Could someone explain the location of the access panel in the wings to inspect the vacuum hoses to the PC wing leveler.  My manual is not very clear to the actual location.
Thanks, Chris
Hi Chris.
The red/green wing leveler tubes run along the lower rear area of each wing, from the fuselage out to the servos.    Remove those rear wing access panels and you'll see them as they travel along.  Inside the cabin, you'll have to remove the side panels for tube access.  I hope that helps you.
Since you are in the area....
Please use caution removing wing panels (Think: is this a fuel tank panel?)   Being upside down and backwards under the wing with an electric screw driver....
Its a mistake less common than a gear up landing.
