Mac201 Posted May 19, 2012 Report Posted May 19, 2012 Every 30 hrs. or six months with Phillips X/C and Avblend. The oil is getting pretty dark by 30 hours.
jetdriven Posted May 19, 2012 Report Posted May 19, 2012 The oil gets dark becuase the heat works on the additives. It does not necessarily mean that the oil is dirty, or bad.
jetdriven Posted May 19, 2012 Report Posted May 19, 2012 Quote: Dale I change my oil at 35 hours. This was recommended by my mechanic who felt that planes with a turbo should change the oil no later than 35 hours. I use Phillips with camguard, which was also recommended and I feel confident with that combination.
Mac201 Posted May 19, 2012 Report Posted May 19, 2012 I just started using Avblend in the last two oil changes, but my oil has always turned dark by 15- 20 hours. That seems quick to me. Is there something esle that I should be considering?
DaV8or Posted May 19, 2012 Report Posted May 19, 2012 Quote: Mac201 I just started using Avblend in the last two oil changes, but my oil has always turned dark by 15- 20 hours. That seems quick to me. Is there something esle that I should be considering?
jetdriven Posted May 19, 2012 Report Posted May 19, 2012 Yeah, skip the Avblend, and use Camguard or nothing at all. If the oil is going black quickly and you have low compression or high oil consumption, thats a sign of blowby contaminating the oil. Or it mght be those full rich climbs to 10K feet.
DaV8or Posted May 19, 2012 Report Posted May 19, 2012 Quote: jetdriven Is Camguard an approved additive for turbocharged aircraft?
The-sky-captain Posted May 21, 2012 Report Posted May 21, 2012 Before my engine OH I was changing it every 25 hours because it was getting nasty quick. It was a PITB due to the fact that I fly a lot and I was cracking the cowl every 6 weeks or so as I change the oil myself. Now that the engine doesnt burn much and the oil stays nice and clean I change it every 50 hours. Im actually headed out today to do it. It's been a little under 3 months since the last oil change so I guess the 3 month rule/ 50 hours is where I'm at. FYI for you do it yourselfer's try the New Pig Funnel for draining the filter and screen. Its a great form- a- funnel...
ATM Posted May 25, 2012 Report Posted May 25, 2012 How long does it take to change the oil on a M20C with screen filters?
Guest Posted May 25, 2012 Report Posted May 25, 2012 Takes me about a hour, drain oil, pull screen, clean and replace gasket.
carusoam Posted May 26, 2012 Report Posted May 26, 2012 ATM, Welcome aboard... Search this site for various funnel devices that will help you in this process... Best regards, -a-
Ned Gravel Posted May 26, 2012 Report Posted May 26, 2012 Quote: BluSky Takes me about a hour, drain oil, pull screen, clean and replace gasket.
