Bolts in picture are to 0-360-A1D measured to be 1/4 inch. Standard torque table shows 96-106 inch pounds. If that’s the case, they ARE loose! My wrench does foot pounds which would equate to 8-8.83 foot pounds. Feel free to check my math. Am I looking at this correctly? Thanks!
Torque values agree with Lycoming SSP-1776 and the math is right. However, that seems like a low value for a torque wrench calibrated in ft-lbs. I might get an in-lb wrench where 100 in-lb is closer to mid scale and recheck.
What's up with the red RTV? Maybe someone tried to fix a leak? That may be what caused the bolts to lose torque as the RTV shrunk.
Factor of 12 just like you would expect…
But, if your wrench only does ft-Lbs…
Check the accuracy at its low end…
Torque wrenches are pretty low cost this century… compared to past…
Then there is that whole discussion on calibration…
PP thoughts only…
Correct on all accounts… *sigh
The nut and bolt in the second picture are the wrong p/n.  That an MS21042-4 nut instead of an STD1411 Lycoming nut.
Ah, the eagle eye of a pro. Priceless!
