Need INPUT...ASAP on battery replacement recommendations!
The shop working on my Rocket is saying that I need 2 new batteries (in the tail section & hard to get to) the current batteries were installed in 7/2010.  I never had any problems with the batteries but they are reporting that after charging they won't start the engine....  They have quoted 2 each G-35 batteries and my cost is $245.94 each with acid.  (don't know if that includes labor but if it is like the other items I doubt it...).   They have also asked if I would be interested in the Concord sealed batteries!
What say you?  Need input ASAP so I can give them an answer!
Thanks in advance,
Lacee
Those gills are 209$ each from spruce, but they leak and go bad in two years. The Concorde RG-35 or rg-35 AXC with more capacity is what u want, sealed batteries and last 7 years. We got one last year.
If your cg is near the forward limit get the AXC if its approved for the M20K
+3 On the Concorde series. I am in year 9 of my Concorde RG-35AXC ownership. The one before it lasted 7 years and I replaced it because I thought it was in there too long...
Concorde is the best on the market currently... Gill has been building a lot of bad batteries over the last few years according to everything I've read on various forums and lists.
I have to replace my Gill G35 as well and like the the idea of installing a sealed battery, but it seems the Concord AXC is 5lbs heavier.  Does Concord have a STC for the AXC?
Yes, and you'll need to update the W&B for it.  The non-AXC version is only a pound or two heavier.
I replaced my Concord AXC when it was almost 8 years old.  It would still crank the plane, but was starting to slow down a little.
I put in my current sealed Concorde in 2008. So far, so good. I had serious cranking troubles and rebuilt the carb and the SOS system last fall, so I no longer crank and crank and crank. Still a good battery. There are two available, I bought the one with higher cranking amps. Sorry, don't remember the model. It was $250+.
After your new Concord's are installed, don't forget your new "Sky-Tec" Flyweight starter.
Those blades will now be nothing but a blur on start-up.
No more anxiety on hot starts with that combination.
You will not go wrong with the Concorde.  I replaced mine after 5 years of service and now it is used to start my home generator.  This way I can keep an eye on it with a battery minder more often than in the hangar.
BILL
I bought a G-35 and it lasted almost 4 years however it puked acid out in my battery box on a VERY regular basis and I followed the instructions to the letter on putting in the acid. No more Gills I have Concorde sealed in the O and yes they are more to replace but ya wanna buy batteries AND battery boxes? or just buy a good battery?
Does anyone have a weight and balance program they use to recalculate weigths and print for the POH???  I installed the heavier concorde over the weekend and want to update the weight and balance to reflect the 5 lbs xtra
weight x arm = moment
total moment / total weight = CG
You need to be an A&P or better to update the W&B.
