Did you mean one piece windshield or 201 style?
The old M20C windshield is vertical and is missing the aerodynamics of the more sloped 201.
There is a one piece improvement that makes looking out/at better, not too expensive.
Or did I miss the point?
The one piece is a cheap option , it takes out the huge vertical center piece from the middle , and improves forward visibility , improved safety from better visibility , Although the old design is not as sloped , it is far from "Vertical" , The benefit from the slope is negated by the increased drag , more surface area equals more drag..... It looks cool , but you lose most of the access to the instruments and avionics.....The Beech owners groups did tests on the beech speed slope windshields and no increase in speed ..... But they look great...... I had a B model I did like 8 speed mods to , and netted about 8 MPH , 4 or five were from the cowl closure, and in hind sight , It would have been the only one wort doing....
  On 9/12/2012 at 3:07 AM, carusoam said:
V tail vs traditional tail friction...hmmmmm?
Sorry missed your point..
Frictional characteristics of plexiglas....?
V tail is faster because there is less surface area in the two tail surfaces verses the three surfaces , There is substantially more surface area to a 201 type windshield than a 20C type windshield , hence more more surface area = More parasitic drag.....
OTOH, there's less surface area in the fuselage. And surface area is far from the only factor in determining drag. The plexiglass is probably smoother as well, thus less drag per unit of surface area. And certainly the shape plays a role.
I have heard claims the V-tail is faster than an identically-equipped F33. Beech always claimed 2 MPH but by 1980, Beech finally published the same cruise numbers for both. The V-tail has two surfaces instead of 3, but the two surfaces are correspondingly larger and the drag is the same.
I am sticking with the 3 MPH claim on the 201 windshield and the dramatic appearance and resale factor.
Don't forget the improved visibility from inside the cockpit, since the 201 windshield goes several inches further up at the top. Lots of sheetmetal work to be done.
All I know is that my S35 cruises at 165 knots indicated 2500 msl at 16gph and carries 1270 useful load....My friends A36 with 15 more HP burns 17 and indicates about 155 knots 2500 msl , My Mooney "E" indicates about 135 Knots 2500 MSL and burns a little more than 10 gph...
Generally outspeaking...
I'm going with Mooneys are faster.
Big engines are better.
New planes have more capable instrument panels. (except a few modified to better than new)
New Mooneys with big engines, turbochargers and matching E-trade account, are the best. I'd get a talking baby too.
Who claimed they paid for their Mooney with proceeds from stock options?
I want to talk to you!
In case you can't tell, this is in jest. Excluding that last point...send me a PM.
I am happy with the move from M20C to M20R. I had the one piece windshield, not 201. I liked the access behind the panel as well.
The best mod in this regard, is an electric OAT gage, not through the windshield OEM type. It is accurate, easy to read, does not promote cracking, doesn't vibrate like crazy.
M20TN can stay on my wish list.
Best regards just stirring the pot,
Right, but an apples-to-apples comparison is F33 to V35. The A36 is longer, heavier, and more drag.
Wow... Is that true?
Not knowing much about beeches...
I didn't expect to be schooled on the finer points of Beechcraft ownership at MooneySpace.
I feel better now.
ROP or LOP, MY Mooney is faster and burns less at the same time, making it economical enough for me.
Don't get me wrong, I like the Beech, but not it's economics, V-Tail or not.
Thanks?
Wow, you have a really slow E model if that is all your getting. What MP and RPM were you running? If I'm running 25 squared, I usually see 150 KIAS at that altitude. I usually get 139 KIAS up in the 8-10K range.
I easily picked up an extra 3-5 mph with my 201 windshield. Yes, it makes a difference.
...may sound fast but that is normal ops for my bird. Some have questioned my airspeed indicator being out of calibration, but it was certified in 2010 and was spot on. Did the GPS runs to verify it as well.
Heading towards Higginsville, MO on a very cold winter morning at 3.5K (3248F was before I changed the tail number): http://www.67m20e.co...IG/IMG_6896.JPG
Coming back from Denver at 11K: http://www.67m20e.co...LY/IMG_0931.JPG
Coming back from Chicago at 6K: http://www.67m20e.co...PA/P7250124.JPG
Those are all from the same aircraft, just in different phases of the panel make-over... :)
We can all cherry-pick data to support any air/ground speed that we want. I have photos showing my C making 183 knots over the ground headed south to Charlotte once; when I was topping the hills between Greenville and Knoxville at 10K indicating roughly the same airspeed but groundspeed bottomed out at 68 knots, I did not take any pictures.
Normal everday flights are better used for discussion. I went 1300+ nm west at an average of 127 knots, and returned at an average of 151 knots, including takeoffs, climbs, descents and landings. Don't ask me what my indicated speed was, or the groundspeed during cruise, I was too busy sightseeing and vacationing for three days in each direction.
I typically indicate 125-130 knots at 6-9K, and groundspeed is whatever the wind makes it. Book values are 160-165 mph for my plane, so I'm happy. The guppy mouth closure and 201-windshield both help; I've been told the 3-blade on the nose hurts. Either way, I get where I'm going, I can see out the front, and my OAT sensor is not in the way.
I didn't cherry pick those just because, I picked them to show my indicated airspeeds, which he inferred were higher than they should have been for an E. I made no mention of groundspeeds in my post and fully understand block speeds.
Guess I should have looked at the pictures, I responded inappropriately.
Your yellow is pretty low--mine starts at 175 MPH, and even on normal descents I rarely indicate 170. Just some of the joys of having so many models.
Typical 3000 msl, 23/2300, I'll indicate ~130 MPH.
  • 5 years later...
i have to agree. i have flown several mooneys for test flights and delivery and I flew a 70s f model with every mod done. my 67 f flew the same with no mods. over all speed difference was negligible. not worth all the money spent and the guys that worked on them just laugh at the moneys spent. if i want to go faster Ill get another plane. I love my mooney but if adding $10k gets me 6 knots ill buy a faster plane instead.
Expand
Not so much for those of us who prefer the original appearance of the airplane.
  On 4/10/2018 at 2:41 PM, David Herman said:
Alan,
Me thinks that analogy is flawed sir ...
That larger surface area of the 201 Windshield creates a more aerodynamic angle ... or shape of the fuselage... and less parasitic drag ...
correct?
I would counter that analogy with one from the progression of automobile shape and design. The older cars had smaller windshields with steeper slopes and sunken headlights that were completely non aerodynamic ... while the newer designs have larger windshields with less slope ... and the headlights are now integrated into the shape of the vehicle. Go no further than looking at the differences in the same items from the M20F to the M20J ... and ask yourself which has more parasitic drag ...???  (the differences in gear doors are another consideration of the same thought.)
Expand
The minimum surface area shape is a sphere, so if that were the driving consideration we'd be flying around in beach balls with wings.   Fluid dynamics is pretty complicated and somewhat non-linear, so many simplifying assumptions are risky.    I think the 201 windscreen likely reduces drag overall, despite having a bit more area.
  • 3 years later...
Just read this thread and didn’t found an answer to an original question: what is involved in installing a one piece windshield. Anyone?
Alan, I couldn't agree more!   I think of how much time it takes to do any behind the panel work with that stupid 201 windshield in place  vs the 20 seconds you might/might not have gained from from "A to B" flying.  Like give me the 201 VAX - F'n go figure?!
Michael Angelo sculpted "David" Are you like wise "in the mood"?
If you have no talent with forming metal, wood, etc. " fo' get about it."
The stock windshield is 3/16" ( i think I remember) the one piece is thicker - at least what I installed .. these airplanes are built to a very close tolerance.  To fit the new windshield into the airframe requires a lot trial and ( no error) fitting.  If you can imagine putting the windshield in place .. marking, trimming, replacing, marking, trimming, re fitting a dozen or so times then maybe you can get an idea of what's involved.
Also, I dimpled the cabin roof alumn. and counter sunk the plastic because I just couldn't get enough...
Research the sealant.  I wouldn't "glue" the windshield in place.  And No, I won't tell you what I used, because ...
I hope this delves into the "what's involved" question.
Edited by mike20papa
Expand
There is a question asked near the top….
Which one piece windshield?
1) There is a one piece that improves vision by removing the center connection… and changes nothing else…
2) There is the improved version… 201 style that changes a lot of sheet metal… and improves many things….
The low cost option requires taking off a trim piece at the bottom and fitting in a new windshield… replacing the trim piece is probably necessary… paint to match
Going with a thicker windshield… adds to the fitting challenges… where time is money…
What objective are you going after?
Improving a forever-plane?
or, My windshield is totally scratched, can’t see through it when the sun shines in….  Lowest cost replacement?
Expand
Thank you, Antony!
My reasons: looks and fix water leaks. Also I am going to repaint an airplane soon so color to match is not a problem
