Hi all I’m currently working on my interior, I have a 66E model. Most of the interior was out and lots missing, I have an upholstery shop doing the seats right now, I ordered carpet from Airtex. 2 questions,
1. Does carpet go between the seats where it’s Johnson bar goes?
2 what goes on the vertical wall in front of the rear seat? Anyone have pics?
There is usually carpet between the seats. Just make sure it doesn’t move or interfere with the Johnson bar.
The front of the back seat usually gets carpet glued to cardboard or sheet metal.
Just had AIRTEX carpet installed in my 67 F.  Could have spent more time fitting up the carpet between the seats.  The previous carpet tucked under the plastic.  Careful trimming the side panels to fit; those things are aggravating to install; we ended up with a gap in the back corner as you can see but once the seats are in you don't see it.  The panel below the back seats was attached with velcro; hopefully it stays stuck.  Your AIRTEX side panels  should come mounted to a backing board.
36 minutes ago, DCarlton said:
Just had AIRTEX carpet installed in my 67 F.  Could have spent more time fitting up the carpet between the seats.  The previous carpet tucked under the plastic.  Careful trimming the side panels to fit; those things are aggravating to install; we ended up with a gap in the back corner as you can see but once the seats are in you don't see it.  The panel below the back seats was attached with velcro; hopefully it stays stuck.  Your AIRTEX carpet should come mounted to a backing board.
Thanks for the pics and reply, my kit didn’t come with the center section or the rear vertical panel. I have ordered the side panels, waiting on them to be shipped.
what did you use to cut out the fuel selector?
Exacto knife.  Large pair of upholstery scissors.  A needle with a T on the dull end (for pushing hard) to locate existing holes.  All comes in handy.  Maybe the rear panel comes with the side panels?  Don’t remember for sure.  Seems like I remember a plastic panel at vantage plane plastics that may be for your center floor.
Years ago I received the carpet from Airtex for the Johnson bar area but my plane had a plastic in that area. you can order one here:
https://vantageassoc.com/mooney-m20-k740054-503-407.html
As for the wall under the seat: I seem to remember that piece of carpet came with the side kit from Airtex.
You sure you want the dime floor?
 Flown in a lot of working planes with that, not exactly sexy and I just mentally smell dirt and old coffee spills when I see it lol
 talk to the folks at Wipaire floats, they had access to a few different carpet substitutes they use in floatplanes that work great for dirt and water but and look much better
I removed the galley from my Mooney so no smell!
  • Haha 2
