toto Posted November 24, 2016 Report Posted November 24, 2016 Hi all - I have a broken factory electronic tach that went from perfect to intermittent to completely dead in a day. My A&P has determined that the problem is in the tach generator, and that it's no longer possible to buy a new replacement generator. His recommendation is to buy the EI R-1 electronic tach as a drop-in replacement. This would be something like $1100 installed. I've read with great interest all of the various threads on tach replacement, and it seems that most people go with the EI unit for 2.25" applications. I'm not wild about the EI units, which have a curious LED arc, and appear not to have been updated in the past 25 years (so I would be replacing a 25yo factory electronic tach with a third-party electronic tach of the same vintage). I think that the LED format is odd, and replacing only the tach without doing MP and EGT would look particularly odd. I do not have an engine monitor, and I think that my preference would be to install something like the EI CGR-30P unit that could replace the factory gauges. EI is running a nice rebate offer right now for the CGR-30P, which would be 4x as expensive as the R-1 installed, with far more functionality. But the CGR-30P is a 3" display, and would not fit in the 2.25" factory tach hole. My understanding is that there isn't a 2.25" engine monitor that can replace the primary tach, and I don't have an available 3" hole unless I'm ready for major panel surgery. Any advice? Am I better off just buying the R-1 now? Something else? Would I still want the R-1 later after installing an engine monitor that's a primary replacement? (Is having an electronic tach even useful in the event of an electrical failure? Doesn't the tach die along with the engine monitor?) Hope I'm not beating a dead horse with this thread - would appreciate any thoughts. Quote
Guest Posted November 24, 2016 Report Posted November 24, 2016 What model of Mooney do you own? Clarence Quote
toto Posted November 24, 2016 Author Report Posted November 24, 2016 What model of Mooney do you own? Clarence M20J (201) Quote
Guest Posted November 24, 2016 Report Posted November 24, 2016 19 minutes ago, toto said: M20J (201) Here is some info from the maintenance manual. No tach generator in a standard J model. Clarence Quote
Marauder Posted November 25, 2016 Report Posted November 25, 2016 Hi all - I have a broken factory electronic tach that went from perfect to intermittent to completely dead in a day. My A&P has determined that the problem is in the tach generator, and that it's no longer possible to buy a new replacement generator. His recommendation is to buy the EI R-1 electronic tach as a drop-in replacement. This would be something like $1100 installed. I've read with great interest all of the various threads on tach replacement, and it seems that most people go with the EI unit for 2.25" applications. I'm not wild about the EI units, which have a curious LED arc, and appear not to have been updated in the past 25 years (so I would be replacing a 25yo factory electronic tach with a third-party electronic tach of the same vintage). I think that the LED format is odd, and replacing only the tach without doing MP and EGT would look particularly odd. I do not have an engine monitor, and I think that my preference would be to install something like the EI CGR-30P unit that could replace the factory gauges. EI is running a nice rebate offer right now for the CGR-30P, which would be 4x as expensive as the R-1 installed, with far more functionality. But the CGR-30P is a 3" display, and would not fit in the 2.25" factory tach hole. My understanding is that there isn't a 2.25" engine monitor that can replace the primary tach, and I don't have an available 3" hole unless I'm ready for major panel surgery. Any advice? Am I better off just buying the R-1 now? Something else? Would I still want the R-1 later after installing an engine monitor that's a primary replacement? (Is having an electronic tach even useful in the event of an electrical failure? Doesn't the tach die along with the engine monitor?) Hope I'm not beating a dead horse with this thread - would appreciate any thoughts. I have the EI unit in my plane and love it. Mine was installed when an avionics shop replaced the mechanical tach cable with one that was too long and destroyed the tach. I had to adapt from a 3" hole to accommodate the smaller size. I eventually replaced the panel and went with all EI. The LED warning lights are fine since I am only concerned when any of the red LEDs come on. The digital format is easily readable and the backlights are excellent. It has other features like max RPM tracking, tach time and flight time. My FP-5L was installed in the mid 90s and has been problem free. Sent from my iPad using Tapatalk 1 Quote
N201MKTurbo Posted November 25, 2016 Report Posted November 25, 2016 I think the instrument shop at KCHD can overhaul them. I saw them working on them once, it looked like they had the equipment for it. Quote
toto Posted November 25, 2016 Author Report Posted November 25, 2016 I have the EI unit in my plane and love it. Mine was installed when an avionics shop replaced the mechanical tach cable with one that was too long and destroyed the tach. I had to adapt from a 3" hole to accommodate the smaller size. I eventually replaced the panel and went with all EI.The LED warning lights are fine since I am only concerned when any of the red LEDs come on. The digital format is easily readily and the backlights are excellent. It has other features like max RPM tracking, tach time and flight time. My FP-5L was installed in the mid 90s and has been problem free.Sent from my iPad using Tapatalk Your photo of the all-EI setup doesn't look bad to me. Was it strange to have the EI tach by itself before you replaced the MP and fuel flow gauges? Quote
toto Posted November 25, 2016 Author Report Posted November 25, 2016 Here is some info from the maintenance manual. No tach generator in a standard J model. Clarence Mine is a post-205, pre-MSE J, branded as a 201. Quote
toto Posted November 25, 2016 Author Report Posted November 25, 2016 I think the instrument shop at KCHD can overhaul them. I saw them working on them once, it looked like they had the equipment for it. My A&P seemed to know where the generator could be sent for overhaul (not sure where). But he was concerned that it might take a while. The EI install could be done in a day. I'll let him know about KCHD - might be the same place he was thinking of. Quote
Marauder Posted November 25, 2016 Report Posted November 25, 2016 Your photo of the all-EI setup doesn't look bad to me. Was it strange to have the EI tach by itself before you replaced the MP and fuel flow gauges? I actually had the fuel totalizer mounted elsewhere in the panel first. Once I had the tach installed and found I liked it, I decided to remove the MP/fuel pressure gauge, go all digital and rebuilt the right side to accommodate the smaller sized gauges.Later I installed a JPI 900 to get rid of all analog gauges and use digital versions for everything. The EIs and the JPI both are primary and both can be substituted for each other -- allowing redundancy I didn't have before.Here is the mess I cleaned up on the right side:Sent from my iPad using Tapatalk Quote
Marauder Posted November 25, 2016 Report Posted November 25, 2016 Better idea of how everything is laid out. Sent from my iPad using Tapatalk Quote
toto Posted November 25, 2016 Author Report Posted November 25, 2016 Better idea of how everything is laid out. Sent from my iPad using Tapatalk Looks fantastic! Quote
toto Posted November 25, 2016 Author Report Posted November 25, 2016 Better idea of how everything is laid out. Sent from my iPad using Tapatalk For what it's worth, here's a shot of the affected 2.25" stack in my a/c. Quote
Marauder Posted November 25, 2016 Report Posted November 25, 2016 For what it's worth, here's a shot of the affected 2.25" stack in my a/c. The easiest thing would be to fix what you have. The cost is what I would be concerned with. If the cost to fix is high, if it were my plane I would toss in both the EI RPM and MP and be done with it.Sent from my iPad using Tapatalk Quote
Marauder Posted November 25, 2016 Report Posted November 25, 2016 Looks fantastic! Thanks. Still have a little bit more I want to do, but I'm really happy with the functionality this panel provides. Sent from my iPad using Tapatalk Quote
carusoam Posted November 25, 2016 Report Posted November 25, 2016 Background... Marauder is one of those electronics hardware gurus at work... the instrument panel is where he demonstrates his skills... If you go all in one device there are three manufacturers to choose from. All are good... Best regards, -a- Quote
Guest Posted November 25, 2016 Report Posted November 25, 2016 8 hours ago, toto said: For what it's worth, here's a shot of the affected 2.25" stack in my a/c. That is standard factory installed instrumentation. The tachometer is driven by a pair of signal wires connected to the magneto switch in the panel, or by a set of breaker points in the magneto depending on serial number. See the excerpt from the manual I posted above. Clarence Quote
Fritz Kaiser Posted November 25, 2016 Report Posted November 25, 2016 Hello Toto, how's about this one: http://www.aircraftspruce.com/catalog/inpages/uma_electachs.php greetings Fritz Quote
mccdeuce Posted November 25, 2016 Report Posted November 25, 2016 Don't know if it will be of help as it's 3in - but I will be selling my Horizon tachometer shortly. Installing a EI one. (I don't like the location of RPM on the bottom and will be putting it on top of the manifold. I also prefer the LED presentation) http://www.aircraftspruce.com/catalog/inpages/p1000digitaltach.php Quote
goncaloareia Posted November 25, 2016 Report Posted November 25, 2016 Hi I have a spare RPM indicator like the one that failed on your mooney. It was removed working fine from my 252 about a year ago and has been sitting on the shelf since then. The rpm green and red marks are the same and I think that its the same part number. I sell it surely cheaper than the Ei R1. Send me a PM if you want. Goncalo Quote
toto Posted November 25, 2016 Author Report Posted November 25, 2016 That is standard factory installed instrumentation. The tachometer is driven by a pair of signal wires connected to the magneto switch in the panel, or by a set of breaker points in the magneto depending on serial number. See the excerpt from the manual I posted above. Clarence By serial number, my a/c should have the tach connected to the mag. In either case, when the mechanic says that he has traced the problem back to the tach generator, what's he likely referring to? I don't want to start replacing things if there's just a worn connector somewhere that needs to be tightened or resoldered. Quote
Guest Posted November 25, 2016 Report Posted November 25, 2016 1 hour ago, toto said: By serial number, my a/c should have the tach connected to the mag. In either case, when the mechanic says that he has traced the problem back to the tach generator, what's he likely referring to? I don't want to start replacing things if there's just a worn connector somewhere that needs to be tightened or resoldered. Buy him a set of manuals, he clearly doesn't have one. It could be the wires, the points in the magneto or the actual tachometer. Clarence Quote
Mooneymite Posted November 25, 2016 Report Posted November 25, 2016 19 minutes ago, M20Doc said: Buy him a set of manuals, he clearly doesn't have one. Isn't this cheating? Quote
toto Posted November 25, 2016 Author Report Posted November 25, 2016 Buy him a set of manuals, he clearly doesn't have one. It could be the wires, the points in the magneto or the actual tachometer. Clarence Ouch. Apologies for missing the point of your original reply - I didn't make any distinction between an electronic tach and a tach that uses a generator. I do have copies of the J mx manuals, but I'm obviously not a mechanic and certainly don't have the knowledge I would need to steer the shop in the right direction. This mechanic has never touched the plane before, but I was hoping to avoid needing a ferry permit to a shop that I know, and I was assured that he had "plenty" of Mooney experience. Quote
carusoam Posted November 26, 2016 Report Posted November 26, 2016 Toto, When you can, update your avatar data. It is difficult to know what plane you have without it... In the early 90’s, Mooney started to use a hall(?) sensor in the mag to send a signal to the tach. Not sure if the J went that way... Good luck with the details. Best regards, -a- Quote
