larrynimmo Posted January 10, 2019 Report Posted January 10, 2019 Could t find anything suitable, so I made my own... 5
N201MKTurbo Posted January 10, 2019 Report Posted January 10, 2019 43 minutes ago, larrynimmo said: Could t find anything suitable, so I made my own... Now everybody will want some.
larrynimmo Posted January 11, 2019 Author Report Posted January 11, 2019 Fabric is double knit...and the base is felt...chosen as rigid and one that will adhere with the glue... each boot took about 10 minutes to make...but I used to sew 20 years ago
CaptRJM Posted January 11, 2019 Report Posted January 11, 2019 In case someone is in the same situation but doesn’t have access to sewing machine Hector at Aero Comfort has these Rat Boots made out of leather. When my fabric ones were disintegrating I put them on about 10 years ago. I think he charged me $20 each.
FloridaMan Posted January 11, 2019 Report Posted January 11, 2019 I've heard them referred to as "rodent boots" and not dust boots, and rodents in your wings can be far more corrosive. 1
M016576 Posted January 11, 2019 Report Posted January 11, 2019 34 minutes ago, FloridaMan said: I've heard them referred to as "rodent boots" and not dust boots, and rodents in your wings can be far more corrosive. Or “rat socks” 1 1
N201MKTurbo Posted January 11, 2019 Report Posted January 11, 2019 They are really there to keep carbon monoxide from the exhaust from getting into the cabin through the rod opening. And for mice.
thinwing Posted January 11, 2019 Report Posted January 11, 2019 1 hour ago, N201MKTurbo said: They are really there to keep carbon monoxide from the exhaust from getting into the cabin through the rod opening. And for mice. My thought exactly...I would have picked a flexible ,gas impermeable material like Naugahyde to block CO
Yetti Posted January 11, 2019 Report Posted January 11, 2019 Seems like leather would be best and last longer. Do we think these spots are also fire blocks?
PT20J Posted January 12, 2019 Report Posted January 12, 2019 Mooney IPC calls them out as dust boots. Originals are double-knit fabric. Don't think they'd keep much CO out.
Captnmack Posted January 12, 2019 Report Posted January 12, 2019 I just ordered a complete set for my F from Lasar...a lot more than $20 ea!
larrynimmo Posted January 12, 2019 Author Report Posted January 12, 2019 They will likely send you rudder pedal boots
larrynimmo Posted January 20, 2019 Author Report Posted January 20, 2019 Completed installation ... first picture is with the gear fully retracted...you can see the velcro section bunched up but not interfering. The angle of the camera is abnormal because the wheel being tucked up into the wheel well makes access limited. second picture you can see the smoothly extended boot...the cloth is zip tied tight...and the felt base is glued to the fuselage with contact cement 1
N201MKTurbo Posted January 20, 2019 Report Posted January 20, 2019 Nice job. I would have hit the wheel well with some Krylon first, but that's just me.
larrynimmo Posted January 20, 2019 Author Report Posted January 20, 2019 Out of sight...out of mind...the exposed parts are mainly primered aluminum
M20F-1968 Posted January 30, 2021 Report Posted January 30, 2021 On 1/23/2019 at 4:25 PM, GEE-BEE said: I suggest COVERS BY DENISE marine grade Vinyl I have a small roll of Sunbrella fabric (the stuff cabin covers are made of). Think that might work? John Breda
larrynimmo Posted January 31, 2021 Author Report Posted January 31, 2021 Beware..heavier materials seem to be a better option....but make sure you don’t bind the pushrods to the point they jam and cause damage...my feeling is light and flexible...my expectation is mine will last 20+ years
MinneMooney Posted January 31, 2021 Report Posted January 31, 2021 1 hour ago, larrynimmo said: Beware..heavier materials seem to be a better option....but make sure you don’t bind the pushrods to the point they jam and cause damage...my feeling is light and flexible...my expectation is mine will last 20+ years I would also keep in mind the fact that materials like vinyl or leather are going to be much less flexible in the wonderful wintery conditions we experience in the great white north (i.e. Minnesota). I, for one, would stick with a heavier fabric that also is not especially water absorbent.
EricJ Posted January 31, 2021 Report Posted January 31, 2021 The mystery boots on the aluminum frame that the IA put on just before I bought my airplane had a canvas-like cover and only lasted a few years.
