zerotact Posted May 21, 2018 Report Posted May 21, 2018 Hello, I know this subject has been talked about, but 1. I couldn't find it on a search and 2. I think its good to get current information. I just got done repainting my cowl, I had removed all the old and rusty camlok's Who has the best deal on new stainless steel fasteners? I had seen some kits on the online auction site but after counting all the ones I took off, it seems to break down to like almost $7 a fastener, and they are not the OEM camlok brand. So has anyone recently bought new stainless hardware? Quote
cnoe Posted May 21, 2018 Report Posted May 21, 2018 https://skybolt.com/ You can get about anything you need there. Interchangeable with Camloks, and price competitive. Note that there are sometimes different lengths in different spots on the cowling. And if holes are worn you may want/need to adjust some lengths. 1 Quote
hypertech Posted May 22, 2018 Report Posted May 22, 2018 I had a hard time finding some lengths in stainless and the little retainers. These guys have everything. http://www.milspecproducts.com/ 1 Quote
anthonydesmet Posted May 22, 2018 Report Posted May 22, 2018 My first annual I had upper and lower cowl repainted and some fiberglass work done. I just called LAZAR. Gave them my model and s/n and they put the required sizes and types into a package set and sent out that day. No issues - even sent me a couple backups of each size to take on the road if required. 1 Quote
MARZ Posted May 22, 2018 Report Posted May 22, 2018 Dont forget the installaiton tool !! http://www.milspecproducts.com/inc/sdetail/ms_t26/2280 1 Quote
carusoam Posted May 22, 2018 Report Posted May 22, 2018 ThEre are two tools to go with them... the pliers for removing the inner fastener and the tool that Mike posted above... The Mooney parts catalog has all the right fastener details in terms of count and length. There are two or so longer than the others where layers of Aluminum are used... Consider using SS material choice... Great project with excellent results... Best regards, -a- Quote
MARZ Posted June 5, 2018 Report Posted June 5, 2018 + 1 on the stainless - they look great unpainted! Quote
jaylw314 Posted June 5, 2018 Report Posted June 5, 2018 On 5/21/2018 at 3:24 PM, zerotact said: Hello, I know this subject has been talked about, but 1. I couldn't find it on a search and 2. I think its good to get current information. I just got done repainting my cowl, I had removed all the old and rusty camlok's Who has the best deal on new stainless steel fasteners? I had seen some kits on the online auction site but after counting all the ones I took off, it seems to break down to like almost $7 a fastener, and they are not the OEM camlok brand. So has anyone recently bought new stainless hardware? Be careful with SS fasteners. The backing and structure for the cowling is aluminum, so in theory, you could run into corrosion. Realistically, camlocs have so little contact area compared to screws it's not an issue (I live in OR and got SS skybolt hardware), but if you're outdoors in a wet environment, who knows? If you want the part #'s for skybolt, I can look them up at home. I only replaced the small camlocs (3000 series?) because they were pulling through the fiberglass, the big camlocs have been fine. Quote
KSMooniac Posted June 5, 2018 Report Posted June 5, 2018 I just looked at the skybolt site and it looks like they have a great kit for Mooney fiberglass cowls with larger flanges and backup nylon washers to prevent the pull-thru wear.Sent from my LG-US996 using Tapatalk Quote
MooneyTunes Posted June 14, 2018 Report Posted June 14, 2018 I just recently replace my M20J cowl fasteners with Skybolt. The kit is high quality and plenty of different length fasteners to fit your particular cowl. 1 Quote
rbridges Posted June 14, 2018 Report Posted June 14, 2018 I also use the skybolt fasteners. I bought the nylon fasteners but never used them. The wider flange makes wear minimal. Quote
FlyingDude Posted January 28, 2022 Report Posted January 28, 2022 Hi guys, As my annual nears (April ... but better act now) I wanted to replace the 5 camloc-style fasteners that hold the aft edge of the top cowl on the airframe. Only those. Just 5 of them... This is what I found: https://store.skybolt.com/m20-c3p-p397.aspx Of course, as a Mooney owner I know that I am expected to spend every single penny I ever make or can ever borrow on my Hangar Queen, but seriously, 300$ feels outrageous for 5 locks only. All the rest, which are located on side panels, are in great shape. Where can I find substitutes or buy them in small quantities? Please help me cheat destiny... Thanks... Quote
DonMuncy Posted January 28, 2022 Report Posted January 28, 2022 You will have to do some measuring and figuring, but Aircraft Spruce sells them at somewhat reasonable prices. 2 Quote
jaylw314 Posted January 28, 2022 Report Posted January 28, 2022 1 hour ago, FlyingDude said: Hi guys, As my annual nears (April ... but better act now) I wanted to replace the 5 camloc-style fasteners that hold the aft edge of the top cowl on the airframe. Only those. Just 5 of them... This is what I found: https://store.skybolt.com/m20-c3p-p397.aspx Of course, as a Mooney owner I know that I am expected to spend every single penny I ever make or can ever borrow on my Hangar Queen, but seriously, 300$ feels outrageous for 5 locks only. All the rest, which are located on side panels, are in great shape. Where can I find substitutes or buy them in small quantities? Please help me cheat destiny... Thanks... That's to replace every single c-loc fastener in the cowling, along with some extras and I think even the tools. You can just get the individual fasteners from Skybolt as well. I'm not sure there's an advantage to Skybolt in the E. The main advantage is if your cowl has the 2600 series (smaller) fasteners, Skybolt makes a wide-flange version that's better for fiberglass holes. 1 Quote
M20F-1968 Posted January 28, 2022 Report Posted January 28, 2022 Buy the individual fasteners. Use the 4000 series between the top cowling and the cowl deck. The smaller 2000 series with the larger flange will fit into the Mooney small receptacles. Talk to Skybolt to confirm what I have said. John Breda 1 Quote
carusoam Posted January 28, 2022 Report Posted January 28, 2022 Each part is just a couple dollars…. If you are looking to replace the core… the special pliers make it easy… If your plane lived outside… the hardware filled with water and rusted easily… the screw driver then removed the rust one layer at a time… thus camming out the camlocs… (my M20C experience…) Plan on using the stainless version… Exact dimensions are the part number… Part numbers are best found in the Mooney parts catalog… There may be two dimensions needed… the stems depend on how many layers they are holding together… PP, not a mechanic…. Best regards, -a- 1 Quote
FlyingDude Posted January 29, 2022 Report Posted January 29, 2022 Found a bunch of info about camlocs, grommets, receptacles, etc. This one was good: https://jet-tek.com/product-specialties/camloc-fasteners/4002-series/ I think there are a few combinations that would match my measurements... I'll check the parts manual and / or call skybolt on Monday... Thanks a lot guys... Quote
Bartman Posted January 29, 2022 Report Posted January 29, 2022 I bought one each of the 2000 series from Skybolt in sizes that I thought I would need. I did not replace the receptacles and as @carusoam stated above there will be some variation due to wear. I tried the different sizes and figured out what sizes I needed for each hole based on wear and hole depth. Ordered what I needed and a few extra and I’m happy. Use the wide flange stainless. 3 Quote
hypertech Posted January 31, 2022 Report Posted January 31, 2022 If you look closely at the head, there should be a number stamped into it. If its there, and you can read it, that's the length of the faster. Bigger number, longer. shorter number, smaller. 2 Quote
FlyingDude Posted January 31, 2022 Report Posted January 31, 2022 Guys, So, I dug into the parts manual and found this on page 170: Between spruce and skygeek, I can find them. I couldn't find the receptacle on skin drawings. I have the 201 windshield mod. I don't know if that also is a reason. I deduced that the standard 4002 receptacle PN# 214-16 should work. There are 3 flavors https://www.aircraftspruce.com/catalog/hapages/receptacle.php It feels like I should be getting floating & countersunk, because the existing ones are wiggly and rivets are flush on the surface. You think they're are wiggly because the rivets are getting loose? Thanks a lot for your help Quote
carusoam Posted February 6, 2022 Report Posted February 6, 2022 Dude, I’m pretty sure they were not wiggly when the plane was built… +1 for checking the rivet health on what you have… Best regards, -a- 1 Quote
FlyingDude Posted March 9, 2022 Report Posted March 9, 2022 ... and I replaced the camloc receptacles. Now they even click when I fasten them The old ones were badly worn out... Thanks for all the help, guys. 1 Quote
ArtVandelay Posted March 10, 2022 Report Posted March 10, 2022 ... and I replaced the camloc receptacles. Now they even click when I fasten them The old ones were badly worn out...Mine were too tight, I replaced them, the fastners should be level with the receptacles when locked. Quote
FlyingDude Posted March 10, 2022 Report Posted March 10, 2022 29 minutes ago, ArtVandelay said: Mine were too tight, I replaced them, the fastners should be level with the receptacles when locked. Do you have pictures? Quote
