Socket size to remove the oil screen ? (sad oil sample)
I change the oil myself but usually just have my mechanic check the screen at annual. I just received my first suspect oil report in 13 years. While not horrible it is suspect because mine have always been excellent reports. I'm a little concerned now and first on the list is to see if the screen has any metal big enough to read the part numbers from (LOL). I believe it's a larger size socket and I don't keep them at my hangar so if someone knows it will save me from carrying a box full. Thanks
Haha, thanks. I had seen some much larger. I do believe the Bravo is a pita, and that's why it isn't done every oil change..... until now I guess  :-(
Mine is 5/8"
Easy out.
Mother of crapping sob frikken .... oh never mind ....  back in :-)
Actually easy in too,  but a pain to safety wire.
5/8”... do watch the video. Expect a little blood... Our royal highnesses are sometimes hateful but love them anyway Perhaps I should get Lynn and Nathan to do another video talking about metal contaminants
Tony, it hasn't been noted here but the PITA about the task is safety wiring the nut when it is reinstalled. If you watch the video you'll see that a couple of extra tools make it easier, make that possible.
5 hours ago, Tony Armour said:
Mine is 5/8"
Easy out.
Did you find anything in the screen?
  • 7 months later...
  • 1 month later...
Lance sorry for the late reply. I found nothing pertaining to the oil report, although I’m not 100% on that.....we don’t think this would cause the report issues. I have had normal report since.
What I did find in the screen was pieces of the rubber dampeners from one of the mags. I forget the exact name but dampens between the mag and engine gears. These rubber parts were heat hardened and the pieces I found were quite scary until I figured out what they were :-o On a good note it caused me to pull the mag (to replace isolator) and during that process, resetting the e-gap and then retiming solved my hot start issue that had starting creeping up. I looked for a picture of said part but haven’t located it yet.
Actually it was noted, by me, above :-)
I will watch the video but I’m guessing the tio540 may be somewhat different (harder) than a normally aspirated 4 cylinder.
