Cervelorod Posted August 31, 2015 Report Posted August 31, 2015 I searched and didn't find much, but my throttle friction lock doesn't.... My A&P and I took the end off, but couldn't determine exactly what the issue was in the 10 minutes we had this morning. The service manual doesn't seem to have anything other than the complete assembly. Are there any replaceable parts to refresh the lock? Thanks, Rod 6341Q 68 M20F
RobertGary1 Posted August 31, 2015 Report Posted August 31, 2015 Do you have the cool jet-jock throttle quadrant or the less cool vernier style? -Robert
Guest Posted September 1, 2015 Report Posted September 1, 2015 Try making a ring from a piece of leather. Remove the throttle knob, remove the friction knob, slide the leather down the cable shaft, screw the friction knob back on, then the throttle knob. Tightening the friction knob pinches the leather ring on to the shaft. Clarence
Cervelorod Posted September 1, 2015 Author Report Posted September 1, 2015 It's the lowly push-pull setup, not a jet jockey quadrant The leather washer bit is brilliant, I'll try that in the morn... This forum is worth every penny I paid to join!! Rod
Hank Posted September 2, 2015 Report Posted September 2, 2015 It's the lowly push-pull setup, not a jet jockey quadrant You're just jealous of the mighty C model . . .
Marauder Posted September 2, 2015 Report Posted September 2, 2015 You're just jealous of the mighty C model . . . And the mighty F: Sent from my iPad using Tapatalk
RobertGary1 Posted September 2, 2015 Report Posted September 2, 2015 You have a button on the top of your throttle handle that my F doesn't have. What does the button do? -Robert
Marauder Posted September 2, 2015 Report Posted September 2, 2015 You have a button on the top of your throttle handle that my F doesn't have. What does the button do? -Robert Sorry the picture wasn't very clear, I zoomed in on the label. Landing light Sent from my iPad using Tapatalk 4
HRM Posted September 2, 2015 Report Posted September 2, 2015 You're just jealous of the mighty C model . . . And the mighty F: ...neither is Super. 1
Hank Posted September 2, 2015 Report Posted September 2, 2015 And the mighty F Marauder, Are you saying that Rod purchased an Un-mighty F?? ...neither is Super. Careful, Harley. Marauder may open fire . . .
Guest Posted September 2, 2015 Report Posted September 2, 2015 You have a button on the top of your throttle handle that my F doesn't have. What does the button do? -Robert Helium injection for really heavy loads Clarence
smwash02 Posted September 9, 2015 Report Posted September 9, 2015 If you have the style I've attached, it uses a small piece of phenolic tube. The folks at dugosh sell them for $5 or so.
bonal Posted September 9, 2015 Report Posted September 9, 2015 You're just jealous of the mighty C model . . . I don't know those fancy levers look mighty confusing to me only real pilots need apply
Conrad Posted September 9, 2015 Report Posted September 9, 2015 That's just a normal quadrant, where's the photo of the throttle quadrant with the hair tie to keep the RPMs from backing off? Also you guys are fabulous, fabulous, fabulous. Earlier today I posed this question to some of the folks at LASAR, and they didn't have an answer. 1
M20F Posted September 9, 2015 Report Posted September 9, 2015 (edited) Throttles are for cowards. I just safety wired mine WOT. Edited September 9, 2015 by M20F
bonal Posted September 9, 2015 Report Posted September 9, 2015 That's just a normal quadrant, where's the photo of the throttle quadrant with the hair tie to keep the RPMs from backing off? Also you guys are fabulous, fabulous, fabulous. Earlier today I posed this question to some of the folks at LASAR, and they didn't have an answer. I know it's just a normal quadrant I was just kidding around Jeeze
Hank Posted September 9, 2015 Report Posted September 9, 2015 That's just a normal quadrant, where's the photo of the throttle quadrant with the hair tie to keep the RPMs from backing off? The only pictures I've seen of throttles with rubber bands or hair ties have all been "normal" push-pulls. The quadrant has a screw-in friction lock on the right side that does all three levers at once. It's amazing, sometimes, the quality of response that how-to questions get around here. As long as it's mechanical or assembly related, and not a how-to type question!
Yetti Posted September 10, 2015 Report Posted September 10, 2015 Sorry the picture wasn't very clear, I zoomed in on the label. Landing light Sent from my iPad using Tapatalk Funny mine is placarded "Missiles" You must have the close air support Mooney version. 1
