This is the kit that Lasar sells.  It lists the part numbers if you want to buy them separately.  I lubricate them with EZ Turn Lube.
FUEL CAP SEAT KIT & DRAWING - FUEL CAP SEAL KIT
$13.05
KIT CONTAINS O-RINGS AND NEW COTTER PINS FOR TWO(2) FUEL CAPS
Contains: 2) MS29513-010, 2) MS29513-338, & 2) MS24665-132
Be careful on the little one in the center hole when you remove it.
Use a brass tool to work it out
Using a steel screw driver may/will gouge the grove it sets in so it won't seal good
The blue orings are the only way to go but If you do use the black ones replace the big one every year especially if the
airplane sits outside on a tie down.
Lube the little one in its hole before you assemble the pieces. Adjust the cap lever and then use a new cotter pin on the nut.
