Does anybody know of an A&P in the Eugene, Ore area that can replace our M20J starter motor? My partner is stranded at Cottage Grove (61S) unable to get the plane back to SQL.
No one brave enough to hand prop it ?
Jokes aside, is he not capable of doing that himself?  I just watched it done and it looked like a pretty straight forward change ( on a TSIO520)
Edited by Austintatious
Not yet. Still looking;). My partner is not mechanically inclined and she’s up there on business, so not much leisure time.
There is an MSC in Troutdale, Advanced Aircraft. Might be worth giving them a call.
Advanced didn’t have the part, plus they’re 2 hrs away by car. Western Oregon Flying Services, in Roseberg, not only has the part, but they’re will to fly  down to Cottage Grove and do the install! Super nice!
Alan,
Consider editing your title...
Just a bit...
A few thousand MSers will see that and some may think you are in serious need...
AOG is an appropriate term if you are stuck on the ground and need some help to get going again...
What part do you need?
Or do you need a whole starter?
What starter do you have?
What starter do you want?
What’s your next steps?
A Good friend of mine ,Tony , at Speciality Aero might be able to help. He can also build you the finest Pitts Special you’ll ever see!! Look him up.
-Matt
Thanks everyone. Sorry about the dramatic title. We got it covered. JD from Western Oregon Flying Services just happened to have the correct Sky-Tec starter and flew down from Rosenberg to Cottage Grove and installed it today (Saturday). Absolutely incredible customer service!
What another skytec failing?    I wish I knew how many B&C Starters were installed in the fleet.   You never hear about them.
Edited by Yetti
I replaced my failing BC with a Skytech a few years ago.
Tom
Nope. Replaced a failed Bendix, which failed at worst possible time (plane at small airfield, without MX or FBO). Now has a new Sky-Tec. Works fine.
