Bob_Belville Posted September 7, 2017 Report Posted September 7, 2017 25 minutes ago, aviatoreb said: Why did Mooney stop offering retractable step on later Mooneys? Presumably to save money in manufacturing. (I do not believe it was ever "offered" as an option, in the '60s they simply changed from crank to suction and then to fixed.)
aviatoreb Posted September 7, 2017 Report Posted September 7, 2017 17 minutes ago, Bob_Belville said: Presumably to save money in manufacturing. (I do not believe it was ever "offered" as an option, in the '60s they simply changed from crank to suction and then to fixed.) I wish I had it! Sometimes I get in a mood... and think about getting mine removed.
Bob_Belville Posted September 7, 2017 Report Posted September 7, 2017 31 minutes ago, aviatoreb said: I wish I had it! Sometimes I get in a mood... and think about getting mine removed. With the Johnson Bar Gear and the hydraulic flaps, manual cowl flaps, RAM air, and the vacuum step I think my old '66E was built in Mooney's sweet spot. (Though I do like the newer cowl and windshield.) 5
jamesm Posted September 7, 2017 Report Posted September 7, 2017 1 hour ago, Bob_Belville said: With the Johnson Bar Gear and the hydraulic flaps, manual cowl flaps, RAM air, and the vacuum step I think my old '66E was built in Mooney's sweet spot. (Though I do like the newer cowl and windshield.) The only missing would be a Stick as oppose to a yoke. you get rid of a lot mickey mouse linkage above nose wheel well. make ot more like the M20T Mooney Predator 2
Sabremech Posted September 8, 2017 Author Report Posted September 8, 2017 Hmmm, how did we go from a cowling mod thread to talking about retractable or fixed steps?
Bob_Belville Posted September 8, 2017 Report Posted September 8, 2017 2 hours ago, Sabremech said: Hmmm, how did we go from a cowling mod thread to talking about retractable or fixed steps? I suppose we just vamping until we get a notice that you have some more "after" data to report and that you're ready for the next patient. (For planning, I have one trip planned after Summit and would not want to drop off my E until after about October 15.)
MyNameIsNobody Posted September 8, 2017 Report Posted September 8, 2017 45 minutes ago, Sabremech said: Hmmm, how did we go from a cowling mod thread to talking about retractable or fixed steps? There ARE reasons for that...
jamesm Posted September 9, 2017 Report Posted September 9, 2017 (edited) Hum .... I wonder if the person with a "Modern Mooney" Rocket/K model Mooney was just "asking for a friend" who also has high CHT temps on take off and has ugly "guppy mouth" engine cowl opening on their "Modern" Mooney as well while gaining more speed. So they probably figured that David's Cowl Mod is so good that .... If David can do this awesome engine cowl mods on "Vintage Model Mooney's (pre-J Models)" ..... just wait see his retractable step mod on a modern Mooney's. It would be a walk in a park. or maybe just posted in the wrong thread. Helping you David with your spare time just in case you were bored need more stuff to do. Disclaimer: to be clear the Cynicism/ Sarcasm nature tone of my post was NOT direct at David or his Cowl Mod. On a more serious note: the Cowl mod reference it's gratitude that their someone out there willing help out us our CHT issues. However (stating the obvious) the adjectives use to describe the cowl mod was my cheap attempt to "suck up" so that I can get in the cue /line for the cowl mod potentially in the future. Edited September 9, 2017 by jamesm 2
Guitarmaster Posted September 11, 2017 Report Posted September 11, 2017 LET THE GAMES BEGIN!! We are shooting for the end of the month. Here's hoping the FAA and personal schedules will cooperate. 9
Sabremech Posted September 19, 2017 Author Report Posted September 19, 2017 Just a little disassembly of the lower cowling! 4
Marauder Posted September 19, 2017 Report Posted September 19, 2017 Just a little disassembly of the lower cowling! Have you completed CPR on Matt? Sent from my iPad using Tapatalk Pro 1
Guitarmaster Posted September 19, 2017 Report Posted September 19, 2017 29 minutes ago, Marauder said: Have you completed CPR on Matt? Sent from my iPad using Tapatalk Pro Talk about jumping in with both feet!!! 1
Sabremech Posted September 19, 2017 Author Report Posted September 19, 2017 9 hours ago, Marauder said: Have you completed CPR on Matt? Sent from my iPad using Tapatalk Pro Does this mean you'll need CPR too? 1
Bob_Belville Posted September 19, 2017 Report Posted September 19, 2017 Matt's air filter goes inside, I guess the oil cooler goes to the rear via the LASAR STC or is that part of your field approval, @Sabremech? (Mine is already relocated.)
Sabremech Posted September 19, 2017 Author Report Posted September 19, 2017 2 hours ago, Bob_Belville said: Matt's air filter goes inside, I guess the oil cooler goes to the rear via the LASAR STC or is that part of your field approval, @Sabremech? (Mine is already relocated.) Matt has decided to keep the oil cooler in the stock location. Lot's of other maintenance going on at the same time as the cowling mod and relocating the oil cooler would just ad more to the cost. I have two different lower cowling skins depending on the location of the cooler. 1
Marauder Posted September 19, 2017 Report Posted September 19, 2017 22 minutes ago, Sabremech said: Matt has decided to keep the oil cooler in the stock location. Lot's of other maintenance going on at the same time as the cowling mod and relocating the oil cooler would just ad more to the cost. I have two different lower cowling skins depending on the location of the cooler. Is relocating the oil cooler an option at the upgrade or is that something that needs to be done before the upgrade is performed? 3 hours ago, Bob_Belville said: Matt's air filter goes inside, I guess the oil cooler goes to the rear via the LASAR STC or is that part of your field approval, @Sabremech? (Mine is already relocated.) Bob -- you have the relocated cooler. I thought you mentioned at one time you were running fairly warm on the cooler. My temps are fairly reasonable (high 180s to 190s but never over 200).
Bob_Belville Posted September 19, 2017 Report Posted September 19, 2017 2 hours ago, Marauder said: Bob -- you have the relocated cooler. I thought you mentioned at one time you were running fairly warm on the cooler. My temps are fairly reasonable (high 180s to 190s but never over 200). Yeah, my oil temps have gotten higher than I like again. They used to go over 210 in climb and were close to 200 in cruise. I checked and did about everything to little avail. Then for about a year ago the temps were perhaps 15 degrees lower for no apparent reason. I do not think the CHTs, which I deem much more important, correlate very well. Now, starting with formation flying and our trip to KOSH the oil temps are back up. go figure. I emphasize that CHTs are fine. For all the Sherlock Holmes who live here we've: checked and modified baffles and baffle seals including the baffling below the cylinders which had a broken rod at one time. (the port cylinders run 35 degrees cooler than the starboard even though the oil cooler is on that side of the engine. (David's baffling that fits the alternator and starter much better than mine might result in higher pressure air above the engine and in front of the cooler which ought to help.) the oil cooler was inspected and clean by Pacific. They confirmed that the Vernatherm at the same time the oil filter adapter which includes the seat that the vernatherm closes against was removed and the seat was machined by the engine shop/ the cowl flaps are adjusted to be 1/2" open when in the closed position. The cowl flap position does affect CHT and OT in cruise. I've quit tweaking for now since David's cowl with change everything. This flight was several practice approaches...
Marauder Posted September 19, 2017 Report Posted September 19, 2017 Yeah, my oil temps have gotten higher than I like again. They used to go over 210 in climb and were close to 200 in cruise. I checked and did about everything to little avail. Then for about a year ago the temps were perhaps 15 degrees lower for no apparent reason. I do not think the CHTs, which I deem much more important, correlate very well. Now, starting with formation flying and our trip to KOSH the oil temps are back up. go figure. I emphasize that CHTs are fine. For all the Sherlock Holmes who live here we've: checked and modified baffles and baffle seals including the baffling below the cylinders which had a broken rod at one time. (the port cylinders run 35 degrees cooler than the starboard even though the oil cooler is on that side of the engine. (David's baffling that fits the alternator and starter much better than mine might result in higher pressure air above the engine and in front of the cooler which ought to help.) the oil cooler was inspected and clean by Pacific. They confirmed that the Vernatherm at the same time the oil filter adapter which includes the seat that the vernatherm closes against was removed and the seat was machined by the engine shop/ the cowl flaps are adjusted to be 1/2" open when in the closed position. The cowl flap position does affect CHT and OT in cruise. I've quit tweaking for now since David's cowl with change everything. This flight was several practice approaches... Bob -- was this a development or something that was always present since you purchased your E?I'm curious if anyone has "before" and "after" data for the relocation. To squeak out the most speed for David's mod, I am entertaining the cooler relocation as long as it doesn't introduce another issue.Sent from my iPad using Tapatalk Pro
Marauder Posted September 19, 2017 Report Posted September 19, 2017 Does this mean you'll need CPR too? Nah! I saw the quality of your workmanship firsthand. And as a 26 year owner, I have seen everything and am ready for any surprise. Sent from my iPad using Tapatalk Pro 2
Sabremech Posted September 19, 2017 Author Report Posted September 19, 2017 2 hours ago, Marauder said: 2 hours ago, Sabremech said: Is relocating the oil cooler an option at the upgrade or is that something that needs to be done before the upgrade is performed? It would be easier on me if you did this before the cowling mod. I'd like to get them done quicker and am working on my processes to reduce the turn time and associated cost. I'd like to limit my work to just the cowling mod itself. 1
Bob_Belville Posted September 19, 2017 Report Posted September 19, 2017 Just now, Marauder said: Bob -- was this a development or something that was always present since you purchased your E? I'm curious if anyone has "before" and "after" data for the relocation. To squeak out the most speed for David's mod, I am entertaining the cooler relocation as long as it doesn't introduce another issue. Sent from my iPad using Tapatalk Pro Can't help with the before data, the cooler was relocated 20 years ago by a PO. But I'm not so sure I really should be worried, the oil temp pickup is in the rear, right in front of the cooler, I think(?) and would be the hottest sample point. Some oil temp pickups on in the front of the engine. Perhaps @M20Doc or @kortopates or someone who can quantify the typical delta t for different pickup taps.
HRM Posted September 19, 2017 Report Posted September 19, 2017 On 9/6/2017 at 11:16 PM, Bob_Belville said: With the Johnson Bar Gear and the hydraulic flaps, manual cowl flaps, RAM air, and the vacuum step I think my old '66E was built in Mooney's sweet spot. (Though I do like the newer cowl and windshield.) I have the same feeling, but I will add the swept "Buck Rodgers" antennae to the list. Frankly, how do you judge a landing without the retractable step? So easy: good landing, step is there; bad landing, you are going to have to jump off the wing.
Guitarmaster Posted September 20, 2017 Report Posted September 20, 2017 What's normal? Mine rarely gets above 190.Sent from my XT1585 using Tapatalk
Sabremech Posted September 21, 2017 Author Report Posted September 21, 2017 Starting to fit cowling pieces together! 6
