Pinecone Posted January 30, 2023 Report Posted January 30, 2023 When I do my dream panel, I already have the GTX-345, so going remote is a good bit more money. For me, I am the same on the audio panel. But have to think about others that do like music. I will listen to it, but if there is none, I am fine. For me, the right hand display is for a second pilot flying in that seat. And a reversion screen, just in case.
rbp Posted January 30, 2023 Report Posted January 30, 2023 32 minutes ago, Pinecone said: For me, I am the same on the audio panel. But have to think about others that do like music. I will listen to it, but if there is none, I am fine. For me, the right hand display is for a second pilot flying in that seat. And a reversion screen, just in case. the remote Garmin audio panel can do all of this, with bluetooth integration for music. all you do is touch the "Audio Panel" button and can do what you want the right hand display is only a backup for a failed PFD display screen. it does not backup the AHRS, so its not really "reversion". The G5 has its own AHRS
Denis Mexted Posted January 31, 2023 Author Report Posted January 31, 2023 George, no sorry ArtVandelay thanks for clarifying the HSI / CDI thing. The flat screen might be a bit much for me, but I'm sure the kids would love it. I do like the compass on the dash. Keith20EH - thanks for the very nice pic. So as I can get some perspective on layout, do you have a daylight one? What would the two annunciator lights be on the right side of the gear lever? Just below the compass correction card. I found some blank instrument panels eBay which was good to get my head around. Not sure why a person would buy one full of holes already. But is there a source for new blanks? I see the main panel has a rolled lip on the bottom, and a funny box thing to the left. I've been tossing up, yes or no on buying this aeroplane, but the F/O I was flying with this morning has a few aircraft online and talked me through a few ideas on structuring the process. Probably what I needed.
Pinecone Posted January 31, 2023 Report Posted January 31, 2023 15 hours ago, rbp said: the remote Garmin audio panel can do all of this, with bluetooth integration for music. all you do is touch the "Audio Panel" button and can do what you want the right hand display is only a backup for a failed PFD display screen. it does not backup the AHRS, so its not really "reversion". The G5 has its own AHRS Having just done a CAP checkride in a G1000 aircraft, reversion is what Garmin calls using the other screen for the data or combining the data into the primary screen if the MFD fails. Again, I am looking at a right hand display for a pilot in the right seat. The other option is a docking station for an AERA 760
Keith20EH Posted January 31, 2023 Report Posted January 31, 2023 On 1/30/2023 at 10:57 AM, Fly Boomer said: What is the bright green thing on the starboard side? It’s a cigarette lighter USB charging port and voltmeter. Felt like the original amp meter wasn’t quite the full story.
Ragsf15e Posted January 31, 2023 Report Posted January 31, 2023 10 hours ago, Denis Mexted said: George, no sorry ArtVandelay thanks for clarifying the HSI / CDI thing. The flat screen might be a bit much for me, but I'm sure the kids would love it. I do like the compass on the dash. Keith20EH - thanks for the very nice pic. So as I can get some perspective on layout, do you have a daylight one? What would the two annunciator lights be on the right side of the gear lever? Just below the compass correction card. I found some blank instrument panels eBay which was good to get my head around. Not sure why a person would buy one full of holes already. But is there a source for new blanks? I see the main panel has a rolled lip on the bottom, and a funny box thing to the left. I've been tossing up, yes or no on buying this aeroplane, but the F/O I was flying with this morning has a few aircraft online and talked me through a few ideas on structuring the process. Probably what I needed.
Denis Mexted Posted March 15, 2023 Author Report Posted March 15, 2023 Hand forced. Bench tested the two gyros. DG wanders, AH works, but very nosy and not a lot of life left. Vac pump already failed. So 2 G5's it is. The direction driver for the HSI G5 I'm told comes from a GMU 11 Magnetometer. Is there any trick to mounting this? Does it need a rack and does it need to be mounted flat for normal flight. I'm sure a lot will be explained when the unit arrives, but that's weeks away.
Ragsf15e Posted March 15, 2023 Report Posted March 15, 2023 7 minutes ago, Denis Mexted said: Hand forced. Bench tested the two gyros. DG wanders, AH works, but very nosy and not a lot of life left. Vac pump already failed. So 2 G5's it is. The direction driver for the HSI G5 I'm told comes from a GMU 11 Magnetometer. Is there any trick to mounting this? Does it need a rack and does it need to be mounted flat for normal flight. I'm sure a lot will be explained when the unit arrives, but that's weeks away. Yes, it needs to be properly secured, oriented and mounted. Typical location are in the aft avionics area behind the baggage or out in the wing. The installation manual is available online and should guide you through.
RobertGary1 Posted March 15, 2023 Report Posted March 15, 2023 G5 cannot legally replace pitot static although 275 can. But I don’t recommend it. Dual AHRS failures can happen. Garmin has an SB on it and it happened to me. They talk to each other and tend to hit bugs at the same time. So I kept my vacuum attitude.
Denis Mexted Posted March 15, 2023 Author Report Posted March 15, 2023 Thanks, the aft avionics area would be ideal. I've just pulled the HF out of there sucking up a huge amount of space and weight.
Denis Mexted Posted March 15, 2023 Author Report Posted March 15, 2023 Thanks RobertGary1. This aircraft is going out VFR initially. Although if it goes out IFR it won't have a Vac system. When I was a much younger person I departed in a C210 into the murk and the AH rolled over. The T&B was very useful and got me home. I'm sure it wouldn't have looked pretty on the modern tracking apps, but it worked. * I will keep all pitot / static instruments.
gmonnig Posted March 15, 2023 Report Posted March 15, 2023 I love all the panel pictures. I like seeing how people do different things. I need to get to work on the CGR-30 combo! Those look good. After a beautiful flight yesterday, I am motivated to keep working on the plane. 2
Igor_U Posted March 15, 2023 Report Posted March 15, 2023 On 1/31/2023 at 10:08 AM, Ragsf15e said: Nice, functional panel. Who did the leather on the yokes? Thanks
Igor_U Posted March 15, 2023 Report Posted March 15, 2023 11 hours ago, Denis Mexted said: Hand forced. Bench tested the two gyros. DG wanders, AH works, but very nosy and not a lot of life left. Vac pump already failed. So 2 G5's it is. The direction driver for the HSI G5 I'm told comes from a GMU 11 Magnetometer. Is there any trick to mounting this? Does it need a rack and does it need to be mounted flat for normal flight. I'm sure a lot will be explained when the unit arrives, but that's weeks away. Denis. You can download the latest G5 installation manual from the Garmin website. It's quite detailed and all your questions will be answered. Good luck.
EricJ Posted March 15, 2023 Report Posted March 15, 2023 12 hours ago, Denis Mexted said: Thanks, the aft avionics area would be ideal. I've just pulled the HF out of there sucking up a huge amount of space and weight. The installation location for the GMU11 is not just based on convenience, but where it will actually work given the equipment on the aircraft. As mentioned by others, the installation manual describes how to do the survey to determine the best installation location. That said, mine is back there in the tail on a fabricated shelf. 2 1
Ragsf15e Posted March 15, 2023 Report Posted March 15, 2023 2 hours ago, Igor_U said: Nice, functional panel. Who did the leather on the yokes? Thanks Thanks! I don’t know. Previous owner had that done at some point. I’ve had the airplane about 9 years and they’ve held up well. It could use new carpet and some headliner work, but I mostly concentrate on keeping it mechanically sound and having a good functional panel.
gmonnig Posted March 15, 2023 Report Posted March 15, 2023 1 hour ago, EricJ said: The installation location for the GMU11 is not just based on convenience, but where it will actually work given the equipment on the aircraft. As mentioned by others, the installation manual describes how to do the survey to determine the best installation location. That said, mine is back there in the tail on a fabricated shelf. Did your Mooney come from the factory Zinc Chromate? I wasn't sure if that was an option back in the day
McMooney Posted March 15, 2023 Report Posted March 15, 2023 25 minutes ago, gmonnig said: Did your Mooney come from the factory Zinc Chromate? I wasn't sure if that was an option back in the day are they all not like this ?
EricJ Posted March 15, 2023 Report Posted March 15, 2023 32 minutes ago, gmonnig said: Did your Mooney come from the factory Zinc Chromate? I wasn't sure if that was an option back in the day I'm guessing so given the part number on the bulkhead. Been like that since I got it, including the dirt from twenty years of painstaking outdoor parking positioning in the Nevada desert dust storms. I should probably spray some mernal spertz in there to try to wash that stuff out the drain holes, but I'm worried it'll just concentrate on the bottom and plug the holes or something. 1
gmonnig Posted March 15, 2023 Report Posted March 15, 2023 15 minutes ago, McMooney said: are they all not like this ? Mine is not. Maybe I have the "CB" model! 1
EricJ Posted March 15, 2023 Report Posted March 15, 2023 1 hour ago, gmonnig said: Mine is not. Maybe I have the "CB" model! But look how clean it is! 2
RobertGary1 Posted March 15, 2023 Report Posted March 15, 2023 18 hours ago, Denis Mexted said: Thanks RobertGary1. This aircraft is going out VFR initially. Although if it goes out IFR it won't have a Vac system. When I was a much younger person I departed in a C210 into the murk and the AH rolled over. The T&B was very useful and got me home. I'm sure it wouldn't have looked pretty on the modern tracking apps, but it worked. * I will keep all pitot / static instruments. Do you need the tc for the autopilot? Otherwise that’s the first thing I’d ditch.
Denis Mexted Posted March 16, 2023 Author Report Posted March 16, 2023 Do you need the tc for the autopilot? Otherwise that’s the first thing I’d ditch. An interesting point. (we really are a product of our experiences) My thinking was backup if the gyros (in this case screens) topple. But as you point out there is no reason the standby can't be another Vac driven gyro. Thanks. Making this an IFR machine would be 1/2 years away and dependant of a few things, including that USD to back off a bit. It's killing me at the moment. I apologise for the 'questions' guys. There are stages in life where there is time to spend manual reading and times where it's a challenge due work, kids and trying to restore a Mooney in insufficient time. My avionics installer will be all over this. I just was seeking some real world solutions. Anyway, he'll be here soon, so out of bed.
philiplane Posted March 16, 2023 Report Posted March 16, 2023 so when the solar flares hit and GPS goes offline, all the cool G5's and anything else GPS based becomes useless. Vacuum instruments will be unaffected. This is the dirty little secret of all modern GPS aided AHRS units. Without GPS, they are unreliable. 1
