2 hours ago, Fly Boomer said:
Unlike the Rocket, there is no legal amount of lead or batteries in the tail that will fix those numbers.
Actually there are bigger problems:
  • It appears that the 180 HP Austro 330 weighs about the same as the Rocket 305 HP TSIO-520
  • Installing the Austro in a M20E actually derates it at sea level from the original 200 HP Lycoming
  • As you point out batteries and more lead will be needed in the tail to keep the M20E off its nose with the additional 250-300 lbs on the nose.
  • UL will drop to about 500 lbs...maybe less
Maybe a fairer comparison would be the Continental CD-300 used in the Diamond DA-50RG.
  • It has a dry weight of 560 lbs...probably closer to 600 lbs installed.
s&g if was was retired with a bunch of money i'd maybe try and start with a chevy LZ0,  inline 6, should be alot smoother naturally  plus it's a bit closer in weight.  my poor little e would get places before it left
That thing weighs 467 lbs. You will need two M20Es to haul that thing around.
  • Haha 2
shrug i never haul around more than 2 people anyway
One thing to consider with the auto engines; their crankshafts may not be strong enough to handle the torsional stress of driving a propellor. Home builders found that out when they put Corvair engines in their planes.
4 hours ago, N201MKTurbo said:
It does make 16 HP more than your IO-360. Not world changing.
actually that's rwhp in the charts, so crank would probably be 10 to 20 percent more
Edited by McMooney
There’s a nice series of articles in Air Facts Journal about a Chevy V-8 installed in a Skyhawk. I think this has been referenced on MS before … well worth an entertaining read.
https://airfactsjournal.com/2020/11/the-20-an-hour-cessna-172-experiment/
tech wise this can be done but due to economics IT NEVER WILL BE, except for the random barely engineered experimental.
Now back to when will i be able to light 100R on fire in my mooney
Interesting article, but if this were truly viable there are a few glaring issues.
That article was from 5 years ago and had numerous claims but no facts showing any of it was actually accomplished.
Most significant is the statement, “certification cost requires outside investor funding and we have not found the right partner yet.”  The obvious question is why didn’t we see this airplane at OSH in 2022?  Or 2023, 24, or 25?  The buzz would have been tremendous and certainly the “right partner” and outside investors would have been lined up ready to invest.  Instead… crickets.  The only answer is that putting a V-8 in a C-172 just wasn’t a viable solution (probably because the weight and balance just wouldn’t work.)
Everyone loves to malign our 80 year old engine technology, but the fact remains if there was something significantly better it would have been developed and improved upon a long time ago.
Our engines are optimized to produce 65-90% rated power reliably for 2000 hours. For their weight, nothing else even comes close. Any improvements to be seen (such as variable timing or better exhaust) produce only a few percentage points difference. Significant improvements simply haven’t panned out. So it isn’t government regulations or a corporate conspiracy, but instead physics, engineering, and financial sense that prevent significant changes to our engines.
THAT paragraph is gold!
Aircraft engines are stationary; all the fancy electronics just don't increase performance significantly as variable timing isn't really required. The rest of the engine isn't in much need of improvement as it already has excellent power to weight ratio, and proven reliability.
That was the first of the three articles.
https://airfactsjournal.com/2022/10/the-20-hour-cessna-172-experiment-update/
https://airfactsjournal.com/2024/11/the-corsair-c172-v8-experiment-update-3-readers-suggestions/
Plus they are NOT designed for continuous operation at 75% of peak power.   They run at highway speeds at about 10 - 15% of peak power.
On 9/19/2025 at 6:27 PM, Shadrach said:
Yes, government mandated innovation is the key to success…thank God they made horses illegal in the early 1900s or the automobile would’ve never been invented and city streets would still be full of horseshit.
Yeap.  Necessity may be the mother of invention, but the Father is invention is LAZINESS.
Cars are faster and less upkeep.
Most auto engines would overheat in short order if they were making 60% power for any length of time.
most folks with a 400 HP vehicle, have probably never made 400 Hp with it. If they did, it was for a few seconds at best. To get 100% power out of a vehicle requires red line RPM at WOT at sea level. How do you do that? Towing a heavy trailer up a steep hill at the coast in first gear? How long would it last doing that?
Still comparing apples to pretzels,
in the example of a 5.0l engines, io360 and that dog of a ford mentioned earlier
io-360-a1a  -- 5l engine -- RATED at 200hp@2700rpm and most likely limited by prop i believe the helicopte version is rated higher
dogford -- 4.8l engine -- RATED at 400+hp@5000rpm  --  i don't know what rpm just an example
the rating is a point on set by the manufacturer which is different between the applications.
i believe a better comparison is how long can they both put out 200hp, or how long can they both put out 75%, 65%
WOT is rarely even the 100% rating in the airplane unless you're flying on a cold day @ sea level and 59ish deg
On 9/19/2025 at 2:14 AM, hazek said:
Just extremely disappointed with bullshit. You Americans have no idea how much worse it is here in Europe for light GA. I’m seriously questioning whether or not my plane will be able to fly after the AVGAS extension until 2032 passes. I lost all motivation to put any upgrades into my plane or do any facelifting and it desperately needs both. And it’s all because of this bullshit.
I mean look at what SpaceX accomplished in just 4 years at Starbase, and we can’t get a reliable high powered engine running on less than some prehistoric fuel?? While there are Billions of cars on the road? Laughable. Well it would be if it wasn’t so sad.
To give credit where credit is due, Europeans have made GA expensive, and mostly unaccessible, due to the policies they voted for. Rally your countrymen to fix it, rather than blaming the FAA (which is like a European bureaucracy) for the slow fuel transition process.
We've managed to keep fuel prices reasonable, airports open and accessible, and overall operational costs manageable through constant political action. We do know how bad it is on the other side of the Atlantic, and we know how it got that way. It's what drives us to maintain our freedom to fly.
2 hours ago, Pinecone said:
Exactly.   Look at race car engines.  They on run WOT for maybe 60% of the time.  A bit more in F1.
There are lots of counter examples, like Indy, or the Silver State Classic, where they're pretty much WOT all the time.   Penske's famous "beast" Indy motor was optimized for a very narrow range of rpm where it made power, because they knew that's where it'd be nearly all the time.   There are a fair number of oval tracks, both paved and dirt, where you spend most of the time at WOT.   Consumer-based cars gets raced on those all the time, too, for all kinds of crazy classes from skid plates to derbies.
As long as there is sufficient cooling most stock street car engines have no trouble running WOT for very long, even indefinite, periods.    They start to get fragile, or at least more fragile, when they're tuned/modified past stock and start increasing the stress on components and reducing or eliminating design margin.
Normally aspirated cars are seldom a problem racing stock motors.   Turbocharged cars seem to have a lot less design margin, especially in cooling capacity.
I’ve spent a fair amount of time driving on highways that either have no speed limit or speed limits that were not enforced (Italy before speed cameras). I don’t think most modern cars would overheat at 60% power.  Back in the 90s I drove my 15 year-old Mercedes 190E 2.3 from the West Coast to the East Coast. I was young and stupid and elected to set the cruise control at 117mph on highway 90 as I passed through through Montana. I did have to slow down occasionally, but the car would run flat out for extended periods without protest. That s about as was fast as it would go on 130hp. The needle on the coolant temp stayed right at 85C where it always did.  Driving that fast for that long gave me a pretty severe case of velocitation.  This resulted in a painfully expensive interaction with the Highway Patrol shortly after entering Wyoming
Even the vintage Jags that I have flogged have had far more trouble keeping cool in traffic than at high speed.
so as a youngster i remember seeing a presentation on gm engine durability testing.  I can't find the video online anymore but here's AI's abstract of what they do.  this is only a portion of the things i remember them doing, wish i could find the original video
