After burners, Mach 2, and the ice melts off right?  Where's the problem?
And 6, or 7 G's to flex the wings and break off the accumulated ice.  :blink:
Funny you say that- the procedure for picking up ice in the F-18 was engine heat on, accelerate until ice sublimes.... It works pretty good in the (F-15) Eagle, too... Maybe not so much in a Mooney Eagle!
Edited by M016576
Come to think of it Job, I think I learned that from you in the first place in an email a few years ago.
If icing is even a maybe - like any winter ifr flight is - I also use skew-t and spot check several sites along the route. That seems to be usually pretty accurate.
Just read that the tragic 2014 crash of the Phenom business jet at GAI may be partially due to icing as icing was in the area and reported, and the aircraft driving systems were not activated during the decent.  It may be a contributing factor in the end.
Watch out for and avoid icing!
-Seth
I read that investigator found ice on the airframe--nose and tail. How it survived the fire, I'm not sure . . . They also found the anti-ice systems were not turned on, delaying the stall warning by ~20 seconds.
