cliffy Posted July 30, 2015 Report Posted July 30, 2015 The local shop has a G model in for an annual and the Landing Light Switch/Circuit Breaker is toast, dead, kaput, no worky. They have 4 hrs on phone calls trying to find the part. The manufacturer says they will open up the line and make one for $1100+ and a 12 weeks lead time! I'm guessing that this may be one of those parts that finding one is like finding gold in the parking lot but does anyone have any ideas on where they can look to find one? The part number is- 20TC2-RA-25 Thanks.
RobertGary1 Posted July 30, 2015 Report Posted July 30, 2015 How hard have you tried to find one? Have you called Lake Aero, Don Maxwell, etc. Try the wrecking yards. Kenny Faeth, etc. -Robert
M20F-1968 Posted July 30, 2015 Report Posted July 30, 2015 Why can you not spend your money to put in a new circuit with an LED landing light and new modern switch. You can get a DER to sign it off if you need to. As long as he has proper approved data to work with, you can make the modifications. John Breda 1
tony Posted July 30, 2015 Report Posted July 30, 2015 or find an A&P who thinks its a minor mod and just make a log book entry, sometimes we just make things hard
Cruiser Posted July 31, 2015 Report Posted July 31, 2015 Why is the aircraft grounded? Last I knew it was mostly sunny in Arizona.
Marauder Posted July 31, 2015 Report Posted July 31, 2015 The local shop has a G model in for an annual and the Landing Light Switch/Circuit Breaker is toast, dead, kaput, no worky. They have 4 hrs on phone calls trying to find the part. The manufacturer says they will open up the line and make one for $1100+ and a 12 weeks lead time! I'm guessing that this may be one of those parts that finding one is like finding gold in the parking lot but does anyone have any ideas on where they can look to find one? The part number is- 20TC2-RA-25 Thanks. That part number is a Sensata number (Klixon). Not sure what the RA stands for but it looks like a standard rocker rated at 25 amps. Page 24: http://www.gvzcomp.it/images/downloads/Klixonaircraft.pdf Is that it? Looks like from the brochure they are making labels now as well. http://www.sensata.com/contact/klixon-circuit-breaker-aircraft.htm Contact info for distributors. Expect to pay around $150 for it. Sent from my iPad using Tapatalk 2
cliffy Posted July 31, 2015 Author Report Posted July 31, 2015 Well, lets say that I am not connected with the local shop other than they call me on Mooney stuff if they are stumped. They specialize in Cessna 206s and 207s for the most part. The owner of the airplane (NOT mine OK) wants to fix what he has and not add anything to his bird. Actually it's a very heavily modified G with an E engine and lots of outside mods. Yes it is a Klixon No I have not started looking for them other than saying I'd post this for them They have been calling around most of today trying to find one. I don't know who they called as I was only there for a few minutes today and they asked for my help. I will probably have more info tomorrow. I just got involved with till late this afternoon. I will be checking the above lead also. Thanks for it. 1
cliffy Posted July 31, 2015 Author Report Posted July 31, 2015 Forgot to add- Why is it grounded? Because the shop is picky about FARs and the owner doesn't want to deactivate the system as called for in 91.213
carusoam Posted July 31, 2015 Report Posted July 31, 2015 If it is like my 65C... The landing light is a toggle switch / CB in one. They wear out with use. Finding a replacement was as easy as calling Aircraft Spruce. Important to know the rating and be ready for the pain of removing the brass bar that connects all the switches together in the back... Keep in mind this comes from an aging memory. Best regards, -a-
Seth Posted July 31, 2015 Report Posted July 31, 2015 So it's now basically an F. The E and F have the same 200hp engine. The C and G have the same 180 hp engine. The C and E are short body and the F and G are mid length body. So it's a G with F power and probably F performance except with smaller fuel tanks. -Seth
cliffy Posted July 31, 2015 Author Report Posted July 31, 2015 Yup Switch is out , shop did it. Sounds easy to find but the shop came up dry all day today.
carusoam Posted July 31, 2015 Report Posted July 31, 2015 https://www.aircraftspruce.com/catalog/elpages/klixon72707.php?clickkey=23240 This page has likely candidates... My memory isn't strong enough to cover that much detail for a plane I haven't seen in years... Best regards, -a-
Andy95W Posted July 31, 2015 Report Posted July 31, 2015 Pretty sure this is the one: http://www.aircraftspruce.com/catalog/elpages/klixon7270.php May need to measure the original and compare: http://www.aircraftspruce.com/catalog/pdf/klixon7270_7271.pdf See page 2, AN 7270-1 specifications
cliffy Posted July 31, 2015 Author Report Posted July 31, 2015 1395 Nope! It's a rocker switch w/ CB built in. Thanks for trying.
Marauder Posted July 31, 2015 Report Posted July 31, 2015 1395 Nope! It's a rocker switch w/ CB built in. Thanks for trying. Pretty sure this is the one: http://www.aircraftspruce.com/catalog/elpages/klixon7270.php May need to measure the original and compare: http://www.aircraftspruce.com/catalog/pdf/klixon7270_7271.pdf See page 2, AN 7270-1 specifications The part number cliffy provided is definitely a rocker with an integral breaker found on later Mooneys (like mine). They can be bought new, but are real pricey. Even the ones you have shown are up there price wise. Sent from my iPad using Tapatalk 1
cliffy Posted July 31, 2015 Author Report Posted July 31, 2015 Unfortunately no MEL on this airframe. MELs are aircraft s/n specific and have to be approved for that specific s/n. The owner doesn't have one yet.
RobertGary1 Posted July 31, 2015 Report Posted July 31, 2015 The landing light is part of the MEL? A common misunderstanding or just brevity in wording. An MEL is a document signed by your local FSDO that includes your aircraft's S/N that allows you to operate with certain inop equipment in certain situations. Its more common for 121 operators. Usually it allows for maybe a hydraulic pump to be inop if the APU has a functional additional backup, etc. -Robert
cpbloch Posted July 31, 2015 Report Posted July 31, 2015 You may be able to get by with replacing the landing light with an led unit and sold the problem. When I purchased my 1967 F model on the first flight home the landing light switch/breaker would only stay on for about 5 minutes then it would trip and not be able to reset for another 10 minutes after it cooled off. I immediately changed the landing light to a led unit which draws about 2.5 amps compared to the standard 9 am landing light. Problem solved and the landing light switch/breaker has been very happy ever since, and it will probably function for another 50 years
RobertGary1 Posted July 31, 2015 Report Posted July 31, 2015 If its like my F there are a few switches of the same amperage. The only thing that makes the P/N unique is the writing on the rocker which can be swapped out. -Robert
Hank Posted July 31, 2015 Report Posted July 31, 2015 There are no "MEL" for our planes, we aren't Part 121 or 135. Here is the Required Equipment list from my C, identical to your G except for fuselage length. Looks like you can fly Day VFR just fine.
cliffy Posted July 31, 2015 Author Report Posted July 31, 2015 Yes you can fly day vfr BUT you still have to comply with the "inop" equipment regs to remove or disable the item, including log book sign off. An MEL CAN be approved for any Pt 91 airplane by using the generic MEL from the Feds for Mooneys and modifying it to fit your particular airplane and then getting approval to operate under its restrictions. It can be done and they are aircraft S/N specific. Trolling junk yards now for the switch. Can't use the old switch as it sounds like a baby's rattle when shaken.
Shadrach Posted July 31, 2015 Report Posted July 31, 2015 On July 31, 2015 at 0:54 PM, RobertGary1 said: A common misunderstanding or just brevity in wording. An MEL is a document signed by your local FSDO that includes your aircraft's S/N that allows you to operate with certain inop equipment in certain situations. Its more common for 121 operators. Usually it allows for maybe a hydraulic pump to be inop if the APU has a functional additional backup, etc. -Robert I misspoke..."Required Equipment" per the TCDS. The landing light is not required equipment per the TCDS nor does it need to be removed. It does not need to be deactivated as that bar has already been met... AC91-67 defines deactivation as written below: g. Deactivation means to make a piece of equipment or an instrument unusable to the pilot/crew by preventing its operation. The flow chart for 91.213 leads us to the clear determination that it simply needs to be placarded INOP in order to be flown while the appropriate switch is procured. http://www.nbaa.org/ops/maint/inoperative-equipment/operations-without-minimum-equipment-list.php Whoever "grounded" this plane is a first class reg weenie. Should they decide to leave the private sector, I'm sure that they'd do wonderful working for the Fed... 5
Alan Fox Posted August 1, 2015 Report Posted August 1, 2015 No offense , but his license , his rules....(his ass)
