rockydoc Posted March 7, 2013 Report Posted March 7, 2013 What is the procedure for converting my 1965 M20C from a generator to an alternator. Quote
KSMooniac Posted March 7, 2013 Report Posted March 7, 2013 I'd start here:  http://www.plane-power.com/SAL12-70.htm   If you're on a tighter budget, you might ask you mechanic if similar parts from a later Mooney can be retrofitted onto your O-360.  If so, I'd have the brackets, alternator, voltage regulator, etc. from an IO-360/M20J installation that could be used.  I don't know if the same alternator brackets can be used on the IO and O-360, but there is a good chance they will work. Quote
carusoam Posted March 7, 2013 Report Posted March 7, 2013 Consider getting a modern voltage controller for the generator. Low cost, big improvement. Identical foot print. Rebuilt generators are available from aircraft Spruce. Easy to install, check with your A&P for details. The biggest problem of the old technology was the mechanical controller. Modern controllers fix that and provide benefits such as LED information about system status. Search this site for Zeftronics controllers. Alternators do provide a wider voltage vs rpm output. So if you have to ground idle for extended periods of time, the alternator may be better. Best regards, -a- 2 Quote
Mooneymechanic Posted March 7, 2013 Report Posted March 7, 2013 I have a complete low time, under 100hr 50 amp conversion kit if you need one. Quote
JetSet1967 Posted March 7, 2013 Report Posted March 7, 2013 I had to overhaul my Carb air box.  I had to remove the lower cowling, so I decided that I had all this removed and it was crazy not to do the Generator/Alt conversion. I also opted to replace the starter with the lightweight high torque starter as well. The hardest part of the whole install was trimming the baffling so the Alternator would fit. If you are good with your hands it is very easy. 1 Quote
aeromancfi Posted March 7, 2013 Report Posted March 7, 2013 I just completed a conversion to Plane Power 70 amp alterrnator in a 1965 M20E. Get the kit which includes the brackets, a solid state regulator, FAA337 form, and HIgh Voltage  warning lamp. Here's the work required: Modify your front engine baffle to accomodate the larger unit, and seal around the opening with Red silicone rubber sheet (plain or fabric reinforced).  I placed a .025 aluminum reinforcing doubler around the larger opening on the bottom strap. You will have to remove the probeller and remove the front baffle to do the work. You will also have to buy a new V-belt for the alternator because of different geometry.  You need to locate the HIgh Voltage lamp in your panel and wire it in with a 1 amp fuse or breaker. You also need to install a Field switch with 5 amp breaker, or combined Klixon breaker-switch so you can disconnect the alternator in case of overvoltage and protect your radios etc. Your generator is probably 50 amp as is the main breaker. The 337 is for an upgrade to a 70 amp main breaker. However, in my case i left the 50 amp breaker in place since I don't have a big electircal load iln the plane.  A lot of work, but much better 21st Century system. Be sure to torque the the brackets tot he engine case exactly as requred by Lycoming, No more no less and safety same. Also make sure you have a good ground strap between the engine and the airframe. DS Quote
carusoam Posted March 7, 2013 Report Posted March 7, 2013 Getting the lower cowling off is the "hard" part. Alternator and light weight starter are the modern solution to the old problem. Doing it all at once makes the most sense. Finishing it with a new Concorde battery would be the trifecta...(I've only read this here, but it's worth repeating) Best regards, -a- Quote
scottfromiowa Posted March 7, 2013 Report Posted March 7, 2013 Just to give another perspective...I replaced my generator (with a rebuilt unit) and my zeftronics(sp) control unit for minimal dough and spent my money installing a HID landing light. Zero issues. I also installed an EI volt/amp gauge so I know if I am discharging. No desire to "upgrade" 1 1 Quote
Alan Fox Posted March 8, 2013 Report Posted March 8, 2013 Remove said generator , Mail it directly to Scott , recieve a stick of Beemans in the mail , install Planepower conversion kit , increase useable load approx 11 lbs...... 2 Quote
1964-M20E Posted March 8, 2013 Report Posted March 8, 2013 Go with the plane power. You will need to trim the front baffles to fit around the alt. Adjust the voltage regulator to 13.8 to 13.9V. You should be able to use the same belt as the generator. I used the same belt when I change on my former 64E. 1 Quote
Jerry 5TJ Posted March 8, 2013 Report Posted March 8, 2013 Just to give another perspective...I replaced my generator (with a rebuilt unit) and my zeftronics(sp) control unit for minimal dough and spent my money installing a HID landing light. Zero issues. I also installed an EI volt/amp gauge so I know if I am discharging. No desire to "upgrade" I am with Scott on this one: Generators can be fine. Much of the trouble with old Mooney generator systems is due to the Delco regulator.  If you install a new Zeftronics regulator the generator will come on line at a reasonable RPM and keep the voltage buss within decent limits. For 'before' measurements see http://mooneyspace.com/topic/247-electrical-gremlins/?hl=zeftronics The Delco "regulator" does a perfectly horrible job of voltage regulation. Not bad for 1930s technology, I suppose. 1 Quote
jetdriven Posted March 8, 2013 Report Posted March 8, 2013 So, spend 300$ on a new controller to manage a generator which won't charge below 1400-1600 RPM (any ground ops), cracks the case, frequently needs the field flashed, has electrical "noise' which plays hell with your 25 grand radio stack, and weighs 11 lbs more than an alternator? Am I missing something? Quote
M20F-1968 Posted March 8, 2013 Report Posted March 8, 2013 The M20 type certificate includes newer alternators (such as Kelley) which can be installed without much paperwork since the M20 type certificate is good across all M20 models. The costs may be cheaper to go this way without the need to purchase an STC from a different vendor whose product is not on the type certificate. Kelley had some issues in the past but I think these are now fixed.  Going this route would allow the installation of a 70 amp alternator and Zeftronics regulator with I believe lower cost and still get modern equipment.  John Breda Quote
Ned Gravel Posted March 8, 2013 Report Posted March 8, 2013 I just completed a conversion to Plane Power 70 amp alterrnator in a 1965 M20E. +1 Quote
Alan Fox Posted March 8, 2013 Report Posted March 8, 2013 The Alternator conversion although using an alternator rated for 70 amps , is breakered at 50 amps......Still beats the crap out of an generator... Quote
carusoam Posted March 8, 2013 Report Posted March 8, 2013 Byron, The only thing missing is the budget. Makes sense to go all modern, if affordable. My 65 C did well with it's Zeftronics controlled generator. The Narco radios it had would have benefited by smoke inducing voltage Spikes. But the spikes never came.... Best regards, -a- Quote
scottfromiowa Posted March 8, 2013 Report Posted March 8, 2013 Go with the plane power. You will need to trim the front baffles to fit around the alt. Adjust the voltage regulator to 13.8 to 13.9V. You should be able to use the same belt as the generator. I used the same belt when I change on my former 64E. Or mail belt to Scott 1 Quote
scottfromiowa Posted March 8, 2013 Report Posted March 8, 2013 So, spend 300$ on a new controller to manage a generator which won't charge below 1400-1600 RPM (any ground ops), cracks the case, frequently needs the field flashed, has electrical "noise' which plays hell with your 25 grand radio stack, and weighs 11 lbs more than an alternator? Am I missing something? yeah, You are...13lbs for How much does an alternator cost? No issue with charging on ground with new regulator and my HID light gives awesome light at a minimal draw that doesn't challenge generator during taxi. Once again, HOW MUCH IS the conversion? I paid $700 for my ZeeVision HID with install and my control unit was NOT $300. Quote
Ned Gravel Posted March 9, 2013 Report Posted March 9, 2013 I understand the arguments for and against, but my experience doing 35 mins of taxiing on the ground at a busy airport and departing into overcast did it for me. Not enough supply from the generator at those RPMs and about a minute into the soup I noticed the generator beaker had popped. Shut down less-essentials and reset. 10 mins to get it stabilized - all in IMC. Fortunately it was a very warm day. Else the need for pitot heat would have had me declare and return. Never again. Now I have the Plane Power conversion. Sent from my iPad Quote
jetdriven Posted March 9, 2013 Report Posted March 9, 2013 yeah, You are...13lbs for How much does an alternator cost? No issue with charging on ground with new regulator and my HID light gives awesome light at a minimal draw that doesn't challenge generator during taxi. Once again, HOW MUCH IS the conversion? I paid $700 for my ZeeVision HID with install and my control unit was NOT $300.  I just sold a brand new alternator for 250$, and I think the regulator is another 300$. Brackets for 100$, belt for 50$.  So ~800$ all in.  I totally agree on the XeVision HID, but the FAA's "AFS-300 Major repair and installation job aid", dated October 19th, 2012 pretty much bans future installations without an STC. This really sucks because the Boom Beam is expensive. The LED's are an acceptable alternative, but they dont light up the runway at a mile and a half, though.  We already got ours installed in 2011, and its not coming out. We beat the letter. It stays.  "High-Intensity Discharge (HID) lamps and power supplies must have been issued STC for a particular make and model airplane and Parts Manufacturer Approval (PMA) supplement lists’ specific eligibility for installation of HID as supplemental lighting only." http://www.faa.gov/about/office_org/headquarters_offices/avs/offices/afs/afs300/media/Major_Repair_Alteration_Job-Aid.pdf   1 Quote
carusoam Posted March 9, 2013 Report Posted March 9, 2013 Ned, That is the deciding point. My airport is uncontrolled and departures are near immediate. So the point of start-up to generating electricity is not too draining. Waiting for a clearance on the ground, draining the single battery, and then departing into IMC lead me to change aircraft. Now, I have two batteries to go with that alternator....and a few other things. Best regards, -a- 1 Quote
MB65E Posted March 10, 2013 Report Posted March 10, 2013 JD-Thanks for putting up the link for the FAA info. 67 pages of more fun to read... Anyone else have any issues with plane power's belt instructions. That gates belt mentioned in the STC is a 9335xl. I found it to be way too short on our gen to alt install. Ended up with a 1/2 in belt that is 38 and 3/8 long. It's on the long side and may run out of adjustment after it wares in. 38" looks to be the better length. Just wondering if I was the only one with this issue? Thanks! Quote
Jerry 5TJ Posted August 8, 2013 Report Posted August 8, 2013 So, spend 300$ on a new controller to manage a generator which won't charge below 1400-1600 RPM (any ground ops), cracks the case, frequently needs the field flashed, has electrical "noise' which plays hell with your 25 grand radio stack, and weighs 11 lbs more than an alternator? Am I missing something? New controller G1500N is $158.75 from Aircraft Spruce.  Charging in my "C" begins at ~1200 rpm.  Never have manually flashed the field in past 6 years.  Noise on 12V buss is reduced greatly with G1500N compared to Delco - agree that it used to be terrible but most of that noise comes from the bang-bang Delco so-called regulator. I measured it before and after, great improvement. Weight, yes, generator is heavier. 1 Quote
Bob_Belville Posted August 8, 2013 Report Posted August 8, 2013 FWIW, December 2012: 1966 E Log: Â "Removed Jasco alternator, mounting brackets and voltage regulator, installed Plane Power, Ltd alternator and voltage regulator in accordance with STC SA10682SC and master drawing list no. 14-5001 rev B dated 11-19-09. Weight and balance updated. Equipment list updated. AFMS placed in aircraft POH. Instructions for continued airworthiness placed in aircraft permanent records. Form 337 completed this date." Â (The new Plane Power is 70A but the CB and wire size in place with the old 50A Jasco were adequate.) Â $1400. parts and labor Quote
orionflt Posted August 9, 2013 Report Posted August 9, 2013 I replaced my generator with a plane power alt before they completed the conversion kit. I installed a zephtronics regulator and had to get a field approval for the installation. I was set to convert to a standard mooney system but my engine was built before they had the boss mount and the original alternators did not have a case mount...at least not one that would work. If you do try to do a direct conversion it is considered a minor mod and only a log book entry is required, but you will have to change the started ring/pulley assembly along with the belt because the alternator uses a thinner style belt. My recommendation would be to just install the plane power convention kit. Brian Quote
