I purchased both of these units used for upgrading the panel on my C. However, after a long drawn out panel upgrade on a different aircraft, I’ve decided I don’t have the stomach to go through the process again.
The JPI is a display only package that was originally set up for a O-360 engine. My plan was to upgrade my 830 setup to this primary unit. Please note no sensors are included and therefore would only be advantageous for a 700/730/800/830 upgrade. Price is $1950 shipped including a JPI flush mount adapter.
SOLD: The Garmin gdl 50r is a great unit for panel mounting a 660 or 760. These don’t come up in the used market very often. Price is $475 including shipping. :SOLD
What antennas are required for this one?
Thank you,
Just some general info re the JPI - the part numbers required for some of the probes are different for the STCd 900/930 than the  non-primary 730/830.  I asked the JPI rep and he indicated that the CHT, EGT and RPM probes are common - but MAP, OIL P, Fuel P etc are not common. I’d recommend calling JPI with a list of your probes and part numbers; they said they would be willing to quote a package for upgrade cost.
Thank you,
Ideally a transponder type antenna on the bottom of the aircraft. The gps signal can be obtained from the 660 or 760.
