OK so there has been some talk about installing a backup alternator with people going full electronic instruments negating the need for a vacuum pump.
I began looking into this since I am considering going with the AV030s to replace my AI and DG and eliminating the vacuum pump.  B&C offers some systems STCd but not for the Mooney.  I have not contacted them about it yet.
I wonder if you could get field approvals for increased safety and it is a non required system?
Anyone else out there besides B&C for standby alternator?
https://bandc.com/product-category/alternators/certified-alternators/standby-alternators/
I spoke to them last year when I had the last of my vacuum system removed. It would require a field approval. There is also a fair amount of work needed on the buss to separate out hardware that will run off of the standby alternator. I have it on my list of adds for the next upgrade.
Why separate out hardware that will run off of the standby alternator.  Not flying the space shuttle.  Simply turn off what you don't need until the load is acceptable.
Even if the backup alternator is not able to keep up with the full load it will extend the battery time greatly compared to drawing just on the battery alone.
Should be fairly easy to get approval for a Mooney.  I did field approval papers last year for a European customers TB-20.
14 minutes ago, carusoam said:
I think this is one of the topics that is going to get reviewed more and more....
https://mooneyspace.com/search/?q=Back-up alternator
A Two Battery and two alternator system would be really good...
Somebody would need to write an STC for two smaller batteries in the back of the M20F... :)
Must be midnight, Count Caruso is with us again. :ph34r:
I had the B&C standby alternator in the Ovation.
I too wondered what it would power if the ship's main 100A alternator gave out.   About everything, as it turned out.
I dug into the details a bit and came up with the RPM vs current output curve, and experimented to see if the B&C could hold up the load in normal flight.
All that is back three years:
Edited by Jerry 5TJ
So Jerry, it sounds like you & I need to talk about this power/RPM curve. I have been seriously thinking about the B&C for my naked vacuum pad spot. I started putting together a power consumption spreadsheet. What wasn't answered was things like pitot heat, gear and flaps. I think a 20 amp standby can power my avionics comfortably but what about these short duration power drains?
16 minutes ago, ArtVandelay said:
Can’t the battery handle the short larger loads on the system?
Tom
It should, it comes down to what this 20 amp standy-by alternator will handle and how much will depend on the extra power coming from the battery. I just don't know how much juice the landing gear pulls during extension. It is protected by a 20 amp breaker, so it will probably be in the 10 amp range.
A temporary load like keying the microphone or extending the gear will draw needed power from the battery while the maximum amps from the stand-by alternator is exceeded.  Another good reason to keep a healthy battery in your plane.  When considering a stand-by alternator, it is a safety device to assist you getting to a convenient airport for repair of the big alternator, not for flying around for a month awaiting repair.  The Bo I fly occasionally has a B&C stand-by.  Installation includes light that blinks when the stand-by load is exceeded.
Pretty sure B&C has manuals on their website that describes use.
I’ve reached out to B&C as my last items on vacuum are the speed brakes.  Basically they sent me the paperwork for a Mooney that got field approval.  They have an STC for the bonanza and with newer more relaxed STC processes, it would be nice to see blanket approvals coming through.
The STCd option is the slipstream drop down alternator.
Marauder has a George Foreman Grill and a crock pot plugged in for his girlfriends.  More than likely those stay on during an emergency, so it's not so simple for him.
21 minutes ago, McMooney said:
can you just not install a second identical output alternator?
The biggest thing with this would be space in the cowling.  I don't know where I would put it.
The voltage regulators on each alternator need to play nice with each other.  The B&C voltage regulator does really well automatically switching on the standby alternator when the bus voltage goes low.  So most of the time the standby alternator is just sitting there not drawing any more power than needed to overcome the internal resistance to spinning the rotor inside the alternator.
