Austintatious Posted May 26, 2019 Report Posted May 26, 2019 I have a G5 HSI and a 540w (with latest software)... When I load an LPV approach everything seems to work except "No GP" is displayed on the right side of the g5. The lateral guidance seemingly works correctly, but there is no vertical GP. I have just purchased this aircraft and it may be something I am doing or it could be an issue with the installation... any ideas? Quote
ragedracer1977 Posted May 26, 2019 Report Posted May 26, 2019 I'm assuming you haven't hit the CDI button, right? You're staying in GPS mode? If you're in GPS mode on the 530w and not getting vertical guidance, their might be a setting error or something Quote
Jerry 5TJ Posted May 26, 2019 Report Posted May 26, 2019 At power on the 530W should load its self test. The Glideslope indicator on the G5 should be visible and halfway up. Do you see this self test passing? Quote
Jesse Saint Posted May 26, 2019 Report Posted May 26, 2019 Hold the ENT key next Ike you power it up. On the first setting screen that shows up, make sure “Enable Labels” is showing at the bottom of the screen. Quote
Austintatious Posted May 26, 2019 Author Report Posted May 26, 2019 Thank you guys, I will check this this next time I am with the aircraft. It is currently in the shop for some other work. Quote
201Steve Posted June 24, 2019 Report Posted June 24, 2019 Had the exact problem and did just as @Jesse Saint suggested. Problem solved. 1 Quote
carusoam Posted June 24, 2019 Report Posted June 24, 2019 Great pirep, Steve! Go MS! Best regards, -a- 1 Quote
MICKEY Posted June 30, 2019 Report Posted June 30, 2019 (edited) I just saw this. And I had the exact same issue with the 430W and I changed as per @Jesse Saint. He was right on the money, and fixed it immediately. Now I owe him a case of diet coke. Great MS work! Edited July 1, 2019 by MICKEY Quote
Jesse Saint Posted June 30, 2019 Report Posted June 30, 2019 50 minutes ago, MICKEY said: I just saw this. And I had the exact same issue with the 430W and I changed as per @Jesse Saint. He was right on the money, and fixed it immediately. Now I owe him a beer. Great MS work! Might need to make it a Diet Coke. I’m a teetotaler. Quote
MICKEY Posted July 1, 2019 Report Posted July 1, 2019 9 hours ago, Jesse Saint said: Might need to make it a Diet Coke. I’m a teetotaler. Diet coke it is. 1 Quote
cliffy Posted July 1, 2019 Report Posted July 1, 2019 You guys and MS are amazing! My only problem is I used to fly A-N Radio Range stuff and the "old" ILS stuff where you tuned one frequency and both needles came alive and you flew it. :-) :-) None of this pages deep set up stuff :-) :-) even easier was PAR, they did the work and all you had to do was fly! Wasn't all this electronic/GPS stuff supposed to lighten the cockpit load? 2 Quote
Jesse Saint Posted July 11, 2019 Report Posted July 11, 2019 On 7/1/2019 at 11:51 AM, cliffy said: You guys and MS are amazing! My only problem is I used to fly A-N Radio Range stuff and the "old" ILS stuff where you tuned one frequency and both needles came alive and you flew it. :-) :-) None of this pages deep set up stuff :-) :-) even easier was PAR, they did the work and all you had to do was fly! Wasn't all this electronic/GPS stuff supposed to lighten the cockpit load? Until you’ve flown an efis with an IFR gps and an auto pilot, you may say this. Once you have, I think you will change your mind. Can’t wait to be installing the Dynon SkyView in Mooney’s. Quote
cliffy Posted July 11, 2019 Report Posted July 11, 2019 Does 1500 hrs in B757-200 with an FMC qualify? Would types in B767, B757, B737, B727, CE500, LRJT, and SFAR MU2 qualify to critique? :-) :-) :-) :-) How about the FAAs Master Pilot Award? For me, I've gone from AN Range stuff to FMC Glass panels in my career (as some others here have also). I'm not alone. If you want a really good video, utube "Children of the Magenta Line" and get back to me :-) :-) Yes I'm an old curmudgeon pilot! :-) Hopefully I have enough to pass along so others don't make the same mistakes I and other "old" pilots have made in over 5 decades of flying. 2 Quote
