M20F Posted August 15, 2015 Report Share Posted August 15, 2015 RNAV 08 at CYTZ can that be flown by anyone or is it only for certain approved aircraft? It has a big restricted on the left border in Foreflight. Appreciate any insight. Quote Link to comment Share on other sites More sharing options...
Greg252AY Posted August 15, 2015 Report Share Posted August 15, 2015 That's weird, I have Jeppfd pro charts and I don't show a rnav 8 approach at CYTZ. So I can't help you on that one. Quote Link to comment Share on other sites More sharing options...
M20F Posted August 15, 2015 Author Report Share Posted August 15, 2015 There is a coupled document "RNAV (GNSS) RWY 08 OPS SPEC" that says this procedure is for Dash 8-Q400 but I don't know if that means the limitations or the approach apply only to Dash 8. Quote Link to comment Share on other sites More sharing options...
M20F Posted August 15, 2015 Author Report Share Posted August 15, 2015 I guess my real question is can somebody explain RCAP a bit and how you apply it. Thanks! Quote Link to comment Share on other sites More sharing options...
Marauder Posted August 15, 2015 Report Share Posted August 15, 2015 I don't see an RNAV 8 for CYTZ using fltplnGo. I see an RNAV-A and RNAV-C to go along with the ILS to 8. Neither of the RNAV approaches have any restrictions to GA. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Marauder Posted August 15, 2015 Report Share Posted August 15, 2015 Sorry I missed your other questions. No clue since I don't see that notation on the plates. Where is it published? I have all of the Canadian plates. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Greg252AY Posted August 15, 2015 Report Share Posted August 15, 2015 My understanding is that you have to have a operating certificate and hold the ops specs in that certificate to do a RCAP approach. Kind of like doing a RNP approach in the US. Although I don't know if you have to have special aircraft and aircrew requirements (SAAAR) like you do for the RNP approaches. 1 Quote Link to comment Share on other sites More sharing options...
ZFD Posted August 15, 2015 Report Share Posted August 15, 2015 Greg is correct. I am an instrument procedure designer in Canada. An RCAP approach is restricted by op spec. Only a commercial operator can obtain an op spec from TC. Usually the issue is climb gradient or airport certification 2 Quote Link to comment Share on other sites More sharing options...
carusoam Posted August 15, 2015 Report Share Posted August 15, 2015 Welcome aboard ZFD. Sharing your procedure design experience is greatly appreciated. Best regards, -a- Quote Link to comment Share on other sites More sharing options...
M20F Posted August 15, 2015 Author Report Share Posted August 15, 2015 Thanks! Quote Link to comment Share on other sites More sharing options...
