I have polished spinner on my 3 blade propeller ( M20J) and I'd like to get it really nice and shiny. I am not sure what kind of material it is made of and what kind of polish agent I should use.
post-11936-0-78507700-1394144601_thumb.j
I have excellent results with the two step California Custom product.
Effortless too!
It will not remove deep scratches if you have them. It will bring back a stunning mirror shine to the spinner!
post-7035-0-85733700-1394146555_thumb.jp
Mask off the cowl and the prop. Use on spinner ONLY.
PM me on how to use it if need to.
I just needed to replace my spinner. Now I have a "matt" spinner and am wondering how to best polish.
What is the method? Elbow grease?
If it is truly a matte finish, you best use a powered pad to restore the shine.  You might need to work through a variety of compounds as well.  Or if you have any hot-rod type shops over there, they could probably do it for very little money.  I had one do my previous spinner for ~$60 after I stripped the paint but did no other prep work.
Bob, I used California Custom which I got at Oshkosh, they had a display showing how easy it was to use, I had a difficult time so I tried the Calif. product and with a little effort it looked great...
How much "effort"? I.e. How much time?
It was really easy ,did a small area at a time and the product did the work, I had used a few other products which were much harder to use and looked terrible..I did the spinner in about an hour and then did a second time much faster, the spinner looked like chrome..
A 30 dollar hand held electric buffer and some mothers aluminum Polish make the spinner look like chrome in less than 10 minutes.
Be careful, my spinner is chrome and you can take the finish right off with some elbow grease, and you really don't want that.
I think mine is polished aluminum. How you can say for sure?
If the spinner looks like chrome it could just be nicely polished...
Chrome is much harder and near impossible to scratch accidentally.
Aluminum scratches easily in comparison.
When the mechanic checks the timing on your engine, they bungee mount a device on the spinner. If its not one of the fancy new plastic versions, it has probably left a footprint behind as a light scratch. (something to think about when you buy a shiny new TopProp)
Check for scratches. If you have them, expect aluminum...
Jim, I believe our plane's are considered not air worthy if you have a chrome spinner, I had a check ride about 10 yrs ago with a Faa ee' who w/n fly in the plane until it was remover, a new spinner cost a few scheckles I contacted an engineer at Kerrville and was told it was not allowed? Then contacted Premiere at Fxe arguably the top Msc' and also was told it should be replaced so I ordered a new one from them..
That's funny, ours is very shiny and in 3 years we haven't polished it. I wonder if someone chrome plated it?
If I am not mistaken chrome plating on an aluminum substrate can lead to galvnic corrosion. The issue isn't the plating, it is the oxidation of the aluminum underneath if the plated surface is compromised. Probably doesn't help either if the aluminum develops a crack underneath and it doesn't penerate the chrome plated surface.
Chris, you are just so enlightened. on the other hand I have a friend who built a christian eagle about 15 yrs ago and chromed his spinner, he has never had any issues at all, apparently the trick is to keep corrosion from being able to form during the process.
It's hydrogen embrittlement.
Byron, I was going to say the same thing but i took a minute to make sure i was saying what i was thinking correctly it appears that it can occur with aluminum but it is more prevalent when chrome plating steel, the formation of corrosion is the big problem with aluminum.
LOL! My "enlightenment" comes from some friends who own boats and are constantly battling the elements. My only enlightenment were my days of dealing with steel/chrome bumpers on cars (yeah I'm old) and living in western New York.
What I don't understand is why it would be okay to paint a spinner.
Sent using Tapatalk
Thats a good point Chris, I know my spinner that was removed, I had it on my J for about 15 yrs. looked perfect, I sent the original to a motorcycle shop that sent it out to be chromed and they did an excellent job, I d/n understand why a chromed one just could not be inspected like the rest of our plane is at annual??
Sent using Tapatalk
I agree, we should powder coat them instead, the finish would hold up better and hide any cracks better   :ph34r:  :o
I polished mine and was going to clear coat afterwards - never got around to the clear coat, but no matter - 5 minutes of caressing my baby's nose once in a while is ok by me.
