Shadrach Posted January 21, 2014 Report Posted January 21, 2014 Scott started a thread similar to this one years ago in the vintage section. I wanted to take it a step further to see where we are as a group and individual models. So tell us your model, useful load, fuel capacity, payload and still air no reserve range. 1967 M20F Useful: 1049lbs Fuel capacity: 64gals useable (384lbs) FF Payload: 665lbs NR Range: 950nm (conservative estimate, I've never done more than 5.5hrs nonstop...
Alan Fox Posted January 21, 2014 Report Posted January 21, 2014 64 S35 , useful load 1250 , Fuel capacity 80 gals , FF payload 770 , Range = 900 65E , useful load 900 , fuel capacity 64 gals , FF payload 515 , range = 900
AndyFromCB Posted January 21, 2014 Report Posted January 21, 2014 1990 M20M with TKS useful 945lb (or 889lb with TKS tank full) full fuel capacity 89 (on paper, but it's been known to hold 102) ff payload 411 nr range (800nm) ff IFR range 650nm (climb to FL180, fly at 195knots at 18.5gph, descent, go missed, go 100nm radius reserve, shoot an approach) I never fly more than 500nm without a stop anyway Real world useful load is if it fits, it will fly and climb at over 1000fpm ;-)
jetdriven Posted January 21, 2014 Report Posted January 21, 2014 1977 M20J. Useful load 951. Fuel capacity 54.7 total, 320lbs. Full fuel payload 651 lb. NM range 685-875 with 10 gallon reserve and zero wind. NM range 845-960 until dry. (both figured at 10GPH-155 ktas and 7.4GPH 130 ktas) absolute max range 4.5 GPH 90 KTAS 12.1 hours 1,089 NM Drag mods: Lasar dorsal fin, horizontal tail fairings, wheel well liners, aileron gap seals, hidden ELT antenna. extra weight: Bladdders, King KN-61 DME, WX-1000 stormscope, KX-170B radios, beefed up cowl.. After getting a new GPS we can shed 20 lbs
John Pleisse Posted January 21, 2014 Report Posted January 21, 2014 1979 J, 945 Lbs 64 gals, 384, 61 usable 561 Payload full fuel 850-900 still air, max range, 75 ROP, 10.8 gph, best economy.
Oscar Avalle Posted January 21, 2014 Report Posted January 21, 2014 1970 M20C Useful load 889lbs Fuel capacity 64gls Full fuel capacity 504lbs Max range more than 6.5 hours...more than my bladder...
Cruiser Posted January 21, 2014 Report Posted January 21, 2014 1999 M20R/S Useful: 1168 lbs. Fuel capacity: 100 gals. usable (600 lbs.) FF payload: 568 lbs. NR Range: 1259 nm. (LOP) 7 hrs. 24 min. till exhaustion.
Joe Zuffoletto Posted January 21, 2014 Report Posted January 21, 2014 2008 M20TN Useful load: 896 lbs. Fuel capacity: 102 (612 lbs.) FF payload: 284 lbs. Range, LOP, with IFR reserves: 1100nm
201er Posted January 21, 2014 Report Posted January 21, 2014 1978 M20J Useful: 981lbs Fuel capacity: 98gals useable (588lbs) FF Payload: 393lbs Actual Range: Unknown Maximum Flown Range: 1320nm, 11 hours on 8GPH with 12 gallons remaining Theoretical Range Without Reserve: 1600nm+ 2
AndyFromCB Posted January 21, 2014 Report Posted January 21, 2014 2008 M20TN Useful load: 896 lbs. Fuel capacity: 102 (612 lbs.) FF payload: 284 lbs. Range, LOP: 1300nm What kind of power setting, speed and what kind of altitude?
Danb Posted January 21, 2014 Report Posted January 21, 2014 Useful load. 965 lbs Full fuel 130 gal. Max range 1465 I generally do fly 5-6 hour legs. Which is why I had the Monroy tanks installed. Best purchase I have made
Bob - S50 Posted January 21, 2014 Report Posted January 21, 2014 1978 M20J Useful load: 960 Fuel capacity: 64 gallons/373 pounds (100LL is 5.82#/gallon, not 6 pounds) FF payload: 587# Theoretical max range (no reserve) -1.5 gal for STTO, climb to 9500' @110k, cruise at 9.3 GPH/155k: 994nm Don't plan to fly more than about 600 - 650 without a pit stop.
Joe Zuffoletto Posted January 21, 2014 Report Posted January 21, 2014 What kind of power setting, speed and what kind of altitude? Sorry, messed up measuring in Google Earth. 1100nm was the range (with IFR reserves) painted on the G1000 on my last trip from Denver to Cabo. FL180, 70LOP, 195KTAS, no wind. On that day, according to the G1000, the tanks would have run dry just south of Puerto Vallarta, roughly 1200nm from Denver. Fixed these figures in my original post.
AndyFromCB Posted January 21, 2014 Report Posted January 21, 2014 Sorry, messed up measuring in Google Earth. 1100nm was the range (with IFR reserves) painted on the G1000 on my last trip from Denver to Cabo. FL180, 70LOP, 195KTAS, no wind. On that day, according to the G1000, the tanks would have run dry just south of Puerto Vallarta, roughly 1200nm from Denver. Fixed these figures in my original post. Amazing...No LOP in Bravo at any decent power setting
Guest Posted January 22, 2014 Report Posted January 22, 2014 Useful: 1500 lbs. Fuel Capacity:130 gallons Load with full fuel: 720 lbs. Endurance: 7.2 hours TAS: 190 @ 18gph Range:1375 nm, better if I slow down Clarence
Bob_Belville Posted January 22, 2014 Report Posted January 22, 2014 1966 M20E with most 201 modsUseful: 900 lbsFuel capacity: 52 gals usable (300 bs)FF Payload: 600 lbsNR Range: 800 @ Best Power; 900 @ LOP (I seldom fly more than a 4 hour leg = 600 nm no wind)
aaronk25 Posted January 22, 2014 Report Posted January 22, 2014 1977 J 2,740 gross - but operate at 2,900 in protest as I think it's a joke that the faa makes it cost prohibitive to STC early j's to the new 2,900 gross weight. Not starting a argument just my view. Legal useful 960 useful. 66 gallons actual full fuel so 564 useful when full 1041nm range at 9.2gph 155kts at 9,000ft. 1,302nm at 7.5gph at 148kts at FL170 At 2,900lbs (when DA is less than 5,000) 1,120lbs useful. 724 with full fuel.
Hector Posted January 22, 2014 Report Posted January 22, 2014 1967 M20C Useful: 1000.5lbs Fuel capacity: 52 gals FF Payload: 688.5 Range: around 600 NM with IFR reserve Sent from my iPad using Tapatal
kmyfm20s Posted January 22, 2014 Report Posted January 22, 2014 64 S35 , useful load 1250 , Fuel capacity 80 gals , FF payload 770 , Range = 900 65E , useful load 900 , fuel capacity 64 gals , FF payload 515 , range = 900 Ya but you got to live with that funny looking tail with your heavy hauling S35!
Lood Posted January 22, 2014 Report Posted January 22, 2014 1967 M20F Useful load: 967lbs Full fuel payload: 583lbs Max no reserve range: 6.3hrs or 870nm in no wind I do operate it with a useful load of 1039lbs though and thus a full fuel payload of 655lbs. In South Africa, our airplanes have to get a new weight & balance every 5 years and even though I did quite a few weight reducing exercises between the previous and last weighing sessions, my airplane gained 72lbs!! Before the last weigh in, I always operated it at the previous, higher empty weight and it performs perfectly well, under all circumstances. So, if necessary, I load it up with 655lbs and that extra 70 odd lbs sometimes makes a huge difference.
M016576 Posted January 22, 2014 Report Posted January 22, 2014 1982 Missile with TKS useful 998 (or 944lb with TKS tank full) full fuel capacity 100 gallons ff payload 398 lbs (344lbs) No reserve range (13.5gph, 175kts, ~10k msl): 1200NM I'm digging this missile!
FlyDave Posted January 22, 2014 Report Posted January 22, 2014 1989 Bravo U/L 1,006 lbs. Max fuel: 106 gal. Payload w/full fuel: 389 lbs. (using 5.82 lb/gal for 100 LL ) Usable fuel: 100 gal. 17,500' 15.5 gph 190KTAS (economy cruise) Range w/o reserves but allowing for ground covered in climb: ~1145 nm
Nemesis Posted January 22, 2014 Report Posted January 22, 2014 1980 M20K 231 Useful: 940 lbs Fuel: 72 Useable 432 lbs FF Payload: 508 NR Range: 957 NM My normal flight planning is for 174 KTAS at 17500 and 13 gal/hr ROP at just under 75% power. My limiting factor for LOP is a very high TIT so I can not even approach 70% when LOP. While testing LOP, I can run at about 60% and 9.2 gal/hr and maybe 163 KTAS, Given those numbers, I might get a theoretical 1271 NM and 7.8 hours. The most that I have done in one flight was 805 NM and 5.3 hours. Jackson TN to Front Range Denver. Had a bit of a headwind and dialed back the power a bit. Landed with about 12 gals remaining. Useable range with reserves is really 800 NM to 1100 NM depending on power settings.
