VanGo Posted August 9, 2023 Report Posted August 9, 2023 Recently had a complete avionics install. Initially it worked fine, however after a few weeks we get a message stating “AHRS magnetic anomaly-check installation” The shop is very cooperative in doing their warranty work. They feel there is some electronic interference occurring and plan on moving the location of the magnetometer. They are good avionics mechanics, but not Mooney specialists. Anyone else experience this?
chriscalandro Posted August 9, 2023 Report Posted August 9, 2023 (edited) Doesn’t have anything to do with the Mooney and you don’t need a Mooney mechanic. you should listen to the shop. Sounds like they are correct. It’s not complicated. Edited August 9, 2023 by chriscalandro 1
Bolter Posted August 9, 2023 Report Posted August 9, 2023 As a reference, my J had the factory magnetometer in the pilot-side wing, outside of the fuel area, near an access panel. The Garmin sensor with the G5 install used the same place without any issues. If yours is not in this location, that may be a factor. -dan
Ragsf15e Posted August 9, 2023 Report Posted August 9, 2023 1 hour ago, VanGo said: Recently had a complete avionics install. Initially it worked fine, however after a few weeks we get a message stating “AHRS magnetic anomaly-check installation” The shop is very cooperative in doing their warranty work. They feel there is some electronic interference occurring and plan on moving the location of the magnetometer. They are good avionics mechanics, but not Mooney specialists. Anyone else experience this? Mine is not in the wing, but in the tail cone behind the battery. However, it’s on a shelf well up and pretty far behind the battery and the avionics. Seems like either the factory location (outer wing area) or tail can work if they’re careful. 1
ArtVandelay Posted August 9, 2023 Report Posted August 9, 2023 Mine is not in the wing, but in the tail cone behind the battery. However, it’s on a shelf well up and pretty far behind the battery and the avionics. Seems like either the factory location (outer wing area) or tail can work if they’re careful.Mine too, I estimate they are about 2-3 feet from the AP servos…any motor or any wire with a large enough amperage will cause interference with the magnetometer. There’s a free app “magnitude” that will measure magnetic field strength you can use to check areas, just be sure strobes, landing lights, and motors are operating. 1
Utah20Gflyer Posted August 9, 2023 Report Posted August 9, 2023 My magnetometer is also in the tail cone, probably half way back on the pilot side.
N201MKTurbo Posted August 9, 2023 Report Posted August 9, 2023 Mine is in the right wing. It has been trouble free.
Pinecone Posted August 10, 2023 Report Posted August 10, 2023 There was a report of someone with issues with one tail cone mounted. It was something they stored on the hat shelf. Moving it to the floor of the baggage area solved the issue. They are VERY sensitive. I would put it out in the wing.
ArtVandelay Posted August 10, 2023 Report Posted August 10, 2023 Mine is in the right wing. It has been trouble free.Do you have the wing landing/taxi lights? LED or incandescent?Some AP roll servos are the left wing, some are in the right.There’s no 1 right answer, you need to go through the process of doing a magnetic field survey, but as a rule, try to stay 2 feet from motors and high amperage wires. 1
N201MKTurbo Posted August 10, 2023 Report Posted August 10, 2023 1 hour ago, ArtVandelay said: Do you have the wing landing/taxi lights? LED or incandescent? Some AP roll servos are the left wing, some are in the right. There’s no 1 right answer, you need to go through the process of doing a magnetic field survey, but as a rule, try to stay 2 feet from motors and high amperage wires. The only thing in my right wing is a strobe power supply and the nav light. The magnetometer is about 5 feet from anything electrical, except the wires. It is about 18 inches from any wiring.
flyboy0681 Posted August 10, 2023 Report Posted August 10, 2023 22 hours ago, Utah20Gflyer said: My magnetometer is also in the tail cone, probably half way back on the pilot side. When the GI 275 was installed the shop built a shelf in the tail for the magnetometer but we could never get an accurate calibration. We eventually had it moved to the right wing and now it's spot on. 1
EricJ Posted August 10, 2023 Report Posted August 10, 2023 1 hour ago, flyboy0681 said: When the GI 275 was installed the shop built a shelf in the tail for the magnetometer but we could never get an accurate calibration. We eventually had it moved to the right wing and now it's spot on. That looks like it would be subject to a lot of vibration, although I don't know if that would affect calibration. 1
ArtVandelay Posted August 10, 2023 Report Posted August 10, 2023 I assume the black wire (green) is an antenna wire, so that shouldn’t be a problem.But what looks like a conduit (yellow) and what is for?
ArtVandelay Posted August 10, 2023 Report Posted August 10, 2023 You can see my shelf at the very top (secured very securely):
N201MKTurbo Posted August 10, 2023 Report Posted August 10, 2023 3 minutes ago, ArtVandelay said: I assume the black wire (green) is an antenna wire, so that shouldn’t be a problem. But what looks like a conduit (yellow) and what is for? I think it is the fresh air plenum from the dorsal fin air scoop. 1
ArtVandelay Posted August 10, 2023 Report Posted August 10, 2023 I think it is the fresh air plenum from the dorsal fin air scoop.In that case, should not affect the magnetometer.
OR75 Posted August 10, 2023 Report Posted August 10, 2023 2 hours ago, ArtVandelay said: I assume the black wire (green) is an antenna wire, so that shouldn’t be a problem. But what looks like a conduit (yellow) and what is for? the black is a coax (com antenna) , the nylon conduit (yellow) is the static line (two static holes , one on each side of the fuselage tail cone
ArtVandelay Posted August 10, 2023 Report Posted August 10, 2023 the black is a coax (com antenna) , the nylon conduit (yellow) is the static line (two static holes , one on each side of the fuselage tail cone Yeah, thanks, but I meant the gray conduit at the top. 1
Ulysse Posted August 11, 2023 Report Posted August 11, 2023 On 8/10/2023 at 2:05 PM, Pinecone said: There was a report of someone with issues with one tail cone mounted. It was something they stored on the hat shelf. Moving it to the floor of the baggage area solved the issue. That was me. Unfortunately, it happened again, so the problem is still unsolved. The magnetometer is in the tailcone. This issue can cause your attitude indicator to become unreliable if you have a Garmin panel. See @PT20J's post on the topic "g5 as backup of g3x -> GFC500" about this. I am scared of flying in IMC now until this issue is solved. Please do let us know if you find the origin of the problem. 1
