mikesideup Posted July 7, 2015 Report Posted July 7, 2015 I have a 1991 bravo and the O2 is leaking . It takes about a month for it to completely bleed off. Does anyone know from past experience were to start looking?
FoxMike Posted July 7, 2015 Report Posted July 7, 2015 Some soapy water squirted on the fittings in the back would be the best place to start. I am assuming you are careful to shut the bottle off when O2 is not in use. The cable in the cockpit goes all the way back to the bottle. The pressure gauge in the cockpit might be the problem. Good Luck. Walt
mikesideup Posted July 7, 2015 Author Report Posted July 7, 2015 I am hoping it is in the back where it is accessible,I don't like pulling the interior panels. Without looking at the drawing I assume there is a line running to the gauge as well. I always shut the oxy off when not in use because I never forget anything! I always shut the oxy off when not in use because I never forget anything! Thanks for the info.
carqwik Posted July 7, 2015 Report Posted July 7, 2015 I had a leak in the regulator...only "leaked" when the O2 knob was turned on...
