Voodoodb Posted March 11, 2022 Report Posted March 11, 2022 Looking for a good Mooney mechanic near PA.
Marauder Posted March 11, 2022 Report Posted March 11, 2022 [mention=10475]orionflt[/mention]He moved. He is down near Wallups Flight Facility now. Sent from my iPhone using Tapatalk Pro
ShuRugal Posted March 11, 2022 Report Posted March 11, 2022 11 minutes ago, Marauder said: He moved. He is down near Wallups Flight Facility now. Sent from my iPhone using Tapatalk Pro lol, I know where my uncle lives - I @'d him because he still gets up to PA regularly and still knows a lot of folks up there, so he can probably recommend a Mooney mechanic. 1
Marauder Posted March 11, 2022 Report Posted March 11, 2022 lol, I know where my uncle lives - I @'d him because he still gets up to PA regularly and still knows a lot of folks up there, so he can probably recommend a Mooney mechanic.Small world. Did I meet you at one of his fly ins? I thought you @‘d him because you thought he was still turning wrenches in PA. Is Alan Wolk still working on planes? He was doing annuals on Merrit’s Mooney. Sent from my iPhone using Tapatalk Pro
ShuRugal Posted March 11, 2022 Report Posted March 11, 2022 7 minutes ago, Marauder said: Did I meet you at one of his fly ins? possibly? I was at the 2019 memorial day fly in. 1
Voodoodb Posted March 11, 2022 Author Report Posted March 11, 2022 I called Henry Weber Aircraft a MSC in PA, but they are 5 weeks out.
Marauder Posted March 12, 2022 Report Posted March 12, 2022 I called Henry Weber Aircraft a MSC in PA, but they are 5 weeks out.I think you’ll find most shops are booked out weeks in our area. Are you looking for someone to do an annual or just something needs to be repaired? I’ve let the shop on my field do the last two annuals (N57). They have done a decent job. Since I’ve owned the plane 31 years, I know the plane better than any mechanic and bring my squawk to them. Sent from my iPhone using Tapatalk Pro
Marauder Posted March 12, 2022 Report Posted March 12, 2022 I need a prebuy.If you don’t know the Mooney well, I’d take it Air Mods over in Jersey or the MSC in Maryland (can’t remember the name). If the plane is local, PM me. I probably know the owner or the plane. Sent from my iPhone using Tapatalk Pro
PeteMc Posted March 12, 2022 Report Posted March 12, 2022 I'll second Air Mods they're in NJ at the Trenton-Robinsville Airport (N87). Give Dave Mathiesen a call 609-259-2400 https://www.airmodsflightcenter.com/ What airport is the plane you're looking at located? 1
carusoam Posted March 12, 2022 Report Posted March 12, 2022 anyone know how big PA is? I heard it might be pretty large, even in Mooney miles… Pitt is kinda far from Penn… What model Mooney are you looking to get PPI’d? See if @Alan Fox has any input to offer… Alan knows the older Mooneys down to the molecular, or at least saw dust/machine chip level… He is located at the East end of PA… Go Mooney! Best regards, -a-
whiskytango Posted March 12, 2022 Report Posted March 12, 2022 2 hours ago, Marauder said: If you don’t know the Mooney well, I’d take it Air Mods over in Jersey or the MSC in Maryland (can’t remember the name). +1 on Air Mods. The MSC in Maryland is Freeway (W00). Both shops are good. 1
carusoam Posted March 12, 2022 Report Posted March 12, 2022 If going to MD… Find RPM… Byron knows aviation… from top to bottom… -a-
Voodoodb Posted March 12, 2022 Author Report Posted March 12, 2022 Thanks all, yes have talked to RPM. Will get with Air Mod as well. Will also need to possibly get it ferried.
orionflt Posted March 12, 2022 Report Posted March 12, 2022 Where is the plane currently located? Brian
PeteMc Posted March 13, 2022 Report Posted March 13, 2022 5 hours ago, Voodoodb said: Will get with Air Mod as well. And again... Where is the plane? I'm heading over to ABE probably on Wednesday. So if that's anywhere close to where the plane is I could easily pick up Dave (Air Mods) on my way and drop him off. Don't know how long it takes for a pre-buy, but at least he could do a once over and talk to you about what your goal was. Then he could figure out a plan with you.
Voodoodb Posted March 13, 2022 Author Report Posted March 13, 2022 Sorry, carusoam, just noticed my blunder and your jab. PA is big. Should have said Reading area. 1
