Dave I kinda got screwed at annual last yr I had the bendix king aoa installed at a MSC and they learned on my plane I guess..had about 16-20 hrs including the flight tests...learned a hard lesson..
The Bendix King AOA is much more significant to install,  The CYA is uniquely simple to install since it only has two wires from the probe to the plane and only the indicator to install in the panel (I believe all the others use pitot tubes from the wing to the plane, a box in the plane, and the indicator).
