Bartman Posted January 28, 2025 Report Posted January 28, 2025 After nearly 20 years of ownership I had my first flat over 5 hours from home and no service available this past Saturday. I have always used Goodyear Flight Special II with Michelin Leak Stop tubes and know to check and add air periodically, especially when the temperature drops. On landing, it was apparent that I had a flat, and I knew not to try to "make it" to the intersection and taxiway. The line guys brought a specially designed tire dolly, but with the gear doors, it requires jacking the plane to position it correctly. One of the line guys had a strong back, so the two of us used our backs to lift her from under the wing........ Yes, I tipped the line guys very well. I can change the tire this weekend after I drive 5.5 hours back to where she sits on the ramp, and I'll have to bring any tools back with me in the plane, so a wing jack may not be the best option. I know I can use a bar and floor jack, but my question is, what kind of bar? A previous thread suggested using the tow bar, but mine is not solid, which does not sound like a good idea. I want to be prepared when I get there and have everything needed. What size bar and what kind of material should I get, and where can I find it ? I don't want to buy something that will bend and not lift the plane.
warren.huisman Posted January 28, 2025 Report Posted January 28, 2025 Where is it? Perhaps there is a MS’er on here who is near the airplane who could lend you a proper jack?Sent from my iPhone using Tapatalk
00-Negative Posted January 29, 2025 Report Posted January 29, 2025 A friend of mine had a blow-out after landing his M20J in Dauphin Island a few months ago. He rented a car and brought the entire wheel home where A&P fixed it. I flew the 2 of us, the repaired wheel, a few tools, and an Alpha Aviation low wing jack in my M20E no problem. -David
47U Posted January 29, 2025 Report Posted January 29, 2025 1 hour ago, Bartman said: I know I can use a bar and floor jack, but my question is, what kind of bar? I’ve stuck a 1” black pipe in the tube and used an automotive (Mazda) scissors jack (with some dunnage) to lift the main gear high enough to get my too-tall wing jack underneath the jack point. That was in a hangar, though. I don’t know about doing it outside on open ramp. It was a hinky operation though, so I modified my homemade jacks short enough they’ll fit under the wing without jacking the main gear. How hard is it to remove the inner gear door? If you can take that off, since the brake caliper has to come off anyway, that scissors jack will also fit under the axle next to the brake disk. (I don’t think the caliper torque plate will be in the way, but you should check before driving 5.5 hrs.) It’s a much better solution because gear donuts stay compressed thereby reducing the amount of lift required to get the tire off the ground. Scissors jacks are on Amazon for < $50. There’s one rated at 1.5T for < $25. 1
IvanP Posted January 29, 2025 Report Posted January 29, 2025 I used 1" dia steel bar through the hole in the gear truss, scissor jack from my old car that was high enough to lift the wheel and change tire and a jack stand for added security in similar situation. 3
Bartman Posted January 29, 2025 Author Report Posted January 29, 2025 18 minutes ago, IvanP said: I used 1" dia steel bar through the hole in the gear truss, scissor jack from my old car that was high enough to lift the wheel and change tire and a jack stand for added security in similar situation. That's what I needed to know. I can get a 1" diameter cold rolled rod at Tractor Supply, and I have a jack, blocks, and jack stand. I should be good to go. Thank you !
EricJ Posted January 29, 2025 Report Posted January 29, 2025 3 hours ago, Bartman said: That's what I needed to know. I can get a 1" diameter cold rolled rod at Tractor Supply, and I have a jack, blocks, and jack stand. I should be good to go. Thank you ! I jacked up a C model with a 1" pipe, and the pipe flexed enough that we could barely get my wing jack in to lift it sufficiently to change the tire. A solid rod should work better. On the C model we couldn't get the tire quite off the ground with a pipe and a floor jack.
IvanP Posted January 29, 2025 Report Posted January 29, 2025 Solid rod is definitely a better choice here. I did this on a Bravo that is heavier than C and did not have much flex in the rod. 1
MikeOH Posted January 29, 2025 Report Posted January 29, 2025 1 hour ago, IvanP said: Solid rod is definitely a better choice here. I did this on a Bravo that is heavier than C and did not have much flex in the rod. Sure, I guess. It just seems that if two guys can lift one wing up with their backs even a 1" steel hollow pipe should be plenty strong enough.
Hank Posted January 29, 2025 Report Posted January 29, 2025 5 hours ago, MikeOH said: Sure, I guess. It just seems that if two guys can lift one wing up with their backs even a 1" steel hollow pipe should be plenty strong enough. Depends on what you call "pipe." Galvanized pipe, maybe; black gas pipe, probably; electrical conduit, definitely not.
EricJ Posted January 29, 2025 Report Posted January 29, 2025 4 hours ago, Hank said: Depends on what you call "pipe." Galvanized pipe, maybe; black gas pipe, probably; electrical conduit, definitely not. This is the stuff that flexed. 1" galvanized. I was surprised. Part of the problem is that it is difficult to get a floor jack close enough to the MLG leg that there isn't a fair amount of lever arm on the pipe. Regardless, a solid rod should be better.
philiplane Posted January 29, 2025 Report Posted January 29, 2025 https://aviationvibes.com/shop/jack-pad-adapter-for-cirrus-sr20-and-sr22/ I use these on Cirrus and other planes that have a hollow in the axle 1
PT20J Posted January 29, 2025 Report Posted January 29, 2025 46 minutes ago, philiplane said: https://aviationvibes.com/shop/jack-pad-adapter-for-cirrus-sr20-and-sr22/ I use these on Cirrus and other planes that have a hollow in the axle I had a tool welded at a local shop that is very similar except that instead of a pad, I had a short piece of metal tube welded to the solid rod. The tube fits over a the top of a bottle jack just to stabilize it and the bottle jack lifts the solid rod. I use this when I only want to raise the nose wheel. I haven't tried it on the mains but it should work.
PT20J Posted January 29, 2025 Report Posted January 29, 2025 In a pinch, you can remove the threaded pad from the top of a bottle jack which leaves a hole in the top of the piston that will fit over the conical jack point. You will need some timbers to raise the bottle jack to the appropriate height. If you are on level, solid ground it's actually very stable since you are only lifting one wheel and the other two wheels provide stability. 3
Yetti Posted January 29, 2025 Report Posted January 29, 2025 take some cribbing also. 2x4 and 4x4 cut to 12" 16" Jack and inch crib and inch Also can be used to raise the jack.
Paul Thomas Posted January 29, 2025 Report Posted January 29, 2025 I'm all for owner maintenance and doing thing on your own... but I'd want to do a gear swing after replacing a tire and removal/re-install of the lower gear door.
Bartman Posted February 2, 2025 Author Report Posted February 2, 2025 On 1/29/2025 at 12:53 PM, Yetti said: take some cribbing also. 2x4 and 4x4 cut to 12" 16" Jack and inch crib and inch Also can be used to raise the jack. This is precisely what I did. After removing the inner gear doors, that space was perfect to slide a couple of 2x6 for a base and add 2x4 as I jacked it up and provided a solid base while I changed the tire and tube. The 1" solid bar worked great, and based on the amount of flex seen, I would not trust anything hollow. As an owner/operator, I can perform everything required for this repair and then fly home without engaging an A+P. I can remove, install, and repair landing gears and tires, service wheel bearings, and remove non-structural fairings. The POH recommends the removal of the inner gear doors if going into a grass field. Removing the inner doors does not require touching the outer gear doors, so a gear swing is unnecessary. We will swing the gear when we put the inner doors back on later. 3
Yetti Posted February 3, 2025 Report Posted February 3, 2025 On 1/29/2025 at 12:00 PM, Paul Thomas said: I'm all for owner maintenance and doing thing on your own... but I'd want to do a gear swing after replacing a tire and removal/re-install of the lower gear door. I would say the gear swing is part of changing a tire. So is removal and replace of the brake caliper to get the wheel off. Took me about 4 hours yesterday to do all three tires. Tires have doubled in price from 10 years ago. 2
Mooney-Shiner Posted February 4, 2025 Report Posted February 4, 2025 I know that OP already solved this issue, but for sake of posterity: I used black iron pipe 3/4x18" to lift by the truss. I've never seen it flex. https://www.lowes.com/pd/Southland-Pipe-3-4-in-x-1-1-2-ft-150-PSI-Black-Iron-Pipe/1000227953
Fly Boomer Posted February 7, 2025 Report Posted February 7, 2025 On 2/3/2025 at 3:07 PM, Yetti said: Tires have doubled in price from 10 years ago. This has nothing to do with airplane tires, but your comment made me wonder how often prices double in 10 years. Graph shows on various dates since 1977 (x-axis), how many years had passed (y-axis) since CPI doubled. So, as of 8/1/81, prices had doubled in just under 9 years -- big time inflation. Since then, the time to double has steadily risen until COVID. From a longer-term perspective, we have enjoyed decades of declining inflation. https://economistwritingeveryday.com/2024/04/19/the-time-it-took-for-price-to-rise/ 1
Yetti Posted February 7, 2025 Report Posted February 7, 2025 11/2014 1/2025 2-600-6 tire 152.00 251.90 1-500-5 tire 63.00 102.96 1-500 Tube 53.95 111.95 2-600 Tube 109.90 191.90 before taxes and shipping 228.41 658.71
