chrixxer Posted May 3, 2017 Report Posted May 3, 2017 Any idea what the antenna is sticking up from the front cowling? COM? (Does it have to live there, on an E? I don't know this airframe yet, but on the Pipers I've been flying, there's ample room behind the windshield for everything...) https://imgur.com/a/uYR8P Quote
thinwing Posted May 3, 2017 Report Posted May 3, 2017 It looks like a dumb (and lazy)place to put a comm ant! Quote
Bryan Posted May 3, 2017 Report Posted May 3, 2017 I had a M20F that had something that looked like that but it was not an antenna but a OAT guage. Here is a picture of mine in some light rime ice Quote
MB65E Posted May 3, 2017 Report Posted May 3, 2017 Old comm antenna probably. Possibly still used. Easy place to put it as the radio is only inches away. Not the best looking place but if it works and no panel upgrades are in the near future I wouldn't worry about it. Just tell people it's the newest wifi antenna. Or sat phone. -Matt 2 Quote
takair Posted May 3, 2017 Report Posted May 3, 2017 Likely one of the comm antennas. I'm pretty sure that was an original location. Mine has the hole there in the structure. The problem with the location is that it causes lots of interference, including nav, when transmitting. Quote
chrixxer Posted May 3, 2017 Author Report Posted May 3, 2017 This aircraft has the same antenna in the same spot: I'm going to be doing a ton of work on the panel / avionics sooner than later, that antenna's getting ripped out when that happens. Quote
RLCarter Posted May 3, 2017 Report Posted May 3, 2017 My 65 E has a comm antenna in the same spot, looks like crap in my opinion but it works, I'll change it if I do a 201 windshield Quote
Jerry 5TJ Posted May 3, 2017 Report Posted May 3, 2017 My 64 E originally had an antenna in that center section between the radio hatches in front of the windscreen. It was a Com antenna about 22" long. I used it as my #2 com antenna. It did not work very well, probably due to poor ground counterpoise, but the feed line was short. Quote
Yetti Posted May 4, 2017 Report Posted May 4, 2017 It's either a Loran Antenna which based on the length it looks like it is. Or it is a VHF antenna which would be a bit shorter than the Loran Antenna. Made by Comit Pull a cover and trace the coax Quote
Yetti Posted May 4, 2017 Report Posted May 4, 2017 if it is a Loran, you can cut a bit off and make it into a VHF comm antenna Quote
carusoam Posted May 4, 2017 Report Posted May 4, 2017 (edited) 65C had one centered between the radio access panels. Mine looked like an ADF wire insulator. Probably what they used to plug the hole... Plan on taking the ceiling panel down once, early in your ownership. Just to mend a few things that have gotten old up there. Like airflow controls, antennae, water drain, that kind of thing... Best regards, -a- Edited May 4, 2017 by carusoam Quote
Jim Peace Posted May 8, 2017 Report Posted May 8, 2017 I had one,,,,It is a VHF comm antenna....... 1 Quote
OR75 Posted May 8, 2017 Report Posted May 8, 2017 On May 3, 2017 at 7:20 PM, Yetti said: if it is a Loran, you can cut a bit off and make it into a VHF comm antenna How much would you have to cut a Loran antenna to make it a vhf ? Quote
orionflt Posted May 8, 2017 Report Posted May 8, 2017 That was the comm antenna on the older Mooneys. Most people have removed them and plugged the hole or replaced the center plate. Brian Quote
Yetti Posted May 8, 2017 Report Posted May 8, 2017 12 inches plus a little bit is a VHF quarterwave. What I can't figure out is if you include the part before the bend and after or just a bit more. There are online calculators to figure out the correct dimensions. The best would be to have one of their vhf antennas and measure it. http://hangarswap.com/ci122sp-6-comant-loran-c-antenna http://hangarswap.com/comant-vhf-ci122-antenna-with-bracket?search=comant vhf antenna Quote
thinwing Posted May 8, 2017 Report Posted May 8, 2017 6 hours ago, Yetti said: 12 inches plus a little bit is a VHF quarterwave. What I can't figure out is if you include the part before the bend and after or just a bit more. There are online calculators to figure out the correct dimensions. The best would be to have one of their vhf antennas and measure it. http://hangarswap.com/ci122sp-6-comant-loran-c-antenna http://hangarswap.com/comant-vhf-ci122-antenna-with-bracket?search=comant vhf antenna Electrically the bend makes no difference with regards to wavelength matching...just bent for some dubious aerodynamics...measure the entire length Quote
1964-M20E Posted May 11, 2017 Report Posted May 11, 2017 It is a com antenna my 64E had the same thing. Works well there short coax cable to the radio. It is a real simple antenna just the rod with a couple of insulators to keep it form making contact to the air frame. Simple connection to the center conductor of the coax cable. One day while tinkering with the plane the antenna rod came out of the base. They are not that expensive. I brought it home left it on the work bench for a couple of days and the rod was firmly attached back to the base. No hangar fairies around since I was on the ramp at that time. Quote
thinwing Posted May 22, 2017 Report Posted May 22, 2017 On 5/11/2017 at 6:32 AM, 1964-M20E said: It is a com antenna my 64E had the same thing. Works well there short coax cable to the radio. It is a real simple antenna just the rod with a couple of insulators to keep it form making contact to the air frame. Simple connection to the center conductor of the coax cable. One day while tinkering with the plane the antenna rod came out of the base. They are not that expensive. I brought it home left it on the work bench for a couple of days and the rod was firmly attached back to the base. No hangar fairies around since I was on the ramp at that time. I like it!..The Oral Roberts school of faith avionics repair! Quote
Raptor05121 Posted May 22, 2017 Report Posted May 22, 2017 Its Com. Mines in the same place. Ugly as sin, but you barely notice it in flight Quote
RLCarter Posted May 23, 2017 Report Posted May 23, 2017 4 hours ago, Raptor05121 said: Ugly as sin, but you barely notice it in flight They are ugly, when I 1st looked I thought mine was disconnected, but wasn't so it's still there. Quote
cleatus99 Posted May 24, 2017 Report Posted May 24, 2017 They are ugly, when I 1st looked I thought mine was disconnected, but wasn't so it's still there. Glider pilot in me would be wanting to put a yaw string on that thing.. Quote
