Quote: ILXLR8
I registered mooneymap.com and linked it to the map that Jeff set up.  I hope this helps everyone to remember the link.  Thanks for all the participation everyone!
As far as people having extra Mooney parts.  I am in need of a CDT/TIT gauge.  If anyone has one available please let me know.  Thanks!
  • 3 weeks later...
  • Replies 69
  • Created
  • Last Reply
Top Posters In This Topic
I'm now on the map and currently the only member from Maryland noted right now.  Everybody - add yourself to the map (should you want to of course)!
  • 2 weeks later...
  • 2 months later...
Quote: eaglebkh
I'm on now (only one in Alabama), but I accidentally edited the title of the map.  I tried my best to restore original title - apologies.
  • 1 year later...
The mooneymap is a great visual resource.  I just pinned my airport and my aircraft.  Everyone should put their airport and aircraft on the mooney map.  Again, it is a great visual resource.  Thanks.
  • 3 weeks later...
did you put yourself on the map pjsny?
I’m getting frustrated with this Google map. I cannot figure out how to add my name and airport. I think i added my airport 2x (FRG) but cant find a way to put my name with it.
Directions for adding yourself to the Member Map: (Note: must be registered with google)
  1. www.mooneymap.com
  2. in the main search bar type the ICAO code for your airport. e.g. (KLBE)  Make sure your airport comes up and that it is correct.
  3. click on the pin marker over your airport
  4. a box will come up with that locations information.  Click "save to map".
  5. It will prompt you which map you want to save it to.  Make sure you select "Randy B", then click "save"
  6. Once you save it a little box will appear at the top of the screen prompting you to "view map".  click "view map"
  7. Find your airport marker again and click it.
  8. Make sure it's your airport then click the red "EDIT" button on the left side of the screen.  Click it
  9. You will now be able to write whatever you want to in the description box.  When you are done, click "save" on the left side of the screen.
I hope this helps.  I know it's confusing.
I screwed up and entered KPMP more than once, but I can't delete it. Sorry  I hope I didn't ruin the whole map. Maybe Randy can delete the extra entries.
