65 M20E , 4980 TT , 1080 SMOH , 108 Since tear down inspection (Columbia engines) , O&N Bladders (54 gal) , Good solid platform , Manual gear , 2 Blade , with a new hub , and fresh overhaul (88 hours)  GNC250 , and KX155 , KT71 , and GDL88 for adsb out , JPI 701 monitor/fuel flow , Stec 40...   Plane had a gear up , full tear down , 92 hours ago , and then a gear up , and AD inspection 88 hours ago ,  Crank dialed ZERO ... If the the AD inspection bothers you please move on , and buy someone elses aircraft , Plane has been flying 2 times a week since last September  I fly it a lot...   I will post pics , and exact times later tonight...
  • 3 weeks later...
2 hours ago, David Lloyd said:
Yes, the calipers are reversed, now at the lower front.
Thanks David. Does the caliper reversal necessitate running the brake lines in front of the swing arm?
Gee, it's been about 40 years. Think the directions just said to reroute the original hoses.  But going around the front of the swing arm keeps the hose away from spinning parts and the length works out properly.  Did another fitting have to be used at the caliper?  Don't remember, lost in time.
Nope , you just swap the calipers left to right , and everything fits correctly
Factory routing has lines behind swing arm and inside the gear doors. They are secured with adel clamps well away from moving parts. I asked because the ones on the blue plane are routed ahead of the swingarm.
My lines are installed in front like the blue plane.  Looked thru the 1/2" pile of STC instructions for windshield, tips, gap seals, hinge covers, etc. that came with my plane. The only LASAR instruction not there, so can't say for sure.  I think routing around the back with the caliper moved forward would require longer hoses.
It uses the same bolt , and adel clamp , just routed in front.... REALLY guys , its not rocket science...
27 minutes ago, JamieB said:
Potentially interested in your Mooney M20E. The info in your listing doesn't give me the willies. Do you have a price in mind?
Judging by the "55000" in the title, I'd assume thats the price
Thank you Alex... On a side note , should I bring the Mooney , Bo , or Toga to the wedding ???
Although I don't know about the wedding you should fly in style in the Mooney while wearing a toga.  BTW, love the Fat Albert--certainly leaves an impression.
  • 1 month later...
  • 1 month later...
3 hours ago, Captnmack said:
That was a great looking E Alan, but how on earth does it have 2 gear up landings in 100 hours? Of course it could take years to get 100 hours!
That ws within 20 hours , and if you dont put down the gear , thats what happens
  • Haha 3
  • 3 months later...
