3 minutes ago, 0TreeLemur said:
Changing tail number on airplane.   Need new engraved plastic label for panel.   Anyone know a place that makes such things?
Thx.
Check your local trophy shop.
For a small fee, I can carve it in cherry, walnut or mahogany if you give me the final size (preferably not too small).
3 minutes ago, LANCECASPER said:
I found them online.  I ordered something from them before.  Good company.  But, I just need a little 2" x 3/4" engraved label with a sticky back.  Probably cost $3.00 from the right place.  A place with "Aircraft" in their name will probably be 10 times that...
Hey, go all out for $15 :D
engravers.net (no "aircraft" in their name)
It's $1.25 per word  https://engravers.net/placards-std.html
 I use a local trophy store for labels.  I send them a PDF of what I want and they print it on aluminum, cut to size.  I believe I pay about $5.00 per label.  Lee
I've got a  Brother labelmaker that's nicer than that - But I want an engraved label that is  2" wide, 3/4" high with letters 0.4" tall.  Thickness 0.025" - 0.05".   White letters on matte black finish.
1 minute ago, LANCECASPER said:
Matt is capable of any size letter you want. He's a great guy to deal with.
I’m redoing my panel right now and had him do all the switches.  He is a great guy and does fantastic work!  Priced very reasonable too.
cheers,
Dan
The place I used to work at had a control panel shop. They had an engraver that made those labels. They used it to label devices in the panels and to make the data plates for the panels. If I needed one for a work project or other project, I just asked the panel shop manager and they showed up at my desk in a few minutes.
I think it was this one:
https://www.visionengravers.com/applications/tags-badges.php
