I’ve been working with Dan from Lasar, locating lenses for the Flap/Trim and Rudder in my Bravo.
They are probably the same on Ovations. 7116aa6aaadff8cf6e75abd674ead605.jpg
He can order new lenses from Mooney. (40 available of each)
About $100 each lens.
Contact him directly at daniel[mention=16215]lasar[/mention].com
daniel at lasar.com
10 hours ago, IvanP said:
What are the part numbers for these?
They will want a pic and your serial number.
For any airplane you own you want to have the Illustrated Parts Catalog (IPC) and the Maintenance Manual (MM). If you need those for your M20M private message me with your e-mail address.
The part number for your rudder trim lens is 880058-001
The part number for your trim/flap lens is 880060-001
I just had all of them replaced during Annual. Does not include 1.00 Hour labor to install.
880057-001  Cowl Flap Lens--$11.26
880058-001 Rudder Trim Lens--76.07
880060-001 Wing Flap/Elevator Trim Lens--65.36
What a difference!
I’ve got a call to Dan at Lasar.  I checked a few years ago and no go. But with more stock of other lenses, thought I’d circle back around.  Does anyone know if the multifunction kens for an Encore is available anywhere?
880089-003.
My guess is way fewer aircraft with this lens means less likely to find one. it’s a combo lens with indicators for flaps, cowl flaps, rudder trim and pitch trim.
EDIT:  s/w Dan and Mooney has a note by this part number (880089-003) that states no longer available per vendor.  So no go on the Encore multifunction lens.  I reached out to a few plastic vendors and could probably get one made if I had a drawing/dimensions/specs.  Mine isn't bad  enough at this point to hassle.
Edited by Marc_B
update with availability
Thank you. I have the IPC & MM but for some reason could not find the part numbers. User error on my part :). Need more coffee when searching IPC.
There are two panel layouts listed in the IPC. The serial numbers in the latter panel layout does not list the lens part number in the IPC, but it is the same as the earlier lens listed in the IPC
  • 2 weeks later...
Got the new lenses through Lasar (drop ship from Mooney). Now I need to find the time and energy to change them. Taking  the glareshield off is a pain in my plane and I am not looking forward to it.
