Can someone who uses FlyQ's EFB tell me how to open the Airport Facilities Directory? I know it is in there, but for the life of me, I cannot figure out how to get into it. When I update the data, I have the button pushed that says the AFD should be updated as well.
I was curious, so I just pulled down their manual.  I can find no reference to chart supplement, supplement, afd, a/fd, clearance, delivery or anything else that would be in the AFD.  The Airport section seemed get the most hits, but even that didn't seem to have everything.  At least from what I can tell with the manual.
Are you sure they have it?
The way I get to AFD is to type the Airport identifier in search field and select it to get a "general" info on the airport. There's 7 tabs on top to select and one is AF/D.
