Not much, given the dew point spread.
If there is, it will be too cold to cycle the boots, however:  Boot operations are limited to warmer than -30C.
At almost -30C chances icing in even saturated air is very small and here we’re not near saturated. Should be minimal chance if any.
But interesting we see a small temperature inversion up a bit higher.
look forward to learning what I am missing!
  On 3/3/2021 at 1:42 AM, Raptor05121 said:
Scott, do you have any videos explaining how to read a Skew-T?
Expand
I tried them all but really needed a Skew-T for Dummy's video.
A good place to start is, where the heavy Blue and Red lines touch, there will be IMC conditions. Then look at the edges of the chart to see what altitude it will be at, and what temperature it will be. Freezing or below will likely be icing.
The lines aren't touching on this chart so we don't think there's much chance of icing here.
Reminiscent of Scott's post a while back "a nasty icing signature." The big difference is the big dry zone before we get to the inversion, suggesting that there isn't that much moisture to be trapped, and the temperature -30C. The saturation mixing ratio analysis doesn't seem applicable at 15k feet here.
Interesting that you/Scott cut the CAPE from the numbers box. Looking at the chart the moist adiabat line would be to the right of the actual red temp line...i.e. instability...chance of convective clouds reaching 15k, hence icing possible?
Robert
PS: love these puzzles :)
Robert
Expand
Robert,
I didn't cut the CAPE out of this chart.  This is a radiosonde observation and they don't include CAPE on RAOBs. But this might help.
  On 3/3/2021 at 7:33 PM, Scott Dennstaedt said:
Wrote up some more details in my blog here.
Expand
Scott, great discussion.
I had a feeling this case was setting us up to disregard the instability producing the possibility of icing. The CAPE value is less impressive than I thought it would be, but I think the important point is that of the instability overshoot of cumulus clouds above 15,000 feet. Looks like 19,000 feet or higher would be better altitude option, but certainly not high enough with a significantly greater instability/ higher CAPE and higher temperatures.
Expand
Read the blog, which points to ones extreme knowledge in this area is necessary to see the big picture, my first inclination was there would be no ice, after reading the blog which depicted a different answer. Scott I have no clue how to put together the necessary elements to give me a good prediction. Jeez that’s hard, I’ve read a few books on skew t and beyond the basics wow..
Expand
Dan,
Good feedback.  Even though I sell a weather book, this is just the foundation.  Important, but there is a need to learn how to integrate all of this guidance so you understand how to characterize that big picture.  I have been doing a 1-on-1 online training with pilots over the last 15 years for flights they are looking to take. This makes it real and likely one of the best ways to learn how each piece of guidance contributes to making a good decision. Given that each weather event is unique, it’s really hard to put this kind of training in a book. So seeing it all in action for a flight you may take is something you just can’t get from a book.
That’s why I rely on weather forecasts (TAF, windy, aviationweather.gov, usairnet.com, etc).
