Endre Holen Posted September 28 Report Posted September 28 Hi there. We are doing an avionics upgrade. Does anyone have the outline of the left and right panel in a CAD file? If not we will trace it and input it but would help with a starter file.
PeteMc Posted September 28 Report Posted September 28 Are you going to cut it yourself or work with a shop that does this all the time. If you're going with a shop, check with them. They may have a program for you to lay out the panel the way you want it.
00-Negative Posted September 28 Report Posted September 28 Cad file pilot side: and copilot side from the downloads section. https://mooneyspace.com/files/file/149-m20e-pilot-paneldxf/?do=download&csrfKey=67d1bf7a3a9c4170adef0972346b91a6 https://mooneyspace.com/files/file/148-m20e-copilot-paneldxf/?do=download&csrfKey=67d1bf7a3a9c4170adef0972346b91a6
