20230118_115358.jpg.8913d058431147205372cf7a62b03f89.jpgLook at what I dug out of my parents storage. :)
No clue what the big 8footer came off of but it's cool.
Definitely the real deal.
  • Like 5
A little bit of sandpaper then varnish and that’ll look really good on yer Mooney!
On 1/21/2023 at 6:33 PM, N201MKTurbo said:
If you look for the numbers stamped in them, you can usually figure out what they are used on.
Going to get a magnifying glass. Nothing jumps up at me at first glance.
They are usually on the hub near the mounting holes. It would be strange if there are no numbers anywhere. They usually aren't small.
But after a century, they may be hard to see.
David, it may help to shine a flashlight almost parallel to the surface, this will put the impressions in the dark and make them easier to locate.
It's also a helpful technique when you drop something small on the floor . . . . .
Found these numbers. I cannot tell if the first numeral is the letter 'K' or the Roman numeral 'IX' ? That's what it sort of looks like to me.
This is on the larger prop.
