PT20J Posted March 1, 2020 Report Posted March 1, 2020 23 hours ago, gsxrpilot said: Yeah, just like others have said here, the only reason I suggest an EAA membership in this case, is that SolidWorks is included in the membership. And buying a copy of SolidWorks out right would be several hundred dollars. It's completely legitimate, legal, and all that stuff. It's a benefit to EAA members. Thanks, Paul. I didn’t know that — and I’ve a lifetime EAA member (also AOPA and Seaplane Pilots Assoc.) for years. Skip 1 Quote
Woodpile Posted August 10, 2022 Report Posted August 10, 2022 Is there a particular type or thickness of aluminum required (or preferred) for this work? Quote
DCarlton Posted August 10, 2022 Report Posted August 10, 2022 On 1/30/2020 at 5:39 PM, Planegary said: Am considering replacing my instrument panel plastic due to it being heavily modified in the past with random holes that are no longer relevant and general age. Have looked around for replacement plastic to no avail. Any suggestions? I thought that I found a website that had them for sale but I must have been drinking or hallucinated it altogether I was able to find the plastic overlays at Vantage Plane Plastics for my F. Takes some work to get the lights transitioned over but it can be done. I don't mind the look at all. If I do anything more extensive down the road, I'll make a new AL panel. 2 Quote
carusoam Posted August 22, 2022 Report Posted August 22, 2022 DC, You have that fresh from the factory look going on! Only much newer! Looks fantastic! Best regards, -a- 1 Quote
Igor_U Posted August 23, 2022 Report Posted August 23, 2022 On 8/10/2022 at 11:47 AM, Woodpile said: Is there a particular type or thickness of aluminum required (or preferred) for this work? I used 7050 sheet metal as 2024 t3 was not available at the place that water jet my panels. IIRC, thickness was .125" for pilot's panel and .100" for copilots. I just measured the existing panels and used the same. Quote
0TreeLemur Posted August 27, 2022 Report Posted August 27, 2022 I used 0.125 aluminum on the pilot's side and 0.04 aluminum as a thin veneer overlay on the co-pilot's side. We used a brake to put the factory bend in the pilot-side panel. Quote
