benpilot Posted January 23, 2014 Report Posted January 23, 2014 I spoke with Lasar about pedal extension and the max size is only 4" if I recall correctly. I'd still have the yoke in chest panel too close syndrome that Mooney ergonomics challenge me. Any ideas? Quote
AmigOne Posted January 23, 2014 Report Posted January 23, 2014 Elevator shoes?…sorry couldn't resist..:-) Quote
Dave Marten Posted January 23, 2014 Report Posted January 23, 2014 Didn't you say you are 5ft 6? Try on a Mooney for size. You may be surprised by the fit. I have a friend who is barely 5 ft 2 and flies a Mooney. I ask what his pedal setup is. The mooney instrument panel is closer to the pilot than brand C airplanes so you can't use distance from the panel alone to determine your sitting position. Where are you based? We gotta get you in a plane and have you try it on! Quote
NotarPilot Posted January 23, 2014 Report Posted January 23, 2014 You still haven't bought a plane yet? Quote
Rwsavory Posted January 23, 2014 Report Posted January 23, 2014 I spoke with Lasar about pedal extension and the max size is only 4" if I recall correctly. I'd still have the yoke in chest panel too close syndrome that Mooney ergonomics challenge me. Any ideas? Get a Bonanza. 1 Quote
co2bruce Posted January 23, 2014 Report Posted January 23, 2014 Where are you located, I have pedal extentions 3" on co-pilot side and none on pilot side so you can compare. South Fl Quote
flyboy0681 Posted January 23, 2014 Report Posted January 23, 2014 I'm 5' 4", have the 1.5" extension and I don't have any problems with my sitting position. I can fully depress the rudder and apply the brakes. Contrary to what you wrote, the yoke is far from being in my chest and I position the seat in the second row of stops. Quote
Hank Posted January 23, 2014 Report Posted January 23, 2014 Hey, Newbie. All Mooney panels are closer than Cessna panels. Many people use reading glasses for the instruments due to closeness. The plane was built for long-legged pilots, but rudder pedal extensions help. Don't expect to reach Cessna panel distance though. You'll adjust to the closer panel just like you will to more right rudder on takeoff and higher yoke force. If you update your profile to include at least your home state, it will help us help you, as someone may live nearby to permit a test-fit in their plane. There really is no substitute for actually sitting in the aircraft, just be aware of the issues getting in and out. Happy shopping, always fly safe and fly Mooney! Quote
Marauder Posted January 23, 2014 Report Posted January 23, 2014 One thing I have noticed that influences the way seating will or won't work is based on your torso to leg length. Some people with long torsos will sit closer to the yoke to offset the shortness of the legs. If you are long legged and short torso, you are further away from the yoke. Most people are not an equal 50:50 split from hips down. The end result for shorter pilots with short legs in a Mooney is a poor seating arrangement. Sent using Tapatalk Quote
scottfromiowa Posted January 23, 2014 Report Posted January 23, 2014 HELP WANTED: WANTED, PROFESSIONAL LURKER. MUST HAVE OVER 150 POSTS. ENQUIRE WITHIN. WE ARE AN EQUAL OPPORTUNITITY EMPLOYER. WE DO NOT DISCRIMINATE BASED ON HEIGHT...OR LEG LENGTH IN RELATION TO SAID HEIGHT. Quote
Marauder Posted January 23, 2014 Report Posted January 23, 2014 HELP WANTED: WANTED, PROFESSIONAL LURKER. MUST HAVE OVER 150 POSTS. ENQUIRE WITHIN. WE ARE AN EQUAL OPPORTUNITITY EMPLOYER. WE DO NOT DISCRIMINATE BASED ON HEIGHT...OR LEG LENGTH IN RELATION TO SAID HEIGHT. Ah Scott, you forgot one important detail (as did I); how FAT is the "Fat short guy"? Along with the torso/leg dimension, there is the "fatness" factor. Worst combination is short legs, long torso and a really fat belly. In this case, you can't reach the pedals, nor can you reach the yoke! Maybe we need a height versus BMI calculator to make the most accurate determination that certain short, fat guys with short legs and long torsos should be in a Bonanza. The above characterization is not pertinent or applicable to the other category of Mooney Pilots; i.e. "Fat tall pilots" These pilots are the ones who have short legs, long torsos and fat bodies. Those pilots cannot reach the pedals, nor the yoke but routinely bang their head on the ceiling. Sent using Tapatalk Quote
Marauder Posted January 23, 2014 Report Posted January 23, 2014 I should know... I was one of them. Quote
flyboy0681 Posted January 23, 2014 Report Posted January 23, 2014 Ah Scott, you forgot one important detail (as did I); how FAT is the "Fat short guy"? Along with the torso/leg dimension, there is the "fatness" factor. Worst combination is short legs, long torso and a really fat belly. In this case, you can't reach the pedals, nor can you reach the yoke! Maybe we need a height versus BMI calculator to make the most accurate determination that certain short, fat guys with short legs and losing torsos should be in a Bonanza. The above characterization is not pertinent or applicable to the other category of Mooney Pilots; i.e. "Fat tall pilots" These pilots are the ones who have short legs, long torsos and fat bodies. Those pilots cannot reach the pedals, nor the yoke but routinely bang their head on the ceiling. Sent using Tapatalk Well, at least that's one thing I don't have to worry about. Although I'm small at five-four, I weigh 135 pounds and my BMI is well within the envelope. Quote
co2bruce Posted January 23, 2014 Report Posted January 23, 2014 What does this have to do with sleep apnea?? Quote
AndyFromCB Posted January 23, 2014 Report Posted January 23, 2014 Get a Bonanza. Better yet, get an Ercoupe, no rudder pedals to worry about but do, please, get something, otherwise you'll get hemoroids from straining for so long 4 Quote
Marauder Posted January 23, 2014 Report Posted January 23, 2014 See... Mooney pilots come in all sizes: Quote
sreid Posted January 23, 2014 Report Posted January 23, 2014 HELP WANTED: WANTED, PROFESSIONAL LURKER. MUST HAVE OVER 150 POSTS. ENQUIRE WITHIN. WE ARE AN EQUAL OPPORTUNITITY EMPLOYER. WE DO NOT DISCRIMINATE BASED ON HEIGHT...OR LEG LENGTH IN RELATION TO SAID HEIGHT. Wanted: Keyboard without caps lock stuck. haha 1 Quote
EDNR-Cruiser Posted January 23, 2014 Report Posted January 23, 2014 See... Mooney pilots come in all sizes: Mooney Get Together.jpg Yepp!!! Mooney M20: One size fits all... Quote
aviatoreb Posted January 23, 2014 Report Posted January 23, 2014 See... Mooney pilots come in all sizes: Mooney Get Together.jpg Whose the guy with those great pants?!!! Quote
co2bruce Posted January 24, 2014 Report Posted January 24, 2014 Well you still havn't told is where your located. Guess your not that interested. 1 Quote
Shadrach Posted January 24, 2014 Report Posted January 24, 2014 My Dad is 5'6' (more like 5'5" now) with a 29" inseam and has owned 3 Mooneys (C, E and F)...none of which had peddle extensions. Dad's a bit rounder at 75 then he was at 45 (160lbsish) but never had trouble with the peddles. He does fly with the seat in the forward position. I am 5'11 (on a good day) and I fly in second from full aft position. Both of those seat positions put you close to the panel. So it all boils down to inseam... If I were to crash wearing only the lap belt, my face would likely not hit the yoke because it would be in the dash/panel... I can position the seat so that I can fly straight legged or straight armed, but not both... Quote
AndyFromCB Posted January 25, 2014 Report Posted January 25, 2014 Well you still havn't told is where your located. Guess your not that interested. Mom's basement? Would be my guess ;-) I'd need rudder pedal at 12 too. 2 Quote
Rwsavory Posted January 25, 2014 Report Posted January 25, 2014 Ok Boys, let's be nice. OP is a newly minted private pilot. Bless his heart. Quote
Hank Posted January 25, 2014 Report Posted January 25, 2014 We all had fresh PPLs at one point. If he'll tell us where he is, arranging a test-fit will be easy. Then he will know what he needs. Quote
