tcal780 Posted February 28 Report Posted February 28 My son and I just started the journey of updating the panel on my 1970 C! I'm super excited to do this with him as he has been working for the last 18 months at my local airport as an apprentice to gain his A&P cert. We're both going to learn a lot. His boss, the local IA, has agreed to oversee, and sign off on the project. Going in: Dual G5's GNC255A GMA345 GI106A (backup-only for Nav2) JPI900 Cies fuel senders Aera 760 Going Out: Vac system Century HSI Intercom Original Engine gauges KI214 KX175B The KX165, the STEC30 and the GNX375 will stay. The pics will give you all an idea of where the panel was, where it's at, and where it's headed. This is the progress we made just this past weekend. Best, Tcal 9 Quote
tcal780 Posted March 9 Author Report Posted March 9 I finished 95% of the old panel cleanup. The remaining wiring seen in the photo will stay. A couple questions for the group: First, panel mounting. Are there "standard" mounting brackets and avionics rails available for a new panel like this or will I need to have them fabricated? The avionics guy said vibration isolators are not needed anymore, citing Garmin avionics often don't work well with them. Is this the case? Second, some advice on lighting. I am considering a combination of LED bezel ring lights for the 5 round instruments and an LED strip light on the underside of the glareshield for an overall flood. I'd also like to have the toggle switches or switch labels illuminated. The original throttle quadrant/flap labels and compass are also illuminated with incandescent bulbs. Can these be converted to LED? Ideally, I would like the avionics and the instrument ring lights to be on one dimmer and the remaining flood/panel lights to be on a second. What would you recommend? Thanks! Quote
PT20J Posted March 10 Report Posted March 10 I believe the GI 106A is has been replaced by the GI 106B. Are you purchasing a used GI 106A or did you find a new one on the shelf somewhere? Quote
Aerodon Posted March 10 Report Posted March 10 Some suggestions: MaxDim Duo for panel and glareshield lights. Nulites (incandescent work just fine, I think they make LED too but check that they are compatible with your dimmer) KI206 or 209 for the KX165 to save a bit of money. I think in the long run you will regret not doing 2 x GNC255's. MD93 clock / OAT / USB C etc. GI-275 engine gauge for space saving and symmetry. Small vertical stack of circuit breakers like later model Mooney's on a separate panel. It really helps to finish the power and grounds inn the airplane and have a quick connect like Mooney does on later models. Aerodon Quote
Aerodon Posted March 10 Report Posted March 10 Here's a rough start based on my M20K panel. I think your turn co-ordinator needs to be mounted vertically, or at least recalibrated for an 8 degree tilt to get a flat panel all the way across. Or you can try doing a vertical panel all the way across? I think a tilted panel will reduce the height of useable space in the radio stack because of interference? Aerodon M20C_R1.pdf Quote
tcal780 Posted March 10 Author Report Posted March 10 Thanks for the suggestions Don. I am planning to use the maxdim duo (or two single max dimmers). I prefer to not mix incandescent and LED, so I'm not sure what to do with the throttle quadrant lights. This is (was) a vertical panel but the existing brackets and vertical rack rails are not suitable for reuse. I'll will need a new plan for those. This will be a two piece panel with the breakers all on the far right. Tcal Quote
tcal780 Posted March 10 Author Report Posted March 10 22 hours ago, PT20J said: I believe the GI 106A is has been replaced by the GI 106B. Are you purchasing a used GI 106A or did you find a new one on the shelf somewhere? I purchased a used 106A. 1 Quote
tcal780 Posted August 31 Author Report Posted August 31 Agonizingly slow, but making progress! Question for those of you who are using the push to test LEDs from Lonestar for your gear warning lights... The wiring diagram for the light shows one 12v+ on pin #1. Pins #2 and #3 are grounds. When pushing to test, the light closes the circuit with #3. #2 is used for a switched ground (ie. gear position). I thought it would take two 12v+ inputs with a common ground, but it's opposite. How did you make this work? 3 Quote
jamesm Posted September 4 Report Posted September 4 Your Panel Looks nice. Have you considered flush mounting G5's ? I did on my '67C it looks nicer in my opinion. I did have my G5's sitting above panel for a couple of years. I changed mine because one of the RAM mount mounting option came real close to shearing off the knob of the G5. if I ever had to use full control input, highly unlikely but I decided to buy a little clearance so I flush mounted them. The other reason to mount every thing from the one direction is that if you need remove the panel. and you have some equipment the that mounts from the back and other equipment mount from the front. you have to disconnect pitot static lines and my understanding is technically that you would need to pitot static check the system again since you had to disconnect the pitot static lines. James Quote
tcal780 Posted September 4 Author Report Posted September 4 4 hours ago, jamesm said: Your Panel Looks nice. Have you considered flush mounting G5's ? I did on my '67C it looks nicer in my opinion. I did have my G5's sitting above panel for a couple of years. I changed mine because one of the RAM mount mounting option came real close to shearing off the knob of the G5. if I ever had to use full control input, highly unlikely but I decided to buy a little clearance so I flush mounted them. The other reason to mount every thing from the one direction is that if you need remove the panel. and you have some equipment the that mounts from the back and other equipment mount from the front. you have to disconnect pitot static lines and my understanding is technically that you would need to pitot static check the system again since you had to disconnect the pitot static lines. James Thanks jamesm, You make good points, but if that panel ever must come out again, a pitot static test would be the least of my concerns. I did consider flush mounting both G5's and the EDM900. Ultimately, I chose panel mounting only because flush mounting requires more space and this configuration would not have been possible. It was important to me to have the EDM900 located there, on the left. A flush mount would have forced me to place it on the right side. I decided, if I couldn't flushmount both the G5's and the EDM900, they would all stay panel mounted. Quote
Ron McBride Posted September 4 Report Posted September 4 Looks great, but where is your gear switch? Quote
tcal780 Posted September 4 Author Report Posted September 4 Dang. I knew I forgot something! It's right under the backup CDI to the right of the switches. I didn’t put the cap on it yet. Quote
Hank Posted September 5 Report Posted September 5 19 hours ago, tcal780 said: It's right under the backup CDI to the right of the switches. I didn’t put the cap on it yet. Where are the Gear Safe / Gear Unsafe lights? They are usually above and below the switch. Quote
tcal780 Posted September 5 Author Report Posted September 5 They will be right above the altimeter. Quote
Hank Posted September 7 Report Posted September 7 On 9/5/2024 at 7:10 AM, tcal780 said: They will be right above the altimeter. I see them now, with something in between. Should be very visible right in front of you! Quote
tcal780 Posted September 7 Author Report Posted September 7 12 hours ago, Hank said: I see them now, with something in between. Should be very visible right in front of you! I'm adding a stall indicator light (red) between the two gear lights. Quote
tcal780 Posted September 7 Author Report Posted September 7 I'm going to try switching the bulbs to incandescent and use the two ground pins as the switched 14v+ and a use the #1 pin as the common ground. The housing itself isn't grounded, so this should solve the problem with the push to test circuit mentioned in the above post. Quote
Dennis Pendergast Posted September 9 Report Posted September 9 On 3/9/2024 at 6:26 PM, tcal780 said: I finished 95% of the old panel cleanup. The remaining wiring seen in the photo will stay. A couple questions for the group: First, panel mounting. Are there "standard" mounting brackets and avionics rails available for a new panel like this or will I need to have them fabricated? The avionics guy said vibration isolators are not needed anymore, citing Garmin avionics often don't work well with them. Is this the case? Second, some advice on lighting. I am considering a combination of LED bezel ring lights for the 5 round instruments and an LED strip light on the underside of the glareshield for an overall flood. I'd also like to have the toggle switches or switch labels illuminated. The original throttle quadrant/flap labels and compass are also illuminated with incandescent bulbs. Can these be converted to LED? Ideally, I would like the avionics and the instrument ring lights to be on one dimmer and the remaining flood/panel lights to be on a second. What would you recommend? Thanks! Nice looking panel work! Who did you have do it? I may want to work with them too. Here are a few tips we have learned in our work on Mooneys in our avionics shop, perhaps you will find them useful: To my knowledge, there are no "standard" brackets available for the new panel. Most Mooneys we work on have the panel spaced out from the sub-structure using aluminum spacers to accommodate a #10 machine screw. The spacers are about 1/2" to 3/4" tall and guide the screw into a rivnut installed into the lower steel tube as well as the upper structure. These rivnuts are often stripped out and need replacement. Using a normal nut will make installation nearly impossible. We usually try to use the original provisions and mount the panel with hardware similar to what it originally had. Not all screws are equal. Remember that stainless hardware does not have the strength of most cad plated steel hardware. Use structural screws. Some inspectors will demand this and it is easily verified. Opinions vary widely on this, but instrument panel are sometimes considered to be "structural members." Make sure you maintain the original angle (fore and aft) of the panel. The spacer size will effect this. On the left and right side of the center stack, I notice that the vertical supports have been removed. I normally consider these to be structural members. Now, the panel which you are installing, if it is about .090" 2024T3 aluminum, will bring plenty of strength with it, but you might want to verify this. Much will depend upon the opinion of your local FSDO. Most reputable panel shops can also be very helpful with this and may have the paperwork to back it up. Some manufacturers actually require that the vibration isolators be removed since any movement of the panel can effect the accuracy of your digital instruments. Verify with the mfg's authorized documentation. I'm sure you've already done this, but remember to consider the structural steel tubes behind the center stack. I recently had to completely re-think a panel layout because of a mere 1/2" of interference the tubes brought to one of my deeper radios in the stack. Mooneys are famous for this as they have much less space behind the panel to fit everything where you want it. Hope this helps Quote
tcal780 Posted September 9 Author Report Posted September 9 5 minutes ago, Dennis Pendergast said: Nice looking panel work! Who did you have do it? I may want to work with them too. Here are a few tips we have learned in our work on Mooneys in our avionics shop, perhaps you will find them useful: To my knowledge, there are no "standard" brackets available for the new panel. Most Mooneys we work on have the panel spaced out from the sub-structure using aluminum spacers to accommodate a #10 machine screw. The spacers are about 1/2" to 3/4" tall and guide the screw into a rivnut installed into the lower steel tube as well as the upper structure. These rivnuts are often stripped out and need replacement. Using a normal nut will make installation nearly impossible. We usually try to use the original provisions and mount the panel with hardware similar to what it originally had. Not all screws are equal. Remember that stainless hardware does not have the strength of most cad plated steel hardware. Use structural screws. Some inspectors will demand this and it is easily verified. Opinions vary widely on this, but instrument panel are sometimes considered to be "structural members." Make sure you maintain the original angle (fore and aft) of the panel. The spacer size will effect this. On the left and right side of the center stack, I notice that the vertical supports have been removed. I normally consider these to be structural members. Now, the panel which you are installing, if it is about .090" 2024T3 aluminum, will bring plenty of strength with it, but you might want to verify this. Much will depend upon the opinion of your local FSDO. Most reputable panel shops can also be very helpful with this and may have the paperwork to back it up. Some manufacturers actually require that the vibration isolators be removed since any movement of the panel can effect the accuracy of your digital instruments. Verify with the mfg's authorized documentation. I'm sure you've already done this, but remember to consider the structural steel tubes behind the center stack. I recently had to completely re-think a panel layout because of a mere 1/2" of interference the tubes brought to one of my deeper radios in the stack. Mooneys are famous for this as they have much less space behind the panel to fit everything where you want it. Hope this helps Hi Dennis, Thanks for your thoughts on this. Superior made the panel. In order to replace the rubber isolators and keep the panel in the same position/angle as the original, we machined 4 lower mounts out of 1/2 billet. Each is two pieces, that effectively clamp the 1/2" support via (11) 2" #8 screws and nuts. #10's would not fit in the existing holes. The outer mounts are about 7-1/2" long and the inner ones are about 3." The left side inner mount needed some additional work since there's a weld there to contend with. I've attached a photo of the mounts test fitted with the acrylic template. 1 Quote
tcal780 Posted November 20 Author Report Posted November 20 Progress pics. Panel is installed, the main buss is in, all the Mooney systems are powered, and the EDM900. I learned a few lessons there. Particularly with the gear actuator breaker. I should have separated it or, at least, put it on the end. That 25Amp breaker style is different from the others, so i had to cut the buss bar, jumping to and across it. Relabeling the panel was not acceptable to me. Planning a run-up this weekend, then on to the avionics. 2 Quote
tcal780 Posted December 2 Author Report Posted December 2 Engine didn't start, but we didnt have much time to diagnose. I heard the SOS buzzing and I did smell fuel, but not one cyl fired. The mags were fine last time the bird flew in February. It turns out it was a good thing that it didn't fire up. After the battery quit, i discovered the starter gear failed and stayed engaged to the flywheel. Lighting/dimmer install complete. Quote
ragedracer1977 Posted December 2 Report Posted December 2 (edited) 2 hours ago, tcal780 said: Engine didn't start, but we didnt have much time to diagnose. I heard the SOS buzzing and I did smell fuel, but not one cyl fired. The mags were fine last time the bird flew in February. It turns out it was a good thing that it didn't fire up. After the battery quit, i discovered the starter gear failed and stayed engaged to the flywheel. Lighting/dimmer install complete. I believe that’s normal behavior on a no start and a bendix. The faster speed of the ring gear when the engine starts kicks the gear off. I’m not 100% on that, but I’d look into it before you spend money. The no start is almost assuredly a p lead issue. I’d triple check your key wiring. First thing I would do… key off - stay away from the prop! If you wired it backwards, the mags might be hot! Check if your p leads have continuity to ground. If they don’t, they’re hot. If they do, go turn the key to “on” or “run” and check continuity again. If they’re still grounded, it’s a wiring issue. I’ve seen 3 guys at the field with ignition switches wired incorrectly. Edited December 2 by ragedracer1977 3 Quote
