DC_Brasil Posted September 28, 2024 Report Posted September 28, 2024 Hello everyone. My M20J has tarted a panel upgrade this week. I share the ownership with a friend and after much research and talking to the avionics shop we've decided (like most posts we've seen here) to go with the G3X family. We'll install: G3X 10 inch main display with full EIS G5 GFC500 with all 4 servos (pitch, roll, pitch trim and YD) GMA245R Audio box GSB-15 USB power outlet Unfortunately we didn't have enough cash to goo the full way and upgrade more stuff, so our navigator will remain the GNS430. If avionics are already expensive in the US, here in Brazil we still have to consider currency exchange and importing taxes. Perhaps in a year or so, I plan to add a GTN650, new ADSB transponder and LED NAV/Strobe/Landing lights. Consequently, we're removing all analog instruments, all current engine instruments, ADF (it had two ahahahah), DME, Audio Panel, KAP150 autopilot (controller, alt selector and annunciator). I have a few question for all you Garmin savvy out there. I've tried looking these up on the G3X user manual and even install manual without much luck. Some information is even a little ambiguous. 1 - Will our KX-155 Nav 2 send CDI data to the G3X or will I need to keep the backup NAV 2 CDI? 2 - Will I be able to change COMM 1 frequency (COMM1 is the GNS430) in the G3X screen? 3 - I know I can use Connext to send my flight plan from the iPad to the G3X, however, will it send it to the GNS430? I am attaching a pic of the panel as it was and after the first day of instrument removal. Have a great day! DC 1 Quote
PT20J Posted September 29, 2024 Report Posted September 29, 2024 I would post the question on Beechtalk. Several Garmin dealers hang out there. For sure Terry Markovich would know. I’m pretty sure the answer to 1 is no and 3 is yes. Not sure about 2, but I don’t think so. Quote
ArtVandelay Posted September 29, 2024 Report Posted September 29, 2024 I think 2 is no, I can’t change the GTN frequencies, but I can with 255.But that may be because I don’t the necessary connection, all my GTN RS232 ports are being used. Quote
toto Posted September 29, 2024 Report Posted September 29, 2024 On 9/28/2024 at 6:31 AM, DC_Brasil said: 1 - Will our KX-155 Nav 2 send CDI data to the G3X or will I need to keep the backup NAV 2 CDI? Hopefully one of the resident avionics experts will chime in, but my #2 navcom is a KX-155 and I had to keep the legacy indicator for it. Quote
ArtVandelay Posted September 29, 2024 Report Posted September 29, 2024 Hopefully one of the resident avionics experts will chime in, but my #2 navcom is a KX-155 and I had to keep the legacy indicator for it.If you want interoperability with other older equipment, you should get G500 TXi, the G3X I think only works with modern digital equipment. Quote
toto Posted September 29, 2024 Report Posted September 29, 2024 7 minutes ago, ArtVandelay said: If you want interoperability with other older equipment, you should get G500 TXi, the G3X I think only works with modern digital equipment. Definitely don’t want. I would rather spend the money on a new navcom than integrate an old King radio with a TXi. I’m very happy with a standalone KX-155 and a standalone indicator for my backup radio, and when it finally dies I’ll buy something new from Garmin Quote
DC_Brasil Posted October 2, 2024 Author Report Posted October 2, 2024 On 9/29/2024 at 8:07 PM, toto said: Definitely don’t want. I would rather spend the money on a new navcom than integrate an old King radio with a TXi. I’m very happy with a standalone KX-155 and a standalone indicator for my backup radio, and when it finally dies I’ll buy something new from Garmin That's the way we're moving. We'll probably keep an old VOR CDI for NAV2. Next year, after my pockets (hopefully) recover from - and my wife (hopefully) forgets about - this upgrade, I'll try to add a GNT650txi and my current GNS430 will be NAV2. So I'll be able to throw out the analog CDI. Quote
DC_Brasil Posted October 11, 2024 Author Report Posted October 11, 2024 Hello Everyone! Posting an update here about the evolution of the panel upgrade. All instruments removed and cabling being reworked Removal of old KAP150 servos A lot of work being done First fitting test for panel plate A lot of old cabling removed New Garmin AP servos installed (we've added YD as well) Avionics fitting test and fine tuning before painting It is a remarkable difference between the old panel and the new. Can't wait to fly it One question for all of you Garmin flyers out there: now we'll have the GMA-245R remote audio panel controllable within the G3X. If we have a G3X failure, what communications capabilities do we retain? Do we lose intercom? Comm 2? Cheers! 3 Quote
KSMooniac Posted October 11, 2024 Report Posted October 11, 2024 Did they actually remove a tailcone skin??? Sent from my motorola edge plus 2023 using Tapatalk Quote
ArtVandelay Posted October 11, 2024 Report Posted October 11, 2024 Did they actually remove a tailcone skin??? Sent from my motorola edge plus 2023 using TapatalkI think they dropped the 1 piece belly. Quote
kortopates Posted October 11, 2024 Report Posted October 11, 2024 I think they dropped the 1 piece belly.The one piece belly doesn’t go beyond the rear seats - not too avionics bay and battery area.Sent from my iPhone using Tapatalk Quote
DC_Brasil Posted October 11, 2024 Author Report Posted October 11, 2024 1 hour ago, KSMooniac said: Did they actually remove a tailcone skin??? Sent from my motorola edge plus 2023 using Tapatalk I am not sure as I didn't go to the shop. The mechanics sent me these pics. I think they only removed the tail inspection panels under the horizontal stabilizer. Quote
kortopates Posted October 12, 2024 Report Posted October 12, 2024 I am not sure as I didn't go to the shop. The mechanics sent me these pics. I think they only removed the tail inspection panels under the horizontal stabilizer.I think the question comes from the second picture where the light appears like it might be on the ground. But I think it’s an illusion created by the Avionics shelf and the light is actually in the belly, not on the ground.Sent from my iPhone using Tapatalk 4 Quote
KSMooniac Posted October 12, 2024 Report Posted October 12, 2024 I think you're correct, Paul. It sure looked like a hangar floor at first glance! Sent from my motorola edge plus 2023 using Tapatalk 1 Quote
DC_Brasil Posted November 7, 2024 Author Report Posted November 7, 2024 Almost ready! Went to the shop today. The idea was to review all installation and do a thorough runnup and a quick test flight with the mechanic to review the GFC500 autopilot. All avionics working but we had a malfunction with the voltage regulator. Having it checked the next couple of days and see if we can fly the plane Saturday morning. However, we got to spend some time playing with the new screen. The G3X is indeed a very nice piece of equipment. 3 Quote
Stanton R Posted November 8, 2024 Report Posted November 8, 2024 (edited) On 10/11/2024 at 8:04 AM, DC_Brasil said: I wish I had noticed this sooner but the rudder servo cable is wrapped around the servo incorrectly. The cable should be more parallel with the control rod (see attached). It's hard to tell but the elevator servo may be wrong also. I'm pretty sure if it wasn't changed that they would have had to program the yaw servo backwards to get it to work correctly. However it is kind of hard to check the Yaw servo for proper movement on the ground so it may be actually going the wrong way. Edited November 8, 2024 by Stanton R 1 Quote
DC_Brasil Posted November 8, 2024 Author Report Posted November 8, 2024 @Stanton R thanks for the heads-up. I will definitely talk to the mechanics about it. Wednesday I was there to test everything. Pitch, roll and trim controls worked on the ground. I didn't test the YD, but will do tomorrow morning. Do you have any suggestions on how to actually test if the YD is working correctly? I have never flown with YD. Quote
Stanton R Posted November 8, 2024 Report Posted November 8, 2024 If it is working correctly the ball will stay centered in the turns and high power climbs. If it is backwards you will get into a crab and turns will be super uncoordinated. 1 Quote
EricJ Posted November 8, 2024 Report Posted November 8, 2024 Good catch. At a minimum there appears to be an installation error that doesn't conform to the drawing. If it is functioning correctly it may have been reversed in software configuration. Quote
201Mooniac Posted November 9, 2024 Report Posted November 9, 2024 Actually if it is reversed, you will get a dutch roll behavior, very easy to notice and quite alarming. You won't notice it until flying and then just remember you can push the YD button to disable the yaw damper if that happens. Quote
Aerodon Posted November 9, 2024 Report Posted November 9, 2024 Always a good idea to know exactly which circuit breaker to pull if you get unexpected behaviour. I flew a C172 that had the aileron programmed the wrong way and it was interesting. Easy enough to change in the setup. Aerodon Quote
Aerodon Posted November 9, 2024 Report Posted November 9, 2024 And here's a thread with good installation pictures: 1 Quote
DC_Brasil Posted November 12, 2024 Author Report Posted November 12, 2024 @Stanton R thanks for the warning. The servos had indeed been rigged the wrong way and the YD behaved as expected: Dutch roll. However two other things were wrong during the test flight and the shop is assessing the issues: 1 - whenever engaged, the Autopilot commanded very aggressive right turns, even on ROLL lateral mode. 2 - the G3X tachometer is showing less than the real RPM. I guess this can be some incorrect config of the magneto type (Rated RPM is 2700 and the G3X is showing 2470). Having these checked today. 1 Quote
DC_Brasil Posted December 4, 2024 Author Report Posted December 4, 2024 Finally in the air! After solving some quirks after the upgrade, my J is finally flying. Just loving the new panel and especially the GFC500 autopilot. It reaaaaly makes things easier. Next steps for 2025 should be a new GPS, transponder and most likely CiES fuel senders. After a turbulence bump my R fuel sender stopped working (it was working fine in previous test flights). 3 Quote
