Just got my M20c back from annual.  I’ve been using Bobby Norman at 42I, the airport where I had my prop strike.  I’m still mad at myself, that should have never happened.
So, the airplane got its annual inspection and an oil and filter change. It got new gear doughnuts and a new part from Mooney for the front gear. Got my step fixed too, now I can crank it without calling on Mr. Atlas.
What did your annual cost? I’ll spill the beans on mine if and when I get a few replies and/or guesses. By the way, this year I just left it without turning a screw or taking apart anything. Not how I like to do it but how it had to go this time.
Annuals on my C have ranged from less than an AMU (partners are great!) to over six . . . My last pilot static check was 2+ . . . While the last one was ~$300.
Too much variability to have a single meaningful number.
Just completed the annual on my M20J last weekend.   $1083,  owner-assisted.   Only a couple small squawks, both of which we fixed during the annual.
46 minutes ago, steingar said:
Mine winded about $1524.
That seems really cheap if you had new gear biscuits put in. Did you supply the parts? My annual this past year was $2400 (first annual) and I didn't really have any significant squawks.
They replaced instrument filters, inspected nose gear, tightened gear clamp on steering linkage, removed a birds nest, cleared manifold pressure line, sprayed corrosion x, charged me some labor for repacking the bearings, checking caliper, etc and changed a brake line. Pretty much it. They billed me 3.5 hours for checking ADs so that added to the cost.
Edited by AlexLev
Wow, repacking wheel bearings is part of the base charge for my annuals . . . . . Bird's nests, Corrosion X, etc., would be extra.
@steingar ISTM you should segregate maintenance cost, such as the gear donuts and the step repair, from the cost of the annual inspection. I suppose many shops have a fixed rate for the inspection, @AGL Aviationdoes and posts them on the website. Deferring maintenance, upgrades, tank patching, etc., etc. until the plane is in the shop for annual does not make those costs part of the 100 hour/annual inspection.
Surely your shop itemized the parts and labor for the non-annual charges.
We've had folks tell us about a $15 or $20,000 annual only to find out that the prop had to be overhauled, the exhaust system was shot, they had to replace 2 cylinders, and they had the gear painted! I never know whether they're bragging or complaining!
13 minutes ago, Bob_Belville said:
@steingar I never know whether they're bragging or complaining!
I spent $2k just on labor on my first annual, not to mention $1.3k on mag overhauls. Total for parts and labor was ~$5k. Flew 6 hours, engine started running rough. Second mechanic pulled the mags and 1 case was cracked. Believe me when I tell you I’m not bragging! :(
I agree, its a lot like asking about TAS, we end up with screen shots of their GS and if the photo is wide enough they are usually descending slightly
 My IA charges 25 hrs labor for the inspection, you cant really compare the cost of an annuals, you can compare hrs charged but not the dollar amount.
$1524 for an annual, oil change, gear pucks and misc is dirt cheap, the pucks alone are a grand
Yeah, I'm thinking $1524 is a good price for a drop off, pick up annual. The gear pucks at $1100 would have to be on top of that.
You’d need to define the term “Annual” Is it a complete airplane inspection, does it use the manufactures checklist (Mooney is 2 pages long, Cirrus is almost 30 as is a Diamond) or some other list?  Are AD’s S/B’s S/I’s included?
A freelance maintainer at wage rate working with you in your hangar with no manuals, no insurance, no inventory and no tools against a full service shop will always have a lower charge.
42 minutes ago, mike_elliott said:
yea, they need it too.
Mike,
Not quite how I see it.  In my experience many Mooney’s are undermaintained, by a combination of maintainers who don’t do, or don’t understand what is required and by owners who seek out these same maintainers.  This is furthered by a less than detailed maintenance manual and inspection program.  The same inspection sheets for an early 60’s Mooney are used for a turbocharged, de-iced  Acclaim.
Newer airframes have more detailed manuals and inspection sheets.
Edited by M20Doc
We charge for 24hours. Most aircraft manufacturers have some sort of reference document outlining how long an annual should take. We always average on the low side.
We just had a C come out of our shop: there was a significant amount of 'deferred maintenance' that had to be addressed. He upgraded his engine monitor, gear pucks, a few expensive landing gear bushings, down lock block... He purchased most of the parts himself to save our markup and I believe his total expense was around 6G to my knowledge. We've run across old invoices in other aircraft records and upon examination were flabbergasted how some were really taken advantage of. One example of that was a total of 80hrs to r&r an engine (on a J) - it usually takes 21-24 hours on a J that has primary engine monitors (JPI). Most shops are reasonable and fair, but there are some that are just unscrupulous.
I am curious, you had just had the mags overhauled and within 6hours the case was cracked? Was it a Bendix/slick? I am also curious as to where the case was cracked - near the mounting flange? If someone installs a Bendix mag with a slick gasket or omit the 'special washer's required for installation, the case certainly can crack. So many things can be screwed up on an airplane by not having the proper information or technical data.
They hide that information in books
I have Bendix (1200 series?) mags. There was a ~2-1/2" crack on the body, not in the immediate vicinity (relatively speaking) of the mounting flange. I'm not a metallurgist, but the crack sure didn't look recent to me.
And thanks for the heads up on the installation washers, I'll make sure my new mechanic is aware of those.
Edited by N6018Q
left out info
42 minutes ago, M20Doc said:
<snip>
I for one would be interested in an updated inspection check list for my vintage Mooney reflecting the more thorough checklist used for 21 century Mooneys.
I downloaded one from Mooney's website, 2 pages each two columns of small print. It's what I use; I can scan one when I get home.
Thanks Hank, I probably have that. What I was looking for is the equivalent of Clarence's 30 pager for Cirrus or Diamond.
5 minutes ago, francisg said:
Basic annual at LASAR is $3500 plus parts provided there are no issues....
A little steep for me, wonder what the hourly rate is
Me too!
Sent from my XT1585 using Tapatalk
