Jerry Pressley Posted August 24, 2024 Report Posted August 24, 2024 Have a one piece belly panel for sale for $950 but do not know what it fits. 32.5 wide and 79 long. Not for L or Porsche or later Long Bodies as those are more than one piece. Ends are square with cutout for nose wheel well. Good condition will add photos later jerry p 423 231 3491 Quote
PT20J Posted August 24, 2024 Report Posted August 24, 2024 Doesn't look like the factory belly on my M20J. Way too many holes along the perimeter and they don't look to be in line. Maybe the LASAR belly panel? Quote
Bolter Posted August 24, 2024 Report Posted August 24, 2024 37 minutes ago, PT20J said: Doesn't look like the factory belly on my M20J. Way too many holes along the perimeter and they don't look to be in line. Maybe the LASAR belly panel? Were some fiberglass instead of aluminum? May rule out some options. Quote
Will.iam Posted August 24, 2024 Report Posted August 24, 2024 My M20K one piece has way fewer holes like one hole every 6 inches or so not one every inch. Quote
N201MKTurbo Posted August 24, 2024 Report Posted August 24, 2024 That looks like my LASAR one piece. It should have a label imbedded in the fiberglass on the inside. It looks like the holes were doubled up. Mine has 1/2 the holes along the edges. It would take a lot of work to put that back in service. Quote
Hank Posted August 24, 2024 Report Posted August 24, 2024 The one-piece belly on my C looks quite similar, except it's fiberglass with 48 countersunk screw holes around it, and five smaller ones for the notch around the nose wheel. The front end is also not bent upwards around the notch. Quote
ArtVandelay Posted August 25, 2024 Report Posted August 25, 2024 My M20K one piece has way fewer holes like one hole every 6 inches or so not one every inch. Ditto, and mine is fiberglass and holes have camlocs. Quote
Jerry Pressley Posted August 25, 2024 Author Report Posted August 25, 2024 it IS fiberglass. no laser label Quote
Jerry Pressley Posted August 25, 2024 Author Report Posted August 25, 2024 If it was a replacement for the metal multi piece belly skins, would it have all those holes? Quote
PT20J Posted August 25, 2024 Report Posted August 25, 2024 I know of one M20C that has a one off STC for a fiberglass belly panel that the owner made. Quote
Beard Posted August 25, 2024 Report Posted August 25, 2024 As many have said, there appears to be two many holes. It does look like the factory one piece belly on my 1984 M20J. Mine uses cam locks. Quote
PT20J Posted August 26, 2024 Report Posted August 26, 2024 Looks a lot cruder than my factory belly on my M20J. Also, the holes for the cross supports don't seem to be in the same place as mine. And, what are all those large circles and little bumps on the inside? Quote
MikeOH Posted August 26, 2024 Report Posted August 26, 2024 I hate to be the one to say it, but do we know this rectangular sheet with a bunch of holes and a crease down the middle is even an aviation part??? Quote
N201MKTurbo Posted August 26, 2024 Report Posted August 26, 2024 2 hours ago, MikeOH said: I hate to be the one to say it, but do we know this rectangular sheet with a bunch of holes and a crease down the middle is even an aviation part??? Once again, it is the same as my LASER on e piece. With too many holes. Same crease, same hole pattern, same fiberglass mold pattern. Somebody just made more holes than it came with. Quote
N201MKTurbo Posted August 26, 2024 Report Posted August 26, 2024 I think I see where the LASER label is. It gas paint over it. Quote
N201MKTurbo Posted August 26, 2024 Report Posted August 26, 2024 The only time this could be useful, is if somebody had a LASER one piece belly already installed with an STC and had a gear up that destroyed the belly beyond repair. This one could be reworked and put back into service. This scenario is a bit of a stretch. 1 Quote
Jerry Pressley Posted August 26, 2024 Author Report Posted August 26, 2024 Thanks to Mooneyspacer Finally learned what it is. Replacement panel for F G J or K with metal belly. All those holes match the screws on the metal belly skins. A K in TN has the identical pattern and amount of screws. As you folks say it probably is Laser. Quote
Jerry Pressley Posted August 26, 2024 Author Report Posted August 26, 2024 On 8/24/2024 at 2:59 PM, N201MKTurbo said: That looks like my LASAR one piece. It should have a label imbedded in the fiberglass on the inside. It looks like the holes were doubled up. Mine has 1/2 the holes along the edges. It would take a lot of work to put that back in service. where is the laser label? can you see where is covered on this one? jerry Quote
N201MKTurbo Posted August 26, 2024 Report Posted August 26, 2024 13 minutes ago, Jerry Pressley said: where is the laser label? can you see where is covered on this one? jerry I think it is at the top where the paint stripe goes all the way across. I will have mine off in a couple of weeks. I can send you a pic of the label then. Quote
