keithmiller Posted February 26, 2023 Report Posted February 26, 2023 Well last week I had my G1000 updated on my 2009 Acclaim at Continental motors FBO AVONICS shop in Alabama . With no help from Garmin who told the shop there it can’t be updated . Do with help from Dugosh in Kerrville who connected me with the guts over at Mooney the shop in Alabama started the update and boy was it a pain in the ass. Two days later I flew home to discover I have no traffic or storm scope . I’ll be returning in a couple of weeks to get that reloaded . Moral to the story is don’t think this is a couple of hour job , it’s difficult and Garmin is no help if your stuck
exM20K Posted February 26, 2023 Report Posted February 26, 2023 What version were you updated to? -dan
keithmiller Posted February 26, 2023 Author Report Posted February 26, 2023 43 minutes ago, exM20K said: What version were you updated to? -dan New software g1000 0401.37
buddy Posted February 26, 2023 Report Posted February 26, 2023 I had mine updated by Premier at FXE in December and had know problems but I had to order Terrain and updated Basemap from Jeppeesen before they could update to 0401.37.
keithmiller Posted February 26, 2023 Author Report Posted February 26, 2023 That’s good to hear and maybe they have had more experience . I’ve purchased 3 planes thru them
LANCECASPER Posted February 26, 2023 Report Posted February 26, 2023 6 hours ago, keithmiller said: Well last week I had my G1000 updated on my 2009 Acclaim at Continental motors FBO AVONICS shop in Alabama . With no help from Garmin who told the shop there it can’t be updated . Do with help from Dugosh in Kerrville who connected me with the guts over at Mooney the shop in Alabama started the update and boy was it a pain in the ass. Two days later I flew home to discover I have no traffic or storm scope . I’ll be returning in a couple of weeks to get that reloaded . Moral to the story is don’t think this is a couple of hour job , it’s difficult and Garmin is no help if your stuck Only do this at a shop that has done some before yours. Don't let them learn on your airplane. Ask me how I know. The Factory got everything straightened out for me, and since I live 12 nm from them, that helped. But you want someone who has done a few and is connected with both Garmin and Mooney - which means you want the Factory or a Mooney Service Center who is also a Garmin dealer. 1 1
keithmiller Posted February 26, 2023 Author Report Posted February 26, 2023 14 minutes ago, LANCECASPER said: Only do this at a shop that has done some before yours. Don't let them learn on your airplane. Ask me how I know. The Factory got everything straightened out for me, and since I live 12 nm from them, that helped. But you want someone who has done a few and is connected with both Garmin and Mooney - which means you want the Factory or a Mooney Service Center who is also a Garmin dealer. I should have asked more questions but we are 90% there . Thanks 1
Brandt Posted March 14, 2023 Report Posted March 14, 2023 Simply inexcusable that Garmin makes their products so buggy and hard to work with. Every database cycle is a battle. The FS510 card is horribly slow and the system often fails to recognize the new database. SD card is a little better, but it’s like rolling the dice.
keithmiller Posted March 14, 2023 Author Report Posted March 14, 2023 I had mine updated at the Avonics shop at continental services in fair hope Alabama 4 weeks ago . There two guys said it’s the worse update they had every done. Constant failures which ended up taking better part of one day plus . I still don’t have my storm scope back and traffic so going back next week to see if we can get that fixed
LANCECASPER Posted March 14, 2023 Report Posted March 14, 2023 48 minutes ago, keithmiller said: I had mine updated at the Avonics shop at continental services in fair hope Alabama 4 weeks ago . There two guys said it’s the worse update they had every done. Constant failures which ended up taking better part of one day plus . I still don’t have my storm scope back and traffic so going back next week to see if we can get that fixed Nothing against them - they are only doing what they know how to do. If it took them over a day and you don't have everything back I wouldn't let them touch it again. Cole over in Georgia has done them, so has Maxwell in Texas and Premier in Florida. It is way too complicated of a procedure for the average avionics tech. Mooney does not include step-by-step instructions with the 401.37 update. Unless the shop has successfully done one before yours they will miss a lot of things. Don't let them brick your G1000. 1
Schllc Posted March 29, 2023 Report Posted March 29, 2023 There are procedural things that have to happen in order for this to go smoothly. I have done it in several planes. Paul Maxwell at Maxwell’s knows how to do it for sure, the avionics guy at premier knows his stuff but is a cranky sob, and they are the most crooked and predatory shop I have ever had the misfortune of dealing with. I know if there is a 345 transponder, all updates have to be loaded to the transponder first using the usb dongle, it should not be done through the g1000. the issue of the storm scope and other feature not working is 100% just lack of attention to detail by the shop doing the install. I have learned the hard way you have to test all of those feature on the ground before leaving. the upside is most of them will not require reinstall. Garmin is probably part of the problem, but again, I lay most of this on the FAA for making innovation prohibitively expensive. good luck!
wingslevel Posted April 7, 2023 Report Posted April 7, 2023 I have 401.37 - I was told that my SD cards are 8gb (plane is new to me...) and that the new .37 version supports these vs the older 4gb - does that sound right? I was going to order some extra SD cards so I can fully update at home and simply swap into the plane. Just confirming that 8gb is what I want - any special brand or formatting required? I found some old threads on this, but, I think everything changes w 401.37
keithmiller Posted April 7, 2023 Author Report Posted April 7, 2023 It seems like the Avonics tech may have received a message that the cards we were using was too small and he moved to a larger card but I could be wrong
atpdave Posted April 7, 2023 Report Posted April 7, 2023 45 minutes ago, wingslevel said: I have 401.37 - I was told that my SD cards are 8gb (plane is new to me...) and that the new .37 version supports these vs the older 4gb - does that sound right? I was going to order some extra SD cards so I can fully update at home and simply swap into the plane. Just confirming that 8gb is what I want - any special brand or formatting required? I found some old threads on this, but, I think everything changes w 401.37 I have 0401.37 and I am using 8GB Sandisk SD cards in the bottom slots. I’m also using a 32GB Sandisk SD card in the MFD top slot for flight logging (overkill for sure) and it works fine. All are standard FAT32 format. Earlier software was much more picky about SD card formatting but 0401.37 seems much improved in that respect.
M20TN_Driver Posted May 6, 2023 Report Posted May 6, 2023 If I am not mistaken, The new g1000 software was tested in one of the Maxwell's plane(s) before it was released. Those guys absolutely know what they are doing.
Danb Posted May 6, 2023 Report Posted May 6, 2023 What does the .37 provide over the prior version. I’m currently having the 345R installed expecting problems based on reading theses issues
buddy Posted May 7, 2023 Report Posted May 7, 2023 One of the things the software upgrade will do is give you FIS-B weather so they told me but I have yet to try it since I use XM weather. I didn’t have any problems after the .37 version was installed. 1
LANCECASPER Posted May 7, 2023 Report Posted May 7, 2023 4 hours ago, Danb said: What does the .37 provide over the prior version. I’m currently having the 345R installed expecting problems based on reading theses issues Dan, who is doing your 401.37 install?
Danb Posted May 7, 2023 Report Posted May 7, 2023 Lance I’m not having it done, I’m having the 345 installed locally. Most likely during Mooneymax I may get it done. You going D
LANCECASPER Posted May 7, 2023 Report Posted May 7, 2023 1 hour ago, Danb said: Lance I’m not having it done, I’m having the 345 installed locally. Most likely during Mooneymax I may get it done. You going D I wish I could, but that week doesn't work for me. @Pmaxwell is definitely the guy to do the 401.37 upgrade.
Rmag Posted May 7, 2023 Report Posted May 7, 2023 We have done software upgrades on G1000 equipped Bell 505 helicopters and GTX 345 installs. It’s a bitch. Because it is OEM, Garmin does not provide support on it. Usually there is no install guide, so you really need to know what you’re doing to set these things up.
keithmiller Posted May 7, 2023 Author Report Posted May 7, 2023 You might be better asking Don Maxwell , but it changed the engine page with the correct levels on turbo temp , cleared up something on the weather page and I’m sure cleaned ip some bugs in the background .. I can’t prove it but I swear it’s a bit faster
LANCECASPER Posted May 7, 2023 Report Posted May 7, 2023 Ideally you want a Mooney Service Center who is also a Garmin dealer, since Garmin and Mooney have a history of pointing at each other when it comes to glitches. The Factory Service Center in Kerrville did mine and although it wasn't by any means easy, they got it done. 1
