RobertGary1 Posted September 28, 2022 Report Posted September 28, 2022 Just thinking it’s been awhile since I’ve been asked to ident. This is any airspace from E to B and I’ve not been asked. Is this a change to the atc system or just an oddity? Quote
philiplane Posted September 28, 2022 Report Posted September 28, 2022 Entering the airspace around Fort Lauderdale Executive, you will get asked to ident most times so they can sort you out from the other dozen planes coming and going. Quote
jlunseth Posted September 28, 2022 Report Posted September 28, 2022 Just depends. I have been asked to ident on about half my flights this summer. Taking off from KFCM it is pretty typical for Departure to request an ident. Once at cruise I hardly ever get asked. Quote
Vance Harral Posted September 28, 2022 Report Posted September 28, 2022 Flew some approaches in real IMC last week in the Denver area. We were asked to ident on the initial ATC callup after switching over from tower, and multiple times on various missed approaches, despite having a discrete code the whole time. Quote
MikeOH Posted September 28, 2022 Report Posted September 28, 2022 Haven’t noticed any difference here in soCal; pretty typical to ident on initial contact with ATC 1 Quote
Ragsf15e Posted September 28, 2022 Report Posted September 28, 2022 I’ve mostly noticed it when departing a towered field under a class C, but not the primary, when ifr. The one I’m thinking of is Hillsboro, or. The pattern is typically full of training AC and portland apch always wants an ident. In fact now I just hit it as I’m making my initial call to them. Maybe it helps them separate a target from the pattern mess? I don’t know. Quote
EricJ Posted September 28, 2022 Report Posted September 28, 2022 Traffic has gotten thick around here again, so if I'm reporting in from someplace with other traffic around I may get asked to ident. It's maybe not as often as it used to be, since many of the controllers now have targets with tail numbers on their displays, but it does still happen. 1 Quote
jaylw314 Posted September 28, 2022 Report Posted September 28, 2022 3 hours ago, Ragsf15e said: I’ve mostly noticed it when departing a towered field under a class C, but not the primary, when ifr. The one I’m thinking of is Hillsboro, or. The pattern is typically full of training AC and portland apch always wants an ident. In fact now I just hit it as I’m making my initial call to them. Maybe it helps them separate a target from the pattern mess? I don’t know. WTH? Are you texting while flying??? 1 Quote
hubcap Posted September 29, 2022 Report Posted September 29, 2022 I regularly get asked to "IDENT" when contacting departure. No change that I can tell. Quote
0TreeLemur Posted September 29, 2022 Report Posted September 29, 2022 6 hours ago, MikeOH said: Haven’t noticed any difference here in soCal; pretty typical to ident on initial contact with ATC Ditto here in the SE too. Quote
FlyingScot Posted September 29, 2022 Report Posted September 29, 2022 10 hours ago, 0TreeLemur said: Ditto here in the SE too. Ditto in MI. No changes noticed. Quote
N201MKTurbo Posted September 29, 2022 Report Posted September 29, 2022 17 hours ago, Ragsf15e said: I’ve mostly noticed it when departing a towered field under a class C, but not the primary, when ifr. The one I’m thinking of is Hillsboro, or. The pattern is typically full of training AC and portland apch always wants an ident. In fact now I just hit it as I’m making my initial call to them. Maybe it helps them separate a target from the pattern mess? I don’t know. I wouldn't ident until asked. when you ident it makes your tag flash on the radar. The controllers are looking for the flashing tag after they ask for it not before. 2 Quote
N201MKTurbo Posted September 29, 2022 Report Posted September 29, 2022 I think a lot of the radar displays now show ADSB data, so your tag will have your N Number displayed without the controller doing anything. If they don't have that capability, they have to positively identify you to assign your N number to your tag. Quote
WaynePierce Posted September 29, 2022 Report Posted September 29, 2022 I can't think of a time when I haven't been asked to ident at first call to Memphis Departure. Quote
irishpilot Posted September 29, 2022 Report Posted September 29, 2022 San Antonio approach asks for IDENT for most aircraft on initial call. Sent from my Pixel 4a using Tapatalk Quote
larryb Posted September 30, 2022 Report Posted September 30, 2022 I hadn’t thought about it but I agree ident requests are less frequent. Quote
rbp Posted October 5, 2022 Report Posted October 5, 2022 check out the JO 7110.65W -- the ATC Bible -- chapter 5, section 3: "Section 3. Radar Identification" https://www.faa.gov/air_traffic/publications/atpubs/atc_html/chap_5.html Quote
PeteMc Posted October 7, 2022 Report Posted October 7, 2022 On 9/28/2022 at 3:49 PM, Ragsf15e said: I’ve mostly noticed it when departing a towered field under a class C I got a request for an Ident this morning going into a Class B and then again tonight going into a Class C. VFR on both flights and it was the typical spitting out the code and asking for an Ident as one instruction. 1 Quote
rbp Posted October 7, 2022 Report Posted October 7, 2022 i'm wondering if its because the surveillance radar systems are now able to correlate ADS-B identifier with the squawk code. I know that on my traffic readout, I see the tail number or call sign of the aircraft. So I'm imagining that the data block now say Reg N2154X Ident 4215 or something like that, eliminating the need for ident in some TRACONs Quote
Hank Posted October 7, 2022 Report Posted October 7, 2022 1 hour ago, rbp said: i'm wondering if its because the surveillance radar systems are now able to correlate ADS-B identifier with the squawk code. I know that on my traffic readout, I see the tail number or call sign of the aircraft. So I'm imagining that the data block now say Reg N2154X Ident 4215 or something like that, eliminating the need for ident in some TRACONs That would be why I'm still ident-ing away. Not living near anywhere helps, too. Sometimes I have to get above 3000 msl and try several times to pick up Atlanta Departure, and if I'm not heading their way they pass me off to Montgomery Approach. Quote
PeteMc Posted October 8, 2022 Report Posted October 8, 2022 7 hours ago, rbp said: i'm wondering if its because the surveillance radar systems are now able to correlate ADS-B identifier with the squawk code. I've seen Controllers comment on how ADS-B is not readily available on all the systems, some you have to dig to see it. But even so, I think the Ident is really more to just pick you out quickly in the masses. Even if the screen is displaying your code, they still need to find it. Or, another question for a Controller, there may be a delay in how quickly your Code shows up. So if they assign a Code and ask you to Ident, they'll see your 1200 before it switches to the new Code. Again, I'm assuming it just makes it easier to find you and see if they need to give any headings or alerts now that they're talking to you. Quote
rbp Posted October 10, 2022 Report Posted October 10, 2022 there's really no reason to guess. its in the doc i posted above Section 3. Radar Identification APPLICATION Before you provide radar service, establish and maintain radar identification of the aircraft involved, 5-3-3 BEACON/ADS-B IDENTIFICATION METHODS When using only Mode 3/A radar beacon or ADS-B to identify a target, use one of the following methods: Request the pilot to activate the “IDENT” feature of the transponder/ADS-B and then observe the identification display. PHRASEOLOGY- IDENT. SQUAWK (code) AND IDENT. Request the pilot to change to a specific discrete or nondiscrete code, as appropriate, and then observe the target or code display change. If a code change is required in accordance with Section 2, Beacon/ADS-B Systems, of this chapter, use the codes specified therein. Request the pilot to change their transponder/ADS-B to “standby.” After you observe the target disappear for sufficient scans to assure that loss of target resulted from placing the transponder/ADS-B in “standby” position, request the pilot to return the transponder to normal operation and then observe the reappearance of the target. PHRASEOLOGY- SQUAWK STANDBY, then SQUAWK NORMAL. EN ROUTE. An aircraft may be considered identified when the full data block is automatically associated with the target symbol of an aircraft that is squawking a discrete code assigned by the computer. 1 1 Quote
hammdo Posted October 10, 2022 Report Posted October 10, 2022 I had to Saturday leaving Rockwood (KRKW) with Atlanta Center... -Don Quote
