I had my non-waas 530 overhauled but it also wiped out all of the configurations. Now, it does not want to talk to my G5’s. I can get GPS on the G5 but not VLOC. Here’s the screenshots of the settings, any suggestions as to what could be wrong? I’ve naturally had my mechanic who did the install check it out and replicate the install settings but still no joy. Any suggestions what else to try?
My IFD 440 is set to GAMA 429 for OUT.
I believe there is another config page for the CDI/OBS config as well as the VOR/LOC/GS config. I would double check those values.
Edit: I believe VNAV ENABLED needs to be selected as well.
https://static.garmin.com/pumac/190-01112-10_19.pdf#page144
Section 5.12.3
Edited by dzeleski
Section 5.12.3
Mooneyspace to the rescue! Strange but the installer setup notes were totally different to the Garmin instructions. I did the settings now according to the Garmin instructions and voila! It started working! Thank You for the nudge in the right direction!
No problem, please do a VFR flight test for all modes to make sure it’s working correctly. Do a few different practice approaches, gps tracks, ILS, LPV, etc.
