Skeptical not only about the speed, but about a 'factory delivered' TN MSE. The factory may however installed the turbo. I would verify both, and not with the seller!
I have a turbo 201 and it doesn't go that fast. If I take it up in the flight levels I can get 190 KTS, but it takes all day to get up there and about 70 miles to get back down.
I usually run LOP at 9.3 GPH, if I feed it more fuel my TIT gets to high. I can run ROP at about 10.5 GPH I go about the same speed with lower TIT.
I usually fly in the high teens at about 175 - 180 KTS
Is it a Mooney factory installation?
Does it cost you more to maintain then a non turbo? If more, how much more?
Is the TBO can reach 2000 hrs as well as the non turbo?
If you would compared this engine to a six cylinders continental as the 252, what would you say?
Thank you for taking the time...
I would guess that if it was done at the factory it was just a M20 turbos unit that was installed under the M20 turbos STC by a factory mechanic.
Check the airframe logs, the paperwork with the plane should show what was done and by whom. There should be the STC mentioned above.
I looked at the picture of the plane, it is the same conversion I have. M20Turbos turbo normalizer. You can tell by the shark gill vents on the cowl. It was never offered by Mooney.
Maintenance is a bit harder because the already crowded cowl is way more crowded.
I’ve had the exhaust crack which I welded myself, and mounting brackets crack which I sent out for repair ~ $100 per weld repair. Burned up the turbo once (no fault of the system) it cost $2400.00 to repair (never stopped working, I found the damage through inspection). I have had to repair the air box twice because it chafes on everything; it is in there so tight it is impossible to keep it from hitting something. The pressure controller went south it cost $200 to repair (Approved Turbo Components is approved to repair it).
Other than that it works great!
I agree that it is very likely an M-20 Turbos aftermarket kit.  It could not have been installed at the factory because that kit did not exist in 1997!  Perhaps it was installed later by the factory service center.
