jamesm Posted April 16, 2015 Report Share Posted April 16, 2015 Hi David, I have the Hartzell 2 blade scimitar prop (top prop) would I need a different spenner with your Cowl mod ? It is my understanding that the spinner falls under the Propeller TC and as I understand it myself (as a mechanic) or whoever can't be changing spinners a at whim without having some sort of STC or some other type paperwork involved. Is your Cowl STC is going to cover airframe for the cowling and spinner under the propeller TC's. Or am I missing somehting ? Thanks, James Quote Link to comment Share on other sites More sharing options...
MyNameIsNobody Posted April 16, 2015 Report Share Posted April 16, 2015 So then you cut the Ram Air and Air Filter for the E-F out and make another bottom mold? Time-Frame for that? Quote Link to comment Share on other sites More sharing options...
Sabremech Posted April 16, 2015 Author Report Share Posted April 16, 2015 Hi James, I'm going to use Hartzell and McCauley spinners as part of my STC. I will have to provide documentation to the FAA covering the spinners and highly unlikely that I can use any spinner outside the TC for the prop. As soon as I get my C model finished and flying, I'll start on the lower cowling for the E&F models. It's still a year away from getting the STC finished due to FAA and DER workload. I intend on submitting the paperwork for the C&G's to get that going while working out the other models unless my DER advises me to do them together. It's easier to mod the airplane than do the paperwork. David 2 Quote Link to comment Share on other sites More sharing options...
jamesm Posted April 16, 2015 Report Share Posted April 16, 2015 Thanks David, So did you make the carb air box out of fiberglass? What size (diameter) duct/hose are you planning on using for the duct/hose going down to carb air box from left inlet? Looks great. James Quote Link to comment Share on other sites More sharing options...
Sabremech Posted April 16, 2015 Author Report Share Posted April 16, 2015 Carb airbox is aluminum and the hose will be 3 inch scat hose. David 1 Quote Link to comment Share on other sites More sharing options...
Browncbr1 Posted April 17, 2015 Report Share Posted April 17, 2015 D r o o o o l . . . . 2 Quote Link to comment Share on other sites More sharing options...
DaV8or Posted April 17, 2015 Report Share Posted April 17, 2015 When you conduct flight tests, does your plane have a digital multi-cylinder engine analyzer? Quote Link to comment Share on other sites More sharing options...
Sabremech Posted April 17, 2015 Author Report Share Posted April 17, 2015 I have an Insight G1 monitor to record data, 4 CHT and EGT with carb temp. Quote Link to comment Share on other sites More sharing options...
M20C Posted April 17, 2015 Report Share Posted April 17, 2015 Very nice David... Since you are doing a Recertification with a DER, you may want to consider a fiberglass RV spinner. They are much cheeper, lighter and durable. Very nice job!!! Quote Link to comment Share on other sites More sharing options...
Sabremech Posted April 17, 2015 Author Report Share Posted April 17, 2015 I've thought about the RV spinner and haven't ruled it out. One concern that I'd have using one is that I'd most likely be required to carry out 100 hours of test flying just for spinner certification. I'm not sure the cost and time to certify a fiberglass spinner is really worth it. It's just easier and I think in the long run cheaper to use an already certified spinner in my kit. Thanks, David 3 Quote Link to comment Share on other sites More sharing options...
Andy95W Posted April 18, 2015 Report Share Posted April 18, 2015 David- Would this only be for someone who had the ARI mod? How about the LASAR? Could I keep my old, original spinner, since new ones are big $$$$ ? Quote Link to comment Share on other sites More sharing options...
Sabremech Posted April 18, 2015 Author Report Share Posted April 18, 2015 it won't matter if it has an ARI, LASAR or is original. This mod will fit the 66 and later C & G models. 66 and later E & F models next and then the earlier models. I need to do some research on a Mooney with the original spinner to see if I can come up with a kit that will work. Thanks, David Quote Link to comment Share on other sites More sharing options...
cliffy Posted April 21, 2015 Report Share Posted April 21, 2015 You do good work. Looks COOL! As mine is a D its an orphan to everything STC'd Nobody includes Ds even though they are just like a C. Autopilots most notably. Quote Link to comment Share on other sites More sharing options...
Hank Posted April 21, 2015 Report Share Posted April 21, 2015 it won't matter if it has an ARI, LASAR or is original. This mod will fit the 66 and later C & G models. 66 and later E & F models next and then the earlier models. I need to do some research on a Mooney with the original spinner to see if I can come up with a kit that will work. Thanks, David How about those of us with Hartzell 3-blade props? Quote Link to comment Share on other sites More sharing options...
bonal Posted April 22, 2015 Report Share Posted April 22, 2015 I've enjoyed watching the progress and sadly with a 64'this won't apply to mine but my question is will removal / installation involve less screws. 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted April 22, 2015 Report Share Posted April 22, 2015 Cliffy, Same thing happens with R & S... They are the same, accept for when it comes to STCs, they are different... Keep up the good work David! Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Sabremech Posted April 22, 2015 Author Report Share Posted April 22, 2015 Hi Cliffy, I'll include the D. It might not be in the first STC just like the pre 66 airplanes, but I do plan on doing an STC for the 65 and older birds. There's a cowling set on EBay right now I'm contemplating buying for the early planes at a reasonable price. I think I get them for the future mod. It will work with the three blade prop with the correct part number spinner. I'll work more on specifics of that later on in the mod. Thanks for all the comments and suggestions. While I'm waiting on the fiberglass work I've turned my attention to the new baffling. I have another cowling I can put on to do most of the baffling except for the front two cylinders. The new prototype carb airbox is being fabricated and should be ready for installation and fitting in a few weeks. I won't have much for pictures for a while, but work is being done. Thanks again, David 3 Quote Link to comment Share on other sites More sharing options...
Cwalsh7997 Posted April 22, 2015 Report Share Posted April 22, 2015 Hey I've been following this thread for a while and I know your experienced in this area, if you need to do the F model cowl and need a test plane id love to help out 1 Quote Link to comment Share on other sites More sharing options...
Sabremech Posted April 22, 2015 Author Report Share Posted April 22, 2015 Hi Cwalsh7997, I have someone who offered their F model for fitting the mod a while ago. I'll keep you in mind if that changes. Thank you, David 1 Quote Link to comment Share on other sites More sharing options...
francisg Posted April 23, 2015 Report Share Posted April 23, 2015 When the times comes for the development of the cowling for the earlier M20C I would be happy to volunteer N6731U a 1963 model.... Quote Link to comment Share on other sites More sharing options...
N6327Q Posted April 23, 2015 Report Share Posted April 23, 2015 Great work!!! Count me in! Quote Link to comment Share on other sites More sharing options...
Sabremech Posted April 28, 2015 Author Report Share Posted April 28, 2015 Just purchased a set of pre 66 Mooney cowlings for future mod work. I'll look to buy more for different years and models as they become available or as I need them. It's going to take time, but there will be cowling mod options for most of the vintage Mooneys in the future. Thanks, David 10 Quote Link to comment Share on other sites More sharing options...
Sabremech Posted May 4, 2015 Author Report Share Posted May 4, 2015 While I wait for the cowling parts to be made, I stripped the paint from the top cowling in preparation for the new parts. I also received the pre 66 cowling parts for future modification. I find it interesting that Mooney used spot welds on the aluminum on these cowls. I've been working with spot welds on a Corsair restoration that's ongoing. The older cowlings will present a challenge to mod, but I'll get it done. David Quote Link to comment Share on other sites More sharing options...
carusoam Posted May 4, 2015 Report Share Posted May 4, 2015 Learned something new about Mooneys today! Spot welding aluminum and they don't come falling apart after 50 years of vibration. The challenge with aluminum, is its ability to spread/transfer the heat you are trying to weld with... Thank you David. Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Sabremech Posted May 4, 2015 Author Report Share Posted May 4, 2015 Hi Jim, Thanks for the heads up on the other cowling design. I'll keep my eyes out for one of those or just need to find a volunteer airplane when the time comes. Still on track for getting the prototype done on mine by the end of the month. It doesn't look like I'll have parts to bring with me to the MAPA Homecoming. I'll bring plenty of pictures to show and look for input or answer questions if anyone has one or two. Thanks, David Quote Link to comment Share on other sites More sharing options...
